Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
I want to open the file of my t.v because the screen size from left side is not adjusted correctly and I want to adjust it by opening the file. please tell me how can i open the file from the remote of my t.v. Model K-V14M70
  • 901 Answers
Service menu codes are known to the mfr and the service provider. By chance if you get it in the Google search, you can make use of.
But operating the service menu without noting down the settings, there are chances of in correct settings. this will lead to a worst condition.
Posted on Aug 31, 2010
Saw runs on idle but stalls when the throttle is opened up or trying to make a cut.
There are several things that can cause this. One is using gas that is too old. Another is that the mixture is too lean.
Oct 09, 2015 | Jonsered Tecomec Chainsaw Chain Sharpner...
How to change print paper size in tally
Hi'' first open the file you want to print or preview the file, as it open there is a word file on the left top of the screen , click left the file and you can see selection , click page setup then click paper and choose what paper do wish to use to print , just adjust width and height ,.
Aug 14, 2011 | Epson LX-300+ II Matrix Printer
HOW DO I CHANGE THE FONT SIZE. I WANA MAKE IT LARGER.
One way to adjust/set the default size (to get a larger font size) is through your Control Panel - Display - Settings window, where you can select a larger font.
If you are using a browser (e.g. Internet Explorer), there is way to increase (or decrease) the font size (displayed on the screen) using the "magnification" option at the bottom right corner of the screen. Simply click on the "magnifying glass" and increase/decrease the value, e.g. to 150% .
Jan 02, 2011 | Acer Aspire One PC Notebook
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
How can i get videos on my mp4
There's an online manual for COBY mp-c7095 in pdf format:
http://www.cobyusa.com/files/manuals/MPC7095_MN.pdf
1. Use the video conversion software from the CD for adjusting
video to correct size before transferring to the player.
2. Check the system requirements for video conversion on page 34.
The conversion software in zip format can be downloaded with this link:
http://www.cobyusa.com/files/software/MTVVideoConverter_Ver1.12.11.zip
Once video is converted u could use Windows Media Player 11 for
transfers. A short guide on WMP11 for putting files onto the device:
1. Have WMP11 always on top for "drag and drop" usage
Right click in the head of the WMP11 page:
in Tools > Options... > Player : select "Keep the player on top ..."
Restore Down the size of the WMP11 screen and adjust the size on the
edge(s) as you require for your screen.
2. in [Library] mode: under Playlists "Create Playlist" e.g. "My Playlist"
and Enter: "My Playlist" is added on the right screen side.
3. Open your data maps and ad files by drag and drop method
onto the right saying "Drag items here"
4. when ready adding files in [Library] mode: "Save Playlist"
5. in [Sync] mode drag e.g. "My Playlist" under the connected device
and "Start Sync": wait until al files have synchronized: a message
will show up when you can disconnect the player.
Sep 12, 2009 | Audio Players & Recorders
I haven't found a way to move files from my computer to my Sansa mp3 player every since I got a computer with Vista on it.
hi , what you need to do is when you connect the player to your computer open up this file and minimize it so its down the bottom by the start menu.
The open up my documents so you can see the files you want to move onto the player.
Now open up your player file this is what you minimzed if it didnt come up on its own you then need to goto
1 my computer
2 select the device from the list
this will then open up the the place where you want to put your files
adjust the size of this square so you can have this file open and your my documents file open.
You can adjust the size of each box by going to the very edge corned with your mouse hold down left mouse button then move to adjust the size
Now that you have both boxes open side by side what you need to do now is with the mouse select the file you want to move by pressing the left mouse button down and keep holding it down.
Whilst holding the mouse button down move the file into the other box witch is your player once you are in an empty space of this box let go of the mouse button then your computer will place a copy of the file you want to move into your players file.
I hope you can understand what i am saying it might take you a couple of goes to get it right but its easy enough.
If you have any problems then give me a shout back and then ill assist you further ok
Sorry about late reply but i live in uk and it was late when i replied to your post and have only just got back online hope this wasnt a problem.
Aug 17, 2009 | SanDisk Sansa m250 MP3 Player
Trunk won't open
Your rear hatch needs to be adjusted. There are two adjuster. One on right and left. They are black in color and are located just below the hatch lift support. Use the correct size torx/star screw head to adjust.
Jul 27, 2009 | 2000 Volkswagen Beetle
Delstar
the unit should come w/a mini cd of the current driver. if not, drivers are available for download online. windows 2000 and xp will automatically recognize 'new hardware' when you connect the unit to your computer's usb port. look for usb icon in the sys tray (lower right corner of your desktop) it shows that the unit has been found.
1. open 'my computer' and look for, nost likely, (E) drive. that is the delstar unit. leave the window open and adjust the window size to long and narrow.
2. open 'my documents' scroll to 'my music' or go to where ever your music files are stored. leave the window open and adjust the window size so that your two open windows are side by side.
3. simply right click a song file (.mp3), select 'copy.'
4. move your cursor to the (E) drive window. right click in the open area and click 'paste.'
-- simple as that!
Jan 12, 2008 | Delstar DS 31024 MP3 Player
Full screen on monitor
you can use the menu and adjust the vertical size.or if did already but it doesn't work,try to open your monitor and look for a trimmer in the vertical section,then try to rotate by these you can adjust now the vertical size
Oct 18, 2007 | HP Compaq FS7600 17" CRT Monitor
Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
159 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
