Question about Nokia 1600 Cellular Phone
Please Help For Nokia Service Problem Solve Tips and flashing software tips
    President:
  • 563 Answers
You can check tips about Nokia here.
Posted on Sep 02, 2010
Allflashfiles.com
Allflashfiles.com is a website where you can download all flash file and firmware for flashing mobile phones. You can download all nokia flash files for free by going to all nokia flash file download category. Also there are many tips and tricks and guides for flashing and formatting for repairs of software related problems of mobile phones.
Oct 01, 2013 | Cell Phones
Noia6600 system error
Just format it by using this trick Nokia Formating tips.Or if not solved contact mobile repairing shop to flash it.Good luck . thanks for visiting fixya
Oct 20, 2011 | Nokia 6600
Sir, my nokia 7210c mobile phones phone memory is full i had delete some files but some files are not able to delete it says not support flash files and music player is not play says not enough memory pls...
Here is your solution...............
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment. thanks for visiting fixya. Good luck.
Sep 15, 2011 | Nokia 7210
When i open my nokia 3110c mobiles massage options like "create massege, " inbox" my mobile is automatically switchin off. and my mobiles music player is not updating music files.please help...
To solve this two problem flashing is the best way.So contact mobile repairing shop or follow the procedure below.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 3110c file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Aug 31, 2011 | Nokia 3110 Cellular Phone
My nokia 6500s-1 when i switch on then after the logo of of nokia showed on the screen the date settings appeared and after a few seconds it goes blank then it automatic turns off? please help...
It is definitely software.problem .To solve this we need to flash/update the phone .If you do not want to concern a mobile tech.Follow the tricks
My fixya Tips Good luck.Thanks for visiting Fixya
Jul 26, 2011 | Nokia 6500 Slide Cellular Phone
Can i install software in my nokia 3110 classic cell phone ? if yes then how?
Hi....
To flash(format) you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash(format) *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
For more inf about formatting read my tips and how to do.......
Thank you
Feb 03, 2011 | Nokia 3110 Cellular Phone
Problem of cantact servies center
If your phone display contact service, it means the phone software is corrupt, yo solve this contact service problem, you will need flash the phone.
To get the phone flashed, take the phone to any local service center to help flash your phone with a software, once this is done, it will help restore your phone back. flash your phone to resolve the contact service problem.
Dec 03, 2010 | Nokia Cell Phones
5130 contact service problem
Take care.
Aug 09, 2010 | Nokia 5130 Cellular Phone
Nokia team please help me .i have (20pcs) 5130 mobile set in end user's5130 in problem contect service .when mobile switch on after nokia shakehand disply showing contect service.when i use in verious...
This problem has no specific solution, but the only and the final solution is "Flashing". For nokia, Ufs and Jaf boxes are the best flashing software. If these two can't flash your handsets, then there must be internal problem like cpu or power supply ic. If this is the case, repairing or getting repaired would be tough.
If all your 20 sets aren't working and displaying the same problem and asking for the same key, you better take another look at the flashing software. There must be error and something must be wrong with it. I wonder how 20 pcs got the same problem, you must look into the matter very carefully, otherwise, you'd damage more sets. You also need to replace your data cable for the particular model.
Good luck.
Thanks for using FixYa.
Jun 28, 2010 | Nokia 5130 XpressMusic Red Unlocked Import...
Software
nokia 3110 classic software
Apr 03, 2008 | Nokia 3110 Cellular Phone
Nokia 1600 Cellular Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
