I purchased a 1994 5th wheel with a Coleman air conditioner. It had been covered and in storage for 3 years. When I turn on the thermostat, it sounds like its trying to work but quits after a minute or two. I cleaned the filter and I can hear a gurgling sound (maybe coolent?). I'm not sure what to do next. Can you help with any suggestions? Thanks. Lynne PS The furnace uses the same thermostat and it works fine.
  • 172 Answers
Hi roblynne,
It sounds like you may have a fan motor stuck or obstructed. After sitting for awhile the motor can get stuck and it may need some help to free up. If you turn it some by hand it may just start working. Do not have the power on and start the fan, you may just get a nip. good luck and I hope this will FIXYA.
Mike Anderson
Posted on May 09, 2008
  • 828 Answers
You may have a power supply problem. If you are connected to an external power supply with a cord, make sure it is able to carry the necessary power. To small a cord will cause a voltage drop giving insufficient voltage to run the compressor. The noise you hear is the refrigerant pressure equalizing in the system after the compressor shuts down.
My coleman mach air conditioner won't turn off by the controller. I have to turn the circuit breaker off to get it to stay off. The controller works with the heater just fine. What could this be?
Sounds like the contactor that controls the compressor and fan is sticking. You will have to remove the top cover to get to it. It will probably be in a box after you remove the cover. Turn the power off and see if it is still pulled in. If you can get it unstuck then it may work, otherwise you will need a new one.
Aug 29, 2010 | Coleman Mach III Air Conditioner
Compressor will not cut off
Turn power off, remover electrical cover and disconnect the wires that go to thermostat, sounds like bad thermostat control
Jun 22, 2010 | Dometic Rooftop RV Air Conditioner
We have a Mach III coleman AC unit... a little
Sounds like the evap coil is dirty or its low on freon.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
Coleman mach chill grill - heat turns on whether we have it programed or not. have heat off, ''I feel'' off, can be 80 outside we can be gone and come back to 110 degrees inside and heater on. When it...
Sounds like you have a bad thermostat or a short in the wiring. The clicking that you are hearing in the ceiling is a relay in the control board. When this happens, remove the face plate from the thermostat and check for 12VDC between the Blue and the White wires. If there is power then you have a bad thermostat. If there is not power there, then the problem is elsewhere. However, it sounds as if you have a bad thermostat.
Jun 03, 2009 | Coleman Mach 15 Air Conditioner
Problem with heat pump
This sounds like a 4--step furnace. Step 1 ,the small ven fan turns on and proves it turnning thru the small air tube that sucks a switch close . Step 2 the spark igniter lights the pilot ...Step 3, the main gas valve opens up and dump gas in the venture tubes to heat the box up, Step 4 theres a swith in the box the when heated closes and turn the fan on! Thank-you-very-much!
Aug 18, 2008 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
