Question about Car Audio & Video
I have a CKT-D59 head unit from my my 1996 Toyota Aristo,and was just wanting to know what the wiring colours are?eg.power,const,neg,speakers.etc
Benimur
  • 6966 Answers
SOURCE: speaker wiring for a 1993 dodge dakota
To my knowledge a 1993 Dodge Dakota would have the below wiring arrangements for its stereo/head unit:
Constant 12V+ Red/Blue
Switched 12V+ Red/White
Ground Chassis
Illumination Black/Yellow
Dimmer Orange
Left Front (+) Dark Green
Left Front (-) Blue/Orange
Right Front (+) Purple/White
Right Front (-) Brown/Blue
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Red
Right Rear (+) Blue/White
Right Rear (-) Blue/Red
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 18, 2008
  • 373 Answers
SOURCE: I need the colour wire
HI.
In the caravan are 2 types of Radio.
1. Normal sound system.
1 Premium sound system.
Note: If you don't want to cut the original wires,
You can buy a harness connector to install the aftermarket Radio. The connector are made by aplication, and are plug in.
The colour of the connector are the same colour with the Aftermarket Radio. Just you need to soldering or just put joint connectors.
Normal: colour of wires.
Pink = Battery voltage.
Red/withe = Ingnition Voltage.
Brown/red and Dark green. = Left front speaker.
Dark bku/red and Voilet = right front speaker.
Brown light blue and brown/yellow. = left rear speaker.
Dark blue/orange and dark blue white = right rear speaker.
Ground is a single wire behind the radio.
If you have a premium sound. You need to use the front speaker out to connect the speaker on the door and the speaker on the dash. To complete the 6 speaker.
OK... I hope this information work for you.
Thank you , For use fixya. Rate please.
Posted on Jul 17, 2008
jamesmac
  • 71 Answers
SOURCE: wiring on back of head unit
You don't need to change the cables from the head unit on.  Just strip of the end of the wires where the old speakers are and crimp on the proper connectors to connect them.  Alternatively you can just solder the wires directly to the speakers.  I always **** splice at least 6" of wires onto the end so you have more wire to work.  The only reason you would change the wires would be because you are putting more than 200 watts per channel.  You didn't speak of an amp so no worries.
James Mac
Posted on Sep 09, 2008
  • 27 Answers
SOURCE: neg and a pos on each side of car speakers
Depends on your amp. If they are dual 4 and your amp is 1 ohm stable and you have 2 subs, wire red to red and then red to plus on the amp. If your amp isnt 1 ohm stable wire ch1 red to + on amp, ch1 black to ch2 red, then ch 2 black to - on amp. If this sounds like french to you, go to a stereo shop in your area and pay them to hook up your stuff. It will be a lot cheaper than buying a new amp and subs.
Posted on Dec 18, 2008
  • 276 Answers
SOURCE: i am trying to install
usually are given color-pair is green with black and without rallita rallita that's a couple to connect a speaker
Posted on Nov 25, 2010
1991 toyota carolla seca cs limited head unit wiring colour codes
Radio Constant 12V+ Wire: Blue/Yellow
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Purple
Right Front Speaker Wire (-): Light Green
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
May 25, 2012 | 1991 Toyota Corolla
I need to wire my sony cd player into my fiat cinquencento but I have no idea how to wire it in I just spent 23 on a wire for the stereo an it only cost me a tenner for the actual stereo I dont want to...
most car stereos are simple to wire, especially sony!
Main power cable colours are:..
RED = LIVE (+)
BLACK = NEGATIVE (-)
YELLOW = MEMORY/SWITCH LIVE it will be next to the red and black cables
ORANGE AND WHITE = ELECTRIC ARIAL (IF FITTED)
BLUE = REMOTE WIRE (FOR AMP CONTROL IF USING)
You should now be left with a couple of audio out jacks and speaker cables,
the speaker cables are straightforward, most have a twin, ...E.G if you have a grey wire, this should be next to a grey and white (or grey and black, depends on model) wich is classed as its PAIR/TWIN.............
an so forth,...green, purple, white, brown.....ect ect
each colour havin a twin as stated ealier!! (they are twinned, as the solid colour is usually the negative speaker, and the solid colour with a stripe through it is usually the posative speaker connection (eg..single solid colour is (-)...and...solid colour with stripe is posetive (+)...)
Apr 30, 2011 | Car Audio & Video
I want to install it in my 1998 dodge ram but i dont know where to begin. i need step by step help with parts i would need.
hi well it is a long process but i hope this will help you, tools you will need are 1x Philips screw driver ( cross head screw driver ) 1x 10mm socket and driver 2x original security keys ( if required! ) first thing to do is make sure you have all the parts for your radio that are needed these should be supplied with the system but here is a check list of what you need to fit it this will also depend on how you will mount it in the dash also, some car radio stores have power adaptors specifically for certain types of audio equipment to vehicle power plug, ie, they should have a lead that will plug into the plug from your vehicle into the plug for the audio unit..would be worth having an ask before you start cutting plugs off of things first and would cost only a few bucks, not only that it saves all the wiring up from one thing to another and also if you sell your truck, you can just plug original radio back in just a tip.... 1x security cage 2x security keys 1x power plug lead 1x aerial adaptor ok, to remove the original radio Open up the power outlet door and locate and remove one (1) Phillips head screw using your Phillips screwdriver . Set screw aside. Open up both the cup holder door and the ashtray door, remove the bezel that surrounds the radio and climate control and extends across the instrument cluster,To do this, grasp the bezel with your hands on the bottom right side of bezel just above the cup holder door pulling toward you to release a series of clips. Once released, work the remaining clips loose by pulling toward you all the way around the bezel. There are a total of fourteen (14) clips. When the bezel is loose disconnect the wiring harness to the power outlet and set bezel aside. Using a 10mm socket & driver locate one of the (1) screws below and to the left of the radio holding the radio in place. Remove that screw and set it aside.do the same with the screw on the top right, remove this and set aside, gently grasp the bottom of the radio and pull towards you (note!!! some may have a security cage already fitted if so, make sure you have the keys handy to remove it ), once in the correct position you can then access the rear plugs and areal, disconnect them from the radio, and set the radio aside ok that's the easy bit done, now the hard bit starts...... Pull all the plugs out of the old radio recess ( don't pull so hard as to brake them though, just enough to work with if you do not have the plug to plug adaptor ) you should have 2 or 3 plugs depends on if you have tweeters in your truck, the main power plug should have these wires on it as you look at the plug from the front ( where it plugs into the old radio ) from left to right brown/red = left front speaker - neg dark blue/red = right front speaker - neg black/yellow = day sensor orange = dimmer red/white = fuse power ignition pink = fuse box + pos violet/brown = ccd bus + pos white/black = ccd bus - neg light green = choke relay brown/yellow = left rear speaker + pos dark blue/white = right rear speaker + pos dark green = left front speaker + pos violet = right front speaker + pos brown/light blue = left rear speaker - neg dark blue/orange = right rear speaker - neg black/dark blue = ground - neg ok, that's that done, first things first, make sure you put the security cage in before we go any further, as if you connect the wires so they are permanently connected you will have to undo all your hard work and start again, so now that's out the way now we have what the colour ( i am from uk lol colour ) wires are for what things, time to connect them to the stereo plug, you can either cut the plugs and directly wire to wire, solder them, or just twist and tape them, i personally am a perfectionist and would solder them and use shrink covers on them, or just get plug to plug adaptor..ok here we go, the main power wires are the most important, obviously we need power to the system, and also we need to keep the programmed stations once done, so here is the wire to wire connections you need to do from your old plug to the new stereo plug ( as i said its up to you how you do them ) ok..... you need the constant power ( memory for the set stations and other stuff ) and an ignition power and also a good earth/negative
this will be as follows
Pink ( old plug ) to Yellow ( new plug ) constant power or memory as it is known. Red/White ( old plug ) to Red ( new plug ) Ignition power ( when ignition is turned on ) Orange (old plug ) to Orange/white ( new plug ) Dimmer ( when dash is dimmed if to bright ) Black/Dark blue (old plug ) should be left as is no need to touch, Black ( new plug ) this should be attached to a clean metal area as this is the main earth to chassis.
ok that's the power sorted, it should now be able to switch on and off and remember programmed stations.ok now to the speakers...check the other plugs for these wires these are as follows
violet right front speaker pos+ (old) to Grey ( new ) dark Green left front speaker pos+ (old) to White (new) dark blue/white right rear speaker pos + (old) to Purple (new) brown/yellow left rear speaker pos + (old) to Green (new) brown/red left front speaker neg - (old) to White/black (new) dark blue/red right front speaker neg - (old) to Grey/Black (new)
and that's that...the new stereo does not have provisions for 6 speakers unless you are transferring it through an amp, this is the basic 4 speaker set up, there may be more wires for other speakers on the power plug from the new stereo, and these might go to the other speakers if you have them, you will also have other wires on the new plug, like parking sensor wire, this is connected to the hand brake/parking brake wire, and electric areal wire etc etc, these will have labels on them to tell you what they are for, you do not have these with the old plug, and some of them you will not need to use, that will be up to you on what you will be adding, like amp's, TV/DVB receivers, multi disc CD changer etc etc...well i hope this has helped you, its taken ages to write.....good luck, please comment and rate thanks
Feb 02, 2011 | Kenwood KVT-617DVD Car DVD Player
I need to know wat colours do wat on a kenwood KVT-739 car Stereo DVD player wiring
yellow - constant power, red - switched or ignition power black - ground white - left front speaker pos. white/black stripe - left front speaker neg gray - right front spkr pos gray/black stripe right front spkr neg green - left rear spkr pos green/black stripe - left rear spkr neg purple - right rear spkr pos purple/black stripe - right rear spkr neg blue - power antenna remote blue/white stripe - amplifer remote turn on
Aug 16, 2010 | Kenwood Car Audio & Video
I turn the unit on and it works for about a minute then powers down. The red light stays on. If I hit power button again it works but for less than a minute and it powers down again. Any suggestions?
try to check speaker wiring connection for possible short ckt. also check speaker itself, this amplifier have protection ckt that make unit off soon as short ckt detected.
Apr 13, 2010 | Aiwa AV-D67 Receiver
Request for the wiring diagram for a 1989 UK spec Toyota Corolla Hatchback
Sure. Glad to provide assistance.
89 Corolla radio wiring colours:
Power- Solid GREY -
from the 7.5 amp RADIO fuse
Backup power - BLUE w/YELLOW tracer
from the 10 amp DOME fuse
RF speaker - LIGHT GREEN and BLUE
LF speaker - PINK and VIOLET
RR speaker - RED and WHITE
LR speaker - BLACK and YELLOW
Ground/Earth - BROWN
The graciousness of a FixYa rating would be greatly appreciated.
Jan 19, 2009 | 1989 Toyota Corolla 2 Door
Car stereo wire diagram for 88 toyota tercel
1988 toyota tercel sedan as follows
pink = (+) pos. for left front speaker
violet = (-) neg for left front speaker
light green = (+) pos. for right front speaker
blue = (-) neg for right front speaker
blue/yellow = (+) pos at all times (power)
grey = (+) pos. only in the accessory or run position
brown = (-) neg gound
red = (+) pos. right rear speaker
black = (+) pos. left rear speaker
white = (-) neg right rear speaker
yellow = (-) neg left rear speaker
verified at 2 resources . fixya
Dec 26, 2008 | 1988 Toyota MR2
Car radio harness colour code
work it out with a meter ,,,,find perm 12v feed neg and pos ---yes could be any coloured wire depending on car maker,after finding perm 12v feed for memory look for pos from ign switch,now speaker wires are easy as both will be same colour for a speaker but one will have a band through it if not sure or colour blind like yours truelly then use pos and neg on speaker wire till you hear a thump from speaker then you know you have the right wires and location of speaker ,,ie.. front left back right ect ....Now you are a fully experianced radio fitter ??
Dec 20, 2008 | 1993 Nissan Maxima
Colour code for speaker wires.dont know + from -
I am guessing the cable is figure 8 two cores attached to form a single cable. The core with the line down it is very often the - and the plain the + however it is irrelevant, as long as the cable that is connected to the source, CD, or whatever, the colour that goes to + there, must go to + at the speaker terminals, likewise the - must be connected in the same way neg to neg. This follows for ALL the speakers connected to the system as if you get a pos+ connected to a neg- it will cause the speakers to be "Out of Phase" and could cause sound distortion. Rule of thumb, without any stripes or line black, is usually negative -
Feb 10, 2018 | 2003 BMW M3
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
