Question about SanDisk Sansa c200 MP3 Player
Won't turn on
When I press the power button, a batter icon appears and then it shuts off. Same result even after recharging the battery. Any ideas?
  • Anonymous May 22, 2008
    Need a battery
    Sergeant:
    Champion:
  • 209 Answers
How old is it ?
Well,
Try connecting it to your computer
Open My Computer and look for your mp3player's name/brand
If you cannot find the file try re-installing the software
If none of this works reply with more info
[it could be a battery or internal problem]
Good luck, please rate
Posted on May 09, 2008
Okay my sister had her tablet she turned it on and it froze at the go screen. So I pushed and held down. The power button and it turned off, and then I don't know why I pressed the reset button but it...
Do a factory reset. Remove all power including internal battery. Let the unit discharge completely. Plug into external power supply and try to start up. If it starts. shut down, put the external cord out , replace internal battery, and recharge for an hour. Now try a strat from the internal batter. If it fails, that s the problem.
Feb 03, 2015 | Tablets & eReaders
Battery has been charging to 100%. Suddenly would only charge to 76 percent. Now, after two weeks, will max at 62 percent. Computer is 1 year old. Can battery meter be recalibrated?
Pulled from Gateway's website:
Do not interrupt the battery recalibration process. If recalibration is interrupted, you must start the process over again.
  1. Close all open files and programs.
  2. Connect your notebook to AC power and allow the battery to completely charge.
  3. Disconnect the AC power and restart your notebook.Note: If the power cord plug.gif or battery baticon.gif icon does not appear on the taskbar, click the show hidden icons showhidden.gif button. If the icon still does not appear, verify thatAlways show icon on the taskbar is checked on the Power Options Properties Advanced tab.
  4. Completely discharge the battery by doing the following:
    1. From the desktop, right-click on the power icon, then select Adjust Power Properties.
    2. Click the Power Schemes tab.
    3. Click the arrow button to open the Power Schemes list, then click Always On.
    4. Click the Alarms tab.
    5. Click to remove the check mark from the Low battery alarm and Critical battery alarm checkboxes. Let the battery drain until your notebook automatically turns off.
  5. After the battery is completely drained, reconnect your notebook to AC power.
  6. Charge the battery completely until the yellow battery status indicator goes out.
  7. When you are ready to use your notebook again, do the following:
    5. Click to select the Low battery alarm and Critical battery alarm check boxes.
Mar 11, 2011 | Gateway Netbook N450
I have an Acer Aspire 4520 and the batter will not stay charged and it keeps shutting down even though I have it plugged in. Please help.
Hi there, please perform power drain first. Take out the battery and unplug the power adapter. Press and hold the power button for 30secs. Put the battery back in, plug in the power adapater then turn on the computer. If same issue will occur then you need to replace your battery.
May 16, 2010 | Computers & Internet
CAnon indicates low batery even it is full
Clean the battery holder with a pencil eraser, otherwise go for good brand rechargeable battery AA 2700 mAh try it.
Aug 25, 2009 | Canon PowerShot A590 IS Digital Camera
Change language to english
You have to reset your iPod. (Note: This is for the 3rd generation iPod Nano)
To reset iPod nano:
1 Toggle the Hold switch on and off (slide it to HOLD and then back again).
2 Press and hold the Menu and Center buttons for at least 6 seconds, until the Apple logo appears.
If iPod nano won’t turn on or respond
- Make sure the Hold switch isn’t set to HOLD.
- The iPod nano battery might need to be recharged. Connect iPod nano to your computer or to an Apple USB Power Adapter and let the battery recharge. Look for the lightning bolt icon on the iPod nano screen to verify that iPod nano is receiving a charge.
-Logan
Dec 22, 2008 | Apple iPod nano
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
My camera wont turn on
The likely problem is your batteries. Digital cameras need to run on rechargeable batteries, If you are already using rechargeables,have a look at tha mAh value which should be written on the side. Retailers recomend a value of at least 1800,personally i would go for 2100.
Mar 03, 2008 | Kodak EasyShare DX6340 Zoom Digital Camera
Model LXT 300 FRS/GMRS RADIO
There could be three (3) reasons why the display shows the battery icon at the top left side of the LCD display:
1. weak/undercharge/discharge batteries;
2. dirty/corroded/loose battery contacts/terminals; and/or
3. internal fault with the electronic sensing for battery level/state.
Corrective measures would require:
a. replace/recharge batteries. The rechargeable batteries need at least 12 hours of charging time;
b. clean, scrape, tighten (need to bend a little more towards the battery terminals) the spring/contacts of the battery holder;
c. (on the internal fault) your best bet might be to seek the services of a professional electronic technician since this would need familiarity with electronic components, their circuitry and diagnosis, perhaps a bit of soldering and the use of a DVM.
On the other hand, if the "low" is the "L" icon at the bottom right side of the display, this would indicate that the radio's transmit power setting (H/L - high/low). Transmit power level can only be changed in Channels 1-7 & 15-22. The radio will also auto change to lo power when batteries are weak.To switch to high power, press on the Menu button thrice or till "Pr" icon shows, press on the up/down to select H or L. To save & exit, momentary press the PTT.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 31, 2008 | Midland LXT303-A 2-Way Radio
Compaq Presario Laptop lost power
the battery charger board, is what I would swap first.
Good luck, keep us posted.
Nov 15, 2007 | Computers & Internet
SanDisk Sansa  c200 MP3 Player Logo
22 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
