How to remove my LG window AC's cover? - Heating & Cooling
  • 17,129 Answers
You will need to lift up the filter cover by lifting the grill door . Inside the grill is found the screws for fitting the front grill. removing the filter, remove screws of the grill inside will make the grill come off. Do not pull out but there is a latch on the top that the grill has to be lifted up and taken out. Some models have screws on side and must be taken out before the panel is pulled
Posted on Aug 31, 2010
Just want to remove front panel to clean
Anna, Normally front is not fastened with screws. In case, first check for any screws that could be holding cover in place and remove them. To remove front cover normally you push down on the top plastic frame which helps release clips, while pulling or pry cover off towards you, in the same area.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Clean Window Air Conditioner
LG LWHD1200R Owner Manual How To Remove The Front Grille
https://answers.yahoo.com/question/index?qid=20090815115103AAsYyOK
http://www.geeksonhome.com/how_6562969_clean-kenmore-window-unit-ac.html
Jun 19, 2016 | Heating & Cooling
PROBLEM ON START WINDOW AC
Lg have 5uf capacitor installed in outdoor section along with comoressor unit. It bascially helps to rotate the condenser fan.
Mar 15, 2014 | LG Electronic Window Air Conditioner
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Window air conditioner
I have neve done this my self but I have seen it friends expert in the ac field doin it the condenser with the lines are removable true the front of the unit just look for the screws attached to the outside cover and unscrew them all about 6 of them and just pull the inside of it and you can work with it as you please.
Aug 03, 2012 | LG LWHD1200FR Wall/Window Air Conditioner
How do i charge my lg bluetooth headset with AC charger. I cannot find an adapter insert on the headset.
HI. You will need to remove the concealment cover on the charging port before you can connect the charger. The cover is on the opposite side of the volume button. It will have the initials "PWR" on the cover. Pull that off to expose the charging port.
Aug 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Some discharge coil in window ac effectiveness is reduced.what mi
Clean the air filter. It can be removed and ran under water. If the coils are dirty take the window unit out side, remove the cover and house out the coils. Be careful and try not to get a lot of water into the switches. Make sure it's dried out really good before plugging it back in. The number one problem for A\C units is dirt.
Apr 19, 2010 | LG Heat cool Window Air Conditioner
How do i clean my window type aircon?do i need a technician or can i do it myself?
Yes you can do this . Remove this out the window, remove all the screws around the outside cover and lift off the 1-piece cover sides /top and start to clean .Also remove the cover on top of the back coil and clean this real good..
Dec 05, 2009 | LG Heat cool Window Air Conditioner
My a/c is trwonig cold water and air
The water is standing in the ac unit and not draining out.Is this a window unit?Ac on a car or truck?If it is a window unit for a house,remove ac unit from window,and take out side and if it is in a cover,remove the cover to expose the ac unit,and it`s components.Wash out the bottom of the unit to uncover all the drain holes.Get all debri out of unit.Replace the unit in the window at a good tilt(tilt it outward)so it can drain good,and not back up in your house with water.
Aug 29, 2009 | Heating & Cooling
Hitachi qudricool maintenance
ist open grill of window ac.there is two scrow outside the grill.after open grill u can pull ac from cover.
n.b.remove electric connection from voltage stabilizer
Mar 16, 2008 | Heating & Cooling
Heating & Cooling Logo
1,505 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
