Question about Hotpoint NWXR473EV Dryer
Hi , having had my house rewired . the main socket on the wall melted the plug off my tumble dyer and fused to the socket since then my hotpoint TDC62 won`t work . Is this repairable or am i looking to get a new one . thanks
    President:
  • 3,074 Answers
You can replace the outlet and plug on the dryer, more then likely it should still work. Hope this helped tim
Posted on Aug 31, 2010
My hotpoint aquarius wmf560 won't turn on no power since I moved it from my old house yesterday any ideas ???
sounds like a blown fuse or broken wire
cut back the wire by 6 inch and rewire plug replace with 13 amp good fuse
Dec 17, 2015 | Hotpoint Washing Machines
Tumble dyer catches the clothes
hi have good look for splits in drum had couple gone at back were heat enters
Mar 29, 2013 | Hotpoint Dryers
Tumble dryer blows main fuse
check fuse rate on dryer if same rate. check dryer for amps if pulling to many will blow fuse, if dryer is ok check from plug in to fuse.
Jul 29, 2012 | Hotpoint Dryers
Wd645 has no power to on/off switch. changed plug
Could be mains choke. Mains power comes into mahine via wall socket /worth checking this then onto mains filter/Choke..then to switch..So if no power here check this..wish you well
Oct 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Tumble dryer when switched on cuts power to all sockets in house
Hi.
Try it with the heater disconnected, you will find it at the rear of the m/c at the bottom left behind a removable panel.
You may have to remove the top cover and the right hand side panel looking at the m/c from the front. Try it again.
I fit does not trip. then your heater is faulty.
If it still trips then you are probably going to have to call en engineer
Nov 26, 2008 | Hotpoint NWXR473EV Dryer
Tumble dyer
first, you should check the exhaust system, make sure every inch of it is clean on the inside. if it is clogged, there is sensors that turn off your heating element as a safety measure. if this is clean, there is 2 heat sensors, one of them probably needs replaced.
Oct 28, 2008 | Dryers
My Hotpoint 960 is 18 months old and has develped a fault where the mains light and programmer display flicker simultaneously, and the machine cannot proceed through the programme. It does not respond to...
Flickering lights might just be caused by loose wires in the mains plug on the machine's power cable. I would suggest checking that first - for some reason the neutral wire seems more likely than the others to come loose. There might be brown / purple marks around the terminal inside the plug if this is the case. Also try replacing the mains fuse in the plug.
While you are there you might also try plugging a normal table lamp into the socket you use for the machine - if the house cabling to the socket is defective the lamp should flicker too.
If neither of these ideas is productive, the problem would appear to be within the machine, so please ask again. Good Luck D.
Jun 29, 2008 | Hotpoint Washing Machines
Hotpoint Aquarius Tumble Drier
there may be a short somewhere in the circuit, poss with the heater.
Feb 13, 2008 | Dryers
Dryers Logo
150 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
