Question about Altec Lansing ATP 5 Computer Speakers
I got Altec Lansing ATP5 spearker. Two of my satellites are not producing sound, including directly connected satellite with heavy din cable .However all controls are working fine placed on same satellite.
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
Posted on Jun 22, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
Altec lansing acs33
the subwoofer plugs into the wall on a 110 volt outlet. then use mastervolume control.. RANDY
Apr 28, 2014 | Altec Lansing Multimedia Computer Speakers
Where im going to find connectors of atp3
Altec Lansing ATP 3 has 7 pin mini-DIN connector for Right Satellite. You will find that at electronic hardware store. WebRepOverall ratingThis site has no rating(not enough votes)
Sep 19, 2012 | Altec Lansing ATP 3W Computer Speakers
My speakers only the bass when i hook them up i hear the bass but not the sound please help
It sounds like you have subwoofer system that requires satellite speakers for the high frequencies. If you have these satellite speakers, but are getting no sound, either you have connected them incorrectly, or there is a problem with the amplifier that drives the satellites.
Oct 06, 2010 | Altec Lansing 121i Computer Speakers
I need to figure out how to open up the subwoofer for the Altec Lansing vs2121 model. Thank you
theres no on/off button for the subwoofer. once you plugged in the power cable,turn on the speaker system by turning the VOLUME knob on the right satellite until you hear a click sound.
An LED will light on the front of the right satellite when the power is ON. if you still dont hear any sound from the sub woofer then check to make sure that all cables are connected properly and are making a clear connection.
hope this help
Sep 06, 2010 | Altec Lansing VS2121 Computer Speakers
My altec lansing ATP3 right satellite speaker cannot operate...
Speaker is bad or the cable may have come loose. Has it been knocked around? If so it may have pulled the cable loose inside the speaker, try playing a song and wiggle the wire and push the wire in gently to see if it starts to play if it does you have found your problem. If not then the speaker is bad and I don't remember if you can pull it apart and buy a new speaker to install in it. Thanks for using Fix-ya and if this helps please rate this free question.
Avid101
Aug 20, 2009 | Altec Lansing ATP 3W Computer Speakers
No sound coming from ACS 48 Altec Lansing speakers
Hi janros123 - I don't know if this will help - I have a subwoofer ACS48 that needs satellite speakers (they are blown). Want to buy my subwoofer or sell your satellites? I will buy your broken subwoofer, too...thanks, and good luck! Greg illdooyoo at gmail dot com
May 16, 2009 | Audio Players & Recorders
No Power (LED off) in the Altec Lansing VS4121
There is no way to open the satellite speaker without destroying it. I tried and found that the whole thing was glued together. Mine is now destroyed
Apr 15, 2008 | Altec Lansing VS4121 Speaker
Altec Lansing CS-21
Sounds like a bad connection, i wouldnt even try and repair it i would just return them for a replacement. Could be a bad solder connection inside or the cable.
Apr 13, 2006 | Altec Lansing CS21 Computer Speakers
Altec Lansing ATP 5 Computer Speakers Logo
162 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
