Question about Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder
I have a panasonic DVD recorder model numberDMR EX75 with a fault U81
  • dorfet Aug 31, 2010
    Gday Leeth, been unplugged for over an hr and still the same. we had a power failure before it stopped? We can still play off the hdd but nothing else
    thanks dorf
    its 4 or 5 yrs old we brought it new I doubt it is still in warranty we will check the original documents. is there a fuse or something inside of it?
    thanks, Dorf
  • 4,472 Answers
How old is the unit? Have you tried unplugging it for a half hour and restarting the machine? This can be caused by many things this U81 error literally means 'Microprocessor Communication Error on the Universal asynchronous receiver/transmitter'
I would make sure the unit is in a well ventilated area. I would also contact panasonic if the problem persists and see what they can do as far as repairing/replacing the unit at little or no cost to you. I can get you their contact info if you give me your general location.
Thank you,
Lee
Posted on Aug 31, 2010
  • Lee A.
    Lee A. Aug 31, 2010
    and how long have you owned the unit? did you buy it new? if its under warranty have it repaired/replaced by panasonic. As this is definitely an internal defect and could have been caused by the power outage.
    Thanks,
    Lee
  • Lee A.
    Lee A. Aug 31, 2010
    Then it is definitely out of warranty. No this isn't a problem that is or would be fuse related. I would consider replacing the unit. Most likely the power supply internally needs to be repaired the the software reflashed although this isn't something you the consumer can do, it would take a qualified panasonic repair technician.
    Thank you,
    Lee
What does U81 mean
It could mean there is a fault on one of the circuit boards. See
http://www.avforums.com/threads/panasonic-dmr-ex75-85-u81-error-repaired-solved.1486954/
Aug 25, 2014 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
What does U81 Mean on my DMR-EX75
Just make it a factory reset. Refer its user manual for details. Unplug it from AC mains.
Jun 03, 2012 | Panasonic Televison & Video
U81 is permanently on the screen, I cant get the TV listing menu, nor can I get it to record, can you help?
U81 error literally means 'Microprocessor Communication Error on the Universal asynchronous receiver/transmitter'.
This error can be caused by a number of different reasons but one of the most common is a software / firmware problem relating to the Freeview part of the unit.
If you turn the unit off for 30 minutes it should reset the fault.
At this point to need to check what version of firmware you have installed and then check the Panasonic website for your country for the latest version.
Jul 02, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
The DVD player on my Panasonic DVD DMR-EX75 is not working. It no longer is able to read the DVD disk. Is it worth repairing or replacing the DVD drive? The system also has a large Hard Drive which still...
It is up to you, if you are able to obtain a replacement DVD drive for this model series, and it isn't too expensive, go ahead. There may be tips on installing the DVD deck on other forums - or it might be really simple (a DIY job) - or for extra labour costs, a qualified technician can fit it for you in a service centre.
So the short answer is YES it is worth repairing since the HDD is still functioning - if you are concerned about that as well as the DVD drive, get the whole unit assessed by a workshop; they can advise you further.
A second opinion always helps in a case like this, but I would recommend trying to obtain a replacement DVD drive for this model, either locally or by ordering online. This one IS fixable.
May 28, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
U81 error up Do I have to take it to a electrical repairer or is there anything i can do ?
I posted a suggestion a couple of months ago about a similar Panasonic DVD recorder (model DMR-EX78EB) with this exact problem:
This is one of several error codes generated by the main microprocessor IC which are tripped by corruption, preventing proper operation and which may require the processor to be reset (where practical) or replaced.
The U81 and U80 codes don't mean anything in particular because the corruption error(s) could be caused by a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error codes' in any device.
U81 means (in technical terms) 'microprocessor communication malfunction' on the universal asynchronous receiver/transmitter' or 'microprocessor feedback information error'.
This is not something the user should undertake to repair themselves; it should really go to an authorised Panasonic repair centre. The cost depends on the parts used and the labour, however, it is not unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
The DMR-EX series of models are prone to U81 - which is a common (and extremely irritating) error code. As I said, it is not unfixable, if you are prepared to spend a fair amount of money on the repairs by a qualified service technician in a fully equipped workshop with access to all the required components and service manuals.
Certainly worth investigating at least; and you should not need to purchase a new unit. Go with the quote first - then decide on a further course of action.
May 24, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
My DVD RECORDER MODEL NO DMR-EX75EB, THE CODE U81 KEEPS COMING UP WHEN I SWITCH ON MY RECORDER, ALSO I CANNOT GET INTO MY SETTINGS TO SEE IF I CAN FIX IT. THANK YOU
This seems to be a common fault with many Panasonic DVD recorders of the DMR-EX series.
This is one of several error codes generated by the main microprocessor IC in the unit which are tripped by corruption, preventing proper operation and which may require the processor to be reset (where practical) or replaced.
This is not something the user should undertake to repair themselves; it should really go to an authorised Panasonic repair centre. The cost depends on the parts used (if available) and the labour, however, it is not unfixable. You can always get a quote on this and a second opinion, then decide for yourself if it is economical or not.
I posted this 'advice' for this (and a couple of similar models) previously. The DMR-EX series of models are prone to U81 - which is a common (and extremely irritating) error code. As I said, it is not unfixable, if you are prepared to spend a fair amount of money on the repairs by a qualified service technician in a fully equipped workshop with access to all the required components and service manuals.
Because of the malfunction, the user settings and options are inaccessible, and there is no official user-reset option on this or any model of the series to clear this particular error.
Certainly worth investigating at least, as Panasonic usually make great products.
It's up to you as to what you decide to do from here.
Mar 28, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
DVD recorder DMR-EX78EB - Keeps showinf error message 'U81' on display. This means that it does not perform set recordings. What causes this please and how can we fix it as I am fed up with finding...
I posted this 'advice' for this (and a similar) model previously. The DMR-EX series of models are prone to U81 - which is a common (and extremely irritating) error code. As I said, it is not unfixable, if you are prepared to spend a fair amount of money on the repairs by a qualified service technician in a fully equipped workshop with access to all the required components and service manuals.
Certainly worth investigating at least.
Mar 24, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
My DMR EX75EB it fails to operate and a code of U81 comes up.
The U81 and U80 codes don't mean anything in particular because the corruption error could be caused by a number of different reasons. It does not point to any specific one fault. This is where the confusion sets in as to the origin of the 'error code' in any device.
I posted this 'advice' for this model previously. The DMR-EX75 and DMR-EX85 are prone to U81 - which is a common error code.
Mar 14, 2011 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Read failure o DVDs on Panasonic DMR-EX75
You need a lens cleaner to clean the lens of ur DVD recorder..
Dec 09, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Panasonic DMR-EX75EB-S DVD Recorder/HDD Recorder Logo
483 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
