Hello. I have a Samsung AA01 television and it is not turning on. Have tryed unplugging and turning back on but it seems to be dead. Any advise please? Tarsh
4 Suggested Answers
HDTV GURU
  • 261 Answers
SOURCE: Problem with HP-T4254 Samsung television model
I think you have to have something plugged into video inputs or RF INPUT for sound to work. Otherwise you get a blue screen and it says no input. or not available. Does this set have an off air HDTV tuner? IF it does, try hooking it up and see if you get sound then. Good luck and that should solve you problem. If not, reply back and we will continue with troubleshooting. Thank You Jay
Posted on Jan 31, 2008
freetek
  • 5568 Answers
SOURCE: No power on Westinghouse LTV-46w1 Television
This kind of failure is very common; that is why I suggest that one should keep the old CRT TV, buy a converter and put them both in the garage or basement so they are handy when our s*e*x*y new sets go belly up.
With fair confidence I can say that the main power supply has failed.
If you want to try this on your own, it only will require the removal of a few screws and a flashlight.
- Unplug the set overnight. - Remove the rear housing  - Use some logic and these tips; look for a separate board with larger than average parts on it and seems closer to the power cord than others. This will be the power supply.
Check the board over for something that looks like a part number and record it. If you find more than one, one of them will be the bare board number, the second (sometimes on a sticker instead of printed directly on the board) should be the part number for the assembly.
Search for the Westinghouse service company nearest you and call them with this info. Ask if they repair these or just sell new ones. If it is the latter, don't pitch the old one, continue to look for a repair service that will take it on after you have the new one in place and can watch your favorites again. The new supply will likely cost between $90 - $150 and with a little common sense, most anyone can remove and replace these in the set. Expect any repair to cost about the same as a new supply; US technical labor costs more than Chinese assembly labor.
These supplies can be as reliable as the primitive older type but companies refuse to use the high-grade components necessary to give them a long life so they fail much sooner than the old, less efficient kind known as 'linear' supplies.
Posted on Mar 22, 2009
  • 610 Answers
SOURCE: 32'' Samsung LCD HDTV - will not turn on
needs power supply board replaced. VERY common problem, can call 1-800-samsung for nearest service center.
Posted on Dec 29, 2009
Samsung TV LN46B530P7FXZA version AA01, ser num AUCU3CUS300985R,
Change the video board. It seems like it is blocking power. The relay signifies that power is working properly.
Nov 14, 2016 | Samsung Televison & Video
I have a un55c9000zfxza it powers up the screen glows but remains dark, I've got sound, controls seem to work, but no menu OSD
Problems can often occur with even relatively new Samsung LCD, LED Television. Some customers report their screen going black shortly after turning on the television, and flickering picture even though the TV's speakers continue to produce sound. You can test and rule out a number of things before concluding that your TV has a hardware defect.
First, check the input settings of your television. Often, users will experience a dark screen when first turning on their television if the selected input corresponds with a turned-off or unplugged input, such as a gaming system or DVD player. If the problem persists, try reconnecting all cables on the back or sides of the television. It's possible that one of your cables has gone dead. If you have access to other cables, try swapping these in and see if the problem persists. Some customers report that turning the television off and unplugging it for an extended period of time, up to 24 hours, can fix the black-screen issue. Samsung TV - Power Supply Issues If you've tried all of these suggestions and problems persist, it's possible that the power supply inside the television is defective or broken. The power supply for most Samsung LCD, LED televisions will cost around $150, with labor costs of around $250. Unless you have a fair amount of TV repair expertise, this is probably not the sort of repair you'd attempt yourself.
May 03, 2015 | Samsung Televison & Video
I have a Samsung HLP466w. The picture went black but still have sound. Lamp flashing and tv will not turn off, have to unplug. Help please!
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hoping this work out in solving the problem
Aug 09, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
My samsung LN32A330J1DXZA won't power on. please advise. just get a red light on the power button.
You have open the back cover of the television to check for bulged capacitors if found replaced with the same value, but if otherwise
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this help.....
Jun 07, 2010 | Samsung LN32A330 32 in. LCD TV
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
Dec 29, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Samsung hcn653w power surge
If the set went dead during a storm and will not power up at all, first try unplugging the set and waiting an hour or so, and then plug it back in to a working outlet and try turning it on. If the set still will not respond, your power supply has stopped working and should be serviced by a qualified tech familiar with Samsung projection sets.
Aug 24, 2007 | Samsung HCN653W 65" Rear Projection...
Televison & Video Logo
255 people viewed this question
Top Televison & Video Experts
Electro Med Services...
