Back to:
Tags:
Printers
Generic problem for all Printers
Brand new Brother MFC-685CW won't print via... (by 2 users)
posted by UGA-CJM on May 09, 2008
Ok - very frustrated here. I consider myself pretty electronically savvy, and I can't figure this one out for the life of me.
I have just purchased a Brother MFC-685CW multi-function printer. I went through the wireless network setup process using the "control panel" on the machine, and everything worked fine and it says it is connected. I have verified in my router admin page that the printer is indeed connected to the network.
However, I have tried installing the printer on 2 different PCs, and Windows shows the printer as "Ready". I have set these up using a Standard TCP/IP port, and then used the driver from the CD they provided. However, when I try to print the job fails. No error message, it just finally dies and says it couldn't print.
It seems to me that the computers on the network just can't "talk" to hte printer.
What am I missing?
Comment by UGA-CJM, posted on May 09, 2008
Thank you for the advice. I actually have already tried installing the printer using the installation CD. Unfortunately, that didn't work either. However, I have not yet tried using the actual IP address for the port (I have only used the hostname). As of now, the printer is not using a static IP, but if necessary, I can change it....but shouldn't it work with the hostname?
I am going to try this route and will report back after I have done it, but if anyone has any other ideas I would appreciate it.
Thanks...
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by bot-1, posted on Aug 18, 2008
I HAVE TRIED TO INSTALL MY BROTHER BUT EACH TIME I ET A ERROR. IT WAS WORKING FINE UNTIL I GOT A NEW COMPUTER.
Best Solution
Thanks for Trying (70)
Rasjin
Rank:Master Master
Rating: 90%, 21 votes
First, I would recommend NOT trying to manually install this printer by using the add printer wizard in windows and selecting the the port and drivers to use. I would use the install cd to set this all up, it makes setting up this printer MUCH easier. If you are unable to use the install cd then get the IP address for the printer from your router admin page then with the printer "installed" go into the printer properties, go into the port, add a port, and instead of using a printer name just type the IP address for the printer in. Also for any networked printer make sure you don't have a firewall blocking it (this would include making sure that if the printer requires a port opened in the router that all requests for that port are routed to the IP address of the printer).
Rating Locked! (?) UGA-CJM has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Brand new Brother MFC-685CW won't print via wireless:
I don't want to Accept this solution
Can you Help with these Printers problems?
SATO M-8485Se Thermal Label Printer Print...
printer gives print end all the time
Epson Stylus Pro 4000 InkJet Printer
How do I "change paper type", so that I am able...
Printers
i can't get my lexmark 3400 onto print mode, when i click...
Printers
printer cartridge mechanism clamp to hold cartridge in...
Printers
printer will not work,code#6400
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
