Question about Samsung Televison & Video
HELLO, I HAVE 50" SAMSUNG PLASMA THAT WHEN I TRY TO TURN IT ON THERE IS NO PICT BUT THE SOUND WILL CAME ON SOMETIME THE MODEL # IS HPS5053X/XAA NEED TO KNOW WHAT PART I NEED THANK YOU?
  • 1 more comment
  • aimed_sayid Aug 31, 2010
    hello, i am still not 100% sure what part is bed, can't you tell me what part is relly bed that need to be change it thank you
    will, no i don't think that the advice i received was insufficient ,but i need to know what is the relly part that is bed is it the y sys or power board or something elsa, the problem with the tv is when i turn it on the light will came on, sound will cam on, but no picture and the screen will not turn on i ment the screen light thank you,
    will i try volume and up down channel now no sound no pict when try to turn it on it will make that kelk nose like if turning it on so what you thaink it will be the sus board or logic control board thank, you.
  • 712 Answers
This problem is a widespread one with Plasma T.Vs . 6 screws that attach the inverter board to the gray metal bottom loosen over time, causing the TV to periodically lose video while retaining audio. (Sometimes turning the TV off and on restores video, sometimes not). The problem gradually gets worse making the TV unusable.
The best solution for most TV owners is to contact Customer Service to send someone out to fix this problem free of charge and it might take some pressure and a number of calls to get this outcome.
If you decide to fix the TV yourself the good news is that there are no parts to buy and the fix is easy and quick, . The bad news is that disassembling/reassembling the TV is neither easy nor quick. The following instructions, however, should help make your disassembly/reassembly much easier.
My first advice is to obtain a copy of the Service Manual.The different steps of disassembly are:
1) Stand Assembly
2) Back Cabinet Assembly
3) Angle Back Assembly
4) Cover Assembly
5) Bottom with Inverter Board
Disassembly Instructions
Lay the TV face down on a table covered with soft material.
1) Stand Disassembly
Remove the 4 screws holding the stand on with a hex driver. Remove the stand.
2) Back Cabinet Disassembly
Using a screwdriver (preferably magnetized), remove the 16(?) screws around the edge of the back cover molded into the cover. Remove and keep separate the two screws in the center of the back cover (a different size). Remove and keep separate the screw holding the on/off button unit (different size). Lift off and remove the back cover.
3) Angle Back Disassembly
Next you need to remove angle backs 1 and 2. The angle backs are the metal parts that support the stand and run down the middle of the TV. Each is labeled with a stamp in its metal. Remove both angle backs.
4) Cover Disassembly
This is the most challenging disassembly step. Loosen but don't remove the four screws that hold in the side spring clips. Remove the eight silver-topped screws that hold the cover down. Remove the 2 screws holding down the on/off button unit and remove the unit itself. This exposes a screw coming in from the side. Remove it and the 3 other screws coming from the side, 2 on top and 2 on the bottom.
The cover should now be free, but it cannot be removed without undoing some connections. Remove or cut the tape on the top side middle that seals the cover to the TV. The wires to the bottom left speaker must be disconnected. Pull out the plug connecter. Slide off the red and blue wires by depressing the little metal tab that locks them in. There are two ribbon connections in the middle of the cover that also must be disconnected and pushed down through the metal in the cover. One requires that you cut the cable tie that connects it to a black plastic ring. Pull it off gently and slide it down. The other is very thin but also pulls off. Now the cover can be lifted off and moved about 8 inches to the right.
Once the cover is removed, on the left side you can see the metal cover of the inverter board and the six screws holding it down, the very screws that we have been looking for! Remove the six screws and the metal cover. Without disconnecting any of its connections, rotate the inverter board up and to the left to expose the bottom of the inverter board as well as the gray metal bottom of the TV to which the inverter board is attached and grounded. Note the 3 copper rectangles on the bottom of the inverter board surrounding the 3 screw holes away from the left edge towards the middle of the TV. These are the grounding strips that lose their connection.
Using contact cleaner clean off any black burn marks from these connectors. Also clean all black marks from the metal bottom that they contact. Clean carefully and thoroughly. You might need to scrape lightly to remove all marks.
Rotate the inverter board back in place. Line up the metal inverter board cover. You can either use the 6 existing screws or purchase replacement screws. Using a removable thread locker coat the screw threads of one screw. Tightly screw in the middle edge screw first. Follow this by the edge top and bottom screws, then the middle inner screw, and finally the top and bottom inner screws, using the threadlocker on all 6 screws. Verify that all screws are tight.
6) Reassembly
Reassembly is the reverse of disassembly with the advantage that you have been there once before. As long as you have kept all your parts separated and follow the exploded view diagrams of your manual, it should be easier and quicker than the disassembly. Remember to reconnect all the connections that you disconnected.Be sure that all screws return to their proper places.
Now you will discover that the problem is fixed. Enjoy watching the T.V.
Best Regards. Thank You.
Posted on Sep 01, 2010
  • 4,889 Answers
The source of your problem is most likely to be the sustain boards and or the logic control board. Do all of the other functions work? Try volume/up down Channel +/- etc., and let me know.
Posted on Aug 31, 2010
  • Samsung Master
  • 11,800 Answers
Most likely the fault is located either in the power source (the capacitors have aged and failed) or the Y-sus board (the ic's have failed). You need to open the tv and test it to locate the faulty part - start by checking the voltages on the power source. When you are absolutely sure of the defective board and you can't fix it, only then replace it in its entirety.
  • Azrael SRL Aug 31, 2010
    The Y-SUS board is the one that generates the light. That board is powered by the power source board. You need to check if the power board sends the correct voltage to the Y-sus board. If it is then the Y-SUS board is defective and must be replaced. If it doesn't you need to find out why - it's either because the power board is faulty and you must replace it or it's because the th Y-SUS board is shorted badly (completely dead) and it blocks the source.
    You must make these tests. Or you can just replace both boards.
  • Azrael SRL Sep 01, 2010
    Since the tv tries to start but it fails it's more likely it's the Y-sus board.
Technical support
Probably power supply failure that requires more than replacement of a capacitor to correct
Jul 26, 2016 | Samsung 50 in. Plasma TV
I have a Samsung plasma tv model HPS5053X/XAA. The picture turns to multicolored vertical lines then goes out. A few minutes later it comes back on then repeats the problem. If I'm right, it's the logic...
Check all the COF [Chip On Film] connections for any loose contact with its sockets. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 21, 2014 | Samsung Televison & Video
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
My samsung tv model hps5053x/xaa is not finding my laptop via hdmi. i have been using it this way and then all of a sudden it isnt recognizing it now. what do i do what is the issue?
have a samsung plasma model HPS5053X/XAA i have it for less" -- because it falls within my area of expertise. I just need a few more details about your situation and I will get to work!
Jan 05, 2011 | Samsung HP-S5053 Television
Intermittantly there is a black rectangular box that appears on the screen for a few seconds then goes away. Our set is 4 years old. Kris 317-201-6643
Turn off close caption in tv, need to go to menu to turn off close caption function, that will solve your black rectangular box problem.
Aug 29, 2010 | SunBriteTV 2300HD 23" TV
Top half of screen going black.
I've seen this or something similar to this problem on an old lcd screen. The bulb haden't burned out but the system was no longer getting proper 5 volts to the processor chip that processed the image. I ended up desoldering the voltage regulator and soldering a new regulator in it's place it was one with the same amperage so I put a heatsink on it to reduce the chance of another failure.
Feb 16, 2009 | Samsung HP-S5053 Television
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
Televison & Video Logo
258 people viewed this question
Henry  Thomas
Henry Thomas
