Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
My Canon DSLR 1000D will turn itself off (sleep mode) and then will not turn back on, even if I flick the switch off and back on. I have to remove and replace the battery and then turn it on in order for it to work. It also seems to be draining the battery life
Same to me, i dissembled it clean every circuit, upgrade firmware but problem not solve, i thing there is some defect in the electronics parts
Posted on Nov 18, 2010
When I try to take a picture I get an error 99 message. Shooting is not possible turn off power switch or remove battery
Hiyou have very common problem of canon dslr product. usually problem come from defective shutter unit. However, there is cause from lens also. Would you remove lens and push shutter button? if no error 99, then the problem come from lens---usually power diaphragm control fpc defective.If shows error 99, then you have body problem. At this point, still you have to check more. please set camera M mode and bulb shutter speed, you have to look front of camera if mirror goes up and show to you picture sensor. would you tell me more later. Thanks and best regard!
May 27, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
What does error 9 mean in a Canon 1000D DSLR camera ?
shooting is not possible turn the power switch to (off) and (on) again por re- install the battery.
Jan 23, 2011 | Canon Rebel XS / Eos 1000D Digital Camera...
Buying an SLR digital camera
Hard to tell, but I'd give a slight advantage to the Canon 1000D over the Nikon D60 (closest competitor) for 2 main reasons. The Canon has liveview which the D60 lacks and the Canon is largely backwards compatible with older Canon and third party lenses - so you can get good quality older lenses which will work perfectly with the 1000D. With Nikon on the other hand you need to either buy lenses with internal autofocus motors or you'll be stuck with only manual focus.
Besides that there's not really much difference, since both cameras produce great images and are very similar in features handling and price etc. To sum it all up - I suggest you go with the Canon.
Hope that helps with your decision.
Jul 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Will this Lens fit the Canon DSLR 1000D
Yes, it will fit Canon 1000D.
But I'll recommend you to try lens in a shop before buying - picture quality can be low.
Jun 24, 2010 | Rokinon 6502600 mm f816 for Canon
My Canon 1000D won't operate even when turned on. There is power somewhere because there is a lighted display in the viewfinder and it flashes busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My Canon Rebel xs 1000D won't operate even when turned on. There is power somewhere because there is a lighted display in the viewfinder and it flashes busy.
I can help you fix the BUSY Error on your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
Mar 08, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon rebel xs Battery and error 99 problems
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Cannot take picture
Check the switch on the side of the lens, it should be in "AF" not "M". The switch turns the motor in the lens on and off. If the switch is set to "M" the automatic mode on the camera will not work.
Mar 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
192 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
