Question about Sta Rite Sta - Rite 2hp Max - E Pro Inground Pool Pump, P6ea6g207l
EARLEIR TODAY I REPLACED ALL MY FILTERS FILTERS AND TURNED MY STA RITE E GLASS II ON ....IT RAN FOR ABOUT TEN MIN......... SHUT OFF AND NOW IT WONT TURN BACK ON HAVE RESET ALL BREAKERS IS THERE A RESET BUTTON ON THE PUMPITS SELF OR???
  • 990 Answers
First to be sure shut the breaker off then turn back on. Most breakers require that you do this for safty reasons. Check all your power from the breaker to the back of the motor with a meter. If you have power shut it off then open the pump by removing the steel clamp that goes around the pump. Pull the motor and back half of the pump away from the rest of the pump. Now remove the difusser, the white plate covering the impeller. Then try to spin the impeller. If it spins then try to start thr motor. If it goes then you have a problem with the impellor or the difusser. If it won't start at this point you probally have a bad motor and will need to replace it. I always recomend new but you can get a rebuildt. If it's the impeller that will usually be obvious. You can take it into your local store and have them match the parts and they will usually do the bench work for just the charge for parts.
I hope this helps, good luck.
Posted on Aug 31, 2010
89 cougar 3'.8 car stalls. no spark. starts again after 10 to 20 minutes
It sounds like your crank sensor or cam sensor are failing. When either of those two sensors overheat they will shut down the engine until they cool down
Dec 09, 2012 | Sta Rite STA-RITE IGNITION CONTROL MODULE...
Looking for manual on Sta Rite Sand filter Model HRP830
Here is a copy of the users manual for Sta Rite BRPB30 pool filters.
http://www.pool-filters.com/pdf/Sta-Rite-HRPB-Filter-Manual.pdf
Apr 16, 2011 | Sta Rite Sta - Rite 31" Sand Filter & 1.5...
How can i get a Manual of Sta-Rite Hi - Rate Sand Filter system ??? Model- D 64347
Sta-Rite is owner by Pentair; their manuals are available here. Sand filters are towards the bottom of the page.
John
Nov 24, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
EARLEIR TODAY I REPLACED ALL MY FILTERS FILTERS AND TURNED MY STA RITE E GLASS II ON ....IT RAN FOR ABOUT TEN MIN......... SHUT OFF AND NOW IT WONT TURN BACK ON HAVE RESET ALL BREAKERS IS THERE A RESET...
Thank you for posting your question here on Fixya.com.
It is an automatic reset thermal overload. Something is causing the pump motor to overheat and shut off to avoid permanent failure.
The motor is likely failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft to see if it is damaged, best, or the bearings seized.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Aug 31, 2010 | Sta Rite Sta - Rite 2hp Max - E Pro...
Looking for the best replacement pool filters for Sta Rite s8m150 inner and outer filters. Dont know if I should stay with Sta Rite brand or other relacement options.
I would recommend sticking to sta-rite. They are more expensive but are worth it. The system 3 cartridges are very good compared to generic replacements.
Mar 19, 2010 | Pool & Spa
Sta Rite Sta - Rite 2hp Max - E Pro Inground Pool Pump, P6ea6g207l Logo
105 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Jim Goldsmith
Jim Goldsmith
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
