Question about Sony VAIO VGN-N130G/W Notebook
Opening disk drive compartment
I can't get the compartment open so I can insert a CD. I am pushing the little button, but no response.
I'd appreciate a bit of help.
cleostern@att.net
    Novelist:
    Scholar:
  • 134 Answers
If you stll have this problem, then you might try a couple of things..
Firstly, a boot of the pc usually will allow the drive to be opened.. But I'm sure you have tried that.. So, there are a couple of other ways.. There is a small pin hole in the front of 'most' CD & DVD rom drives. This is used for emergency situations when the cd will not 'dismount'. Be careful here. Use a paper clip & insert it gently into the pin hole. Only use a light pressure & you should feel a small switch plate. Gently push it with the (extended) paper clip. It will switch the open button & should allow the drive to open. Thirdly, go to 'Start' (button), 'My Computer' highlight the CD rom drive (left mouse click) then right mouse select 'eject' from the menu options.. Actually, if you are still reading, do this first. If it fails, boot the pc & try it again, before using the paperclip method. good luck. Rgds,
Posted on May 09, 2008
How do i open a disk drive to a acer aspire e touch
well it sounds to me like you are just trying to open the drive to insert a disk ? go to "computer" or "my computer" on the desktop, double click to open. you should see your hard drive "c" and cd/dvd drive "d" listed. right click the "d" drive, left click eject, voila. if you have more than one hard drive or a partitioned drive there might well be more drive letters but your cd/dvd drive will be marked as such. alternatively click "start", bottom left of desktop, click "computer" and once again you should see your drives listed. physically there should be , on the cd/dvd drive drawer itself a small button, push it once to open. failing all else, there should be a very small hole in the drive drawer, using say a paper clip or similar, insert into the small hole and push reasonably firmly, this should release the drawer manually and the drive will open. hope that helps. good luck.
May 11, 2014 | Acer Aspire 5315 Notebook
How to eject dvd disk samsung laptop no eject button?
There are two ways toopen the CD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD driveis faulty and needs replacing.
Apr 01, 2012 | Samsung NC10-14G Notebook
Cannot open compact disccompartment
If you are trying to open it with the eject button and it does not work, you may have a faulty drive. To manually open the DVD compartment, take a paper clip, straighten it, then push it in the little whole next to the eject button, it should pop out the DVD compartment.
Apr 16, 2011 | Acer Computers & Internet
Inserted a DVD wrong way around (silver side facing towards us) now we can not ejecetd or play it.
Here are some options from best to worst and I recommend that you turn off the computer beforehand
Use a straightened paperclip and insert an end into the auto eject hole. (A little pinhole on the front of most disk drives)
Use a knife or flathead to pry the disk tray open.
If it doesn't have a tray you could use tweezers to pinch it out of there
I have pryed open disk trays before without issue
Mar 15, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
I don't know how to open the CD compartment on this laptop.
Open My Computer, right click on the icon for the cd unit and click Eject.
Dec 04, 2010 | Dell Latitude D600 Notebook
CD tray not opeing
Perhaps it didn't fully latch so the CD drive doesn't think it's closed? Try opening and closing the door manually by straightening out a paperclip, then inserting it into the little hole in the front of the CD door. That should open it. Once open, close it and see if it will now open when you press the Open/Close button.
Aug 26, 2009 | Acer (KV.16X04.007) DVD Drive
My disk drive doors will not open
hello budy ! the drives door wont open if the drive is not getting power or the drive is bad .
so pls get Another drive
Jul 10, 2009 | Dell Dimension 3000 PC Desktop
Can open cd tray. How do you open zip drive on G4 Quicksilver
please see on cd drive u seen 1 small hole insert small stick in open tray .
Apr 28, 2009 | Computers & Internet
Compact Disk Drive isn't opening or recognizing disks
The drive may be dirty or jammed. Use an expanded paper clip. Insert the wire into the little hole on the front of the unit. That will engage a manual switch. Gently open the unit all the way. Now press the button and let it close by itself. If this doesn't work it may also be an electronic failure.
Apr 07, 2009 | Dell Inspiron 6400 Notebook
Dvd tray and cd tray won't open on hp pavillion a 250n
Did it work OK under XP Home ?
Did you do a clean install or Upgrade your sytem when you "upgraded" to XP Pro ?
Jun 18, 2008 | HP (176135-630) (176135630) Internal 48x...
Sony VAIO VGN-N130G/W Notebook Logo
62 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
