Question about Maytag 24" Built-In Single Electric Wall Oven - White
Maytag model# CWG3100AAE - only light works.after power surge digital clock and oven wont work. I ordered the clock assy, it will be here in two days (Pt#12001620) but, dont know if thats the problem and its not im out $260.00. If so, is it hard to install?
Krazytech
  • 725 Answers
SOURCE: Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Posted on Aug 23, 2007
SOURCE: De Dietrich Oven - Clock tripping back to 00:00 means I cant turn on my oven!
its a fix more than a solution but you can bypass the clock thus allowing the oven to operate again
unplug at the mains and remove the oven from the housing remove the two fastening screws from the metal lid on the top of the oven ,and remove the lid
you will see the timer back panel with 3 wires coming to it, 2 are black (switching line) and 1 is red (Live feed to timer )
If you pull the connectors from the 2 black wires from the timer board and connect the ends together using a connector block, the timer switch becomes inactive and allows the oven functions to operate again.
you will have no timer functions but its a cheap fix and who uses the timer any way
good luck Andy B
ps if anyone has a set of operating manuals for ths oven i would be glad of a copy
Posted on Sep 26, 2008
  • 4 Answers
SOURCE: Oven will not ignite
The problem is not fixed, but I know it involves replacing the ignitor and/or the gas valve. I just wanted help diagnosing the two so I only had to buy one part if I could. We live on a budget and if I could avoid replacing an unnecessary part that would help. I am afraid your elite people would just tell me to start with the ignitor and then the valve.
Thank you just the same.
Randy
Posted on Jan 03, 2009
kojak18
  • 31 Answers
SOURCE: Gas Maytag oven won't ignite
my oven would take almost 25 minutes to get to 125 degrees. i replaced the igniter for around 48 dollars about a year ago and have had no more problems. hope this helps. if you are any kind of handyman at all it is a do it yourself job.
Posted on Feb 21, 2009
barkencoa
  • 3463 Answers
SOURCE: had a power surge and the clock went blank and
It is quite possible that the power surge has damaged the electronic components in the controller or timer, thus rendering it unuseable.
It would mean replacing board or timer.
Hope this helps ypu.
Posted on Dec 18, 2009
Lower Bake element wont heat up.
no,but if you google who rebuilds oven clock assy. and i did it and found one for you
https://www.appliancetimers.com/faqs
you call them and give them your model number,they'll tell you if they can rebuild your clock assy.you draw out a schematic of where the wires go,remove the clock assy. and mail it to the company,they fix your clock and mail it back to you and you reinstall it,i've done this with older thermador ovens,the clock goes blank and you can't get them anymore,it's great because it was under 100.00 bucks and you have a rebuilt clock assy. the way i did it was mark down on paper the color wire and where it went and then i would start from the left top corner and i would get a marker and put a line on the first wire,then 2 marks on the second wire and so forth,but when i got to like the sixth wire i would tape them together just like they were still connected in the same order and then start with the marks again and when you go to put the clock back in the wires would almost line right up from being in that position for so long so it isn't that hard to do,you can take pictures to whatever works for you but this way is cheaper than buying a new clock assy. if you can still get it depending on how old the stove is.hope this helps you out and happy holidays.
Dec 21, 2017 | Maytag CWE5800ACE 24" Electric Double...
Hotpoint oven bs43
you need to send the full model number,most likely you have a bad clock assy.even though your clock might work it comes with the clock and a computer board all together.i never heard of resetting a timer,i do know that if you unplug or shut down the power from the fuse box for 5 to 10 minutes sometimes resets the computer just like a regular house computer, it sounds like your loosing power and i don't think resetting anything is gonna help you,also make sure you have 240 volts going to the oven,but if the fan and light are not working and no heat it sounds like you have a bad clock assy.if it's in good shape and depending on the age you might want to call someone in to check it for you,if it is the clock assy. it might not be avalable anymore but there are companies that can rebuild the clock assy. you have.good luck with your oven.
Jul 10, 2013 | Ovens
Gas oven wont come on
oven ignitor they only last about 10 years they burn out like light bulbs
Aug 15, 2012 | Maytag CWG3100AAE Gas Oven
Whirlpool single oven model AKZ146/WH. Oven not working, had power failure and display says 'stop' and tried everything in manual, doesnt help, cannot change time or get over to work. I have had...
alot of times when power goes out and then comes back on the power serge can take out the clock assy. you can either change out the clock assy. yourself or call someone in to do this and send the bill to your electric company,have done this before,one customer lost his oven and dishwasher and electric corp. paid the bill.this sin't just the clock it has all the relays on the computer board everything to run the oven,it all goes through the clock assy. the model you sent doesn't show up,you have to find the tag on the oven and give it to the parts store to order the correct part,if the overlay is white for some reason white overlays don't come off,if it's black you can heat it up with a hair dryer and use a putty knife to peal it off and stick it on the new clock assy. good luck.also if this is an older oven you might not be able to get the part you'll have to send it out to get rebuilt or contact your electric corp.tell them the part is no longer available and they'll have to replace it for you.i would call them as soon as possible all they can say is no they won't help you out but here in mass. they do.
Dec 30, 2017 | Whirlpool AKZ159IX Oven
Gas oven repair for Maytag Oven CWG3100AAE after a
More than like a surge has fried most of the electricals in your oven. Since you are dealing with a gas appliance I suggest be very careful. Even the tiniest gas leak could result in your residence blowing up, etc.
For this reason I recommend call your gas company, and have them come out and install a new one for you.
It's just not worth the risk.
Nov 19, 2017 | Maytag Ovens
F-2 error on digital screen, mAYTAG GAS OVEN, SELF CLEANING not sure model #.
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 31, 2011 | Maytag CWG3100AAE Gas Oven
When pushing the button bake and broil the red light starts to blink on lock ? this happened after i woke 1 morning n noticed there was no time where the clock was, it was all dark n nothing worked, after...
if the clock is blank it's bad and you have to change out the clock assy. if that's your model number MEW5527B it says your part is
WP74009198 and it's around 260 dollars but this must be an older wall oven because nobody has it in stock,you can go here,put your full model number in and go to control panel and look up your computer board or clock assy. same thing
https://www.searspartsdirect.com/model-number/MEW5527BAW/3048/0125300.html
Feb 06, 2018 | Maytag MEW5527B Electric Single Oven
Had a power surge and the clock went blank and ove will not turn on but the oven light still works. maytag built in single oven
Dec 18, 2009 | Ovens
Keypad/clock went blank
Normally when a power surge lands a direct hit on a non protected circuit board, it will usually fry it completely. you can confirm this by shutting down the power for 5 minutes. if the control doesn't respond after the 5 minutes of no power, this will confirm circuit failure due to the surge and, you will need to replace the board in this case.
May 18, 2009 | Maytag CWE5800A Electric Double Oven
Maytag 24" Built-In Single Electric Wall Oven - White Logo
43 people viewed this question
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
