Question about Canon Xha1s Hd Hdv 3ccd Mini Dv Camcorder Xha1s Xha1s Mini DV DV Flash Media
When I try to start recording it reads "in card position"
Insignia NS-DCC5SR09 camcorder card Locked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 27, 2014 | Insignia Video Cameras
Memory card is locked philips lfh 9600
Jan 08, 2013 | Olympus DS-4000 Digital Voice Recorder
Screens is reading card is locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 27, 2011 | Vivitar DVR 508HD Digital Video Recorder
Will not read the memory card .keeps saying no memory card and cannot record when ever you try to take a picture
Possibly the SD or SDHC memory card has been locked here is a diagram of a memory card in the two positions.
Also a new memory card will need to be formatted to the camera before the camera can properly communicate with the memory card.
Diagram
Here is a screen shot of the Format page showing the menus
Diagram
Have fun
Jan 12, 2011 | Canon PowerShot SX10 IS Digital Camera
When I try to take a picture with my Pentax Optio W10, I read on the screen "card locked" + icon, and of course no image is recorded. this started happening out of the blue. What to do ?
Look at the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 18, 2010 | Cameras
Lock/read only card message
Make sure all the files from the memory card have been downloaded and saved to the computer. You are going to need to format the memory card to remove the write protect/read only/lock issue. By formatting this will permanently erase all data from the memory card so you are able to use it again.
To format the card: go to Menu - to Submenu - to Format option - Start - then Start again - Press Menu to initiate the process - When done the recorder will be able to be used for recording purposes again.
Dec 18, 2008 | Olympus DS-4000 Digital Voice Recorder
Problem with memory card
your camera can only read so many partitions
( File Allocation Tables )
( partitions are sections of the total volume )
Like slices of a cake.
which equals 4 GB, total.
so it will never be able to read more than this.
Like FAT32 on a Pc, will read 32GB
but you could have a 100GB hard drive in the machine, still reads 32GB only, so even on a PC 68GB would be wasted.
The file format on the camera can not change,
So you are stuck with 4GB max reading.
Hope this halps
Regards
Richard.
Oct 04, 2008 | Pentax Optio W30 Digital Camera
In card position
check the SD card and see if the little tab on the side of it is slid to the position that says "lock" If you cant see the words, try just switching the tab to the other side. Since SD means Secure Digital, these cards wont do anything if the lock tab is not in the right position.
Feb 08, 2008 | Canon DM-XM2 Mini DV Digital Camcorder
IN CARD POSITION
A properly functioning camcorder will report this if it has both a card for recording and a tape mechanism for recording, with a switch set "in card position" when you press the movie mode record button. If you have a camcorder like this, look for a button marked "photo" that is used specifically for snapping still photos.
May 18, 2007 | Canon MV530i Mini DV Digital Camcorder
How Do I Make An MPEG Recording?
You can record video with audio onto the Memory Card. Follow the instructions below. Recording moving pictures onto a MEMORY CARD 1. Insert a Memory Card into the slot on the camcorder. 2. Set the mode switch to MEMORY CARD position. 3. Set the power switch to CAMERA mode. 4. Press the START/STOP button, the images are recorded on the MEMORY CARD in MPEG4. * You can record 10 ~ 20 seconds continuously. * You can record a still image on the Memory Card by pressing the Photo button instead of the START/STOP button. 5. Press the START/STOP button to stop the recording. Notes: * Moving images that you recorded are saved in *.asf file format on the Memory Card. * The moving picture images on a Memory Card are smaller size and lower definition than those on a Tape. * The sound is recorded in mono. * The following functions cannot be operated in M.REC Mode. - DIS (Digital Image Stabilizer), Digital Zoom, Fade, Program AE, Digital Special Effect, Slow Shutter. * Don't insert or eject a tape during Memory card recording as it may record noise. * Don't eject the Memory Card during recording as it may break the data on the Memory Card or the Memory Card itself.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Canon Xha1s Hd Hdv 3ccd Mini Dv Camcorder Xha1s Xha1s Mini DV DV Flash Media Logo
265 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
