Question about Spectra Logic Hello Kitty 13" TV
Av black and white
Tv is colour and clear but when you change to av it only plays in black and white on pal and auto
  • boof head May 09, 2008
    only had them for 5months hello kitty dvd player works fine on another tv and differend dvd works on hello kitty tele.
  • kahvazadeh Apr 29, 2009
    I have had my 13" Hello Kitty TV/DVD for about two years now, last year all of a sudden the DVD stopped working properly. When I would switch to the DVD setting it would play only in black and white. I have been using a external DVD player in order to watch DVDs on the TV.
    However, now I want to sell the Hello kitty TV and would like to fix the problem. Does anyone know if this problem is fixable and also if it is would it coast a lot to fix it.
    Thank you so much
    Genius:
  • 1,139 Answers
Hello boof head,
I got good news and bad news for you. The Hello Kitty TV set uses a Mitsubishi chassis 0707-A20390-00 which employs a single main processor for major systems functions (one of which is color for the AV Composite Video input signal and the Audio input signal. It looks like in your case the processor is bad (IC203). This processor is the sole input for your video signal . The schematic I am looking at shows that from the AV input the signal goes straight to the processor. This processor is tricky because when it goes bad it looks like it could be something else because other devices plugged into the port sometimes works, and misleads folks into thinking that the TV is ok when it is a case of the signal being "hot" enough to leak over into other sections of the chip and causing it to look as though it's working. I would  suggest taking the TV to a qualified repair shop. Now if you don't want to do that you could check the cables and make sure the signal is good going into the AV ports. However that is about the extent you will be able to work on this Tv because of the way it is designed.
I hope this helps
Thank you,
Shuttle83
Posted on May 23, 2008
  • 3 Answers
Please don't take this as me doubting your intelligence, but are you sure your wires are good? sometimes they can become worn out inside of the protective rubber, and partially fail.
Also, how old is the TV? I just got one (for free so i can't complain) from a friend that will start in color on av and then turn to black and white because something inside of it went bad..
Posted on May 09, 2008
New tv.. no colour when playing ps3
Hi, check the setting of the TV, where you can see TV display and you will see two or three option of changing the TV mode(NTSC and PAL).it still on NTSC that is while it is sowing black and white. Switch it to PAL it will start showing co lour screen for you to enjoy the game.
Take care.
May 05, 2010 | Sony Playstation 3 (PS3) Console
My disney TV / dvd player will only play in black and white, the colour settings are set to disolay colour
PLS. seting tv in colour sys [exmp. PAL /NTSC/ SCEAM] so
set your colour system is AUTO . the set all colour system automatcly.
Oct 08, 2009 | Disney CARS 14 TV/DVD Combo
A/V in black and white
good day,
what video device do you plug in to your TV screen, DVD player/VCR or game console?
If you still have the owners manual of your TV screen, look for instruction regarding Color system or video system. this menu will allow you to change color sytem from PAL to NTSC or AUTO system.
most likely the reason why you have a black and white color from vidoe input is because of system color compatibilty from your input device to your screen.
Or if your using a dvd player, you can also try accessing the "setup" button and look for video setting. from the video setting there will be selection to choose from: PAL , NTSC, AUTO . always select "auto"
so that the color system of your DVD player can change from PAL to NTSC deffending on your TV screen system setup.
cheers,
mark
Feb 01, 2009 | Sanyo Over-the-Ear Sleek Boom Microphone...
Nintendo 64.black and white picture
In order to play a different region game on a different region TV (example playing a PAL game on a NTSC tv) your tv needs to be automatic enabled. Some tv's have an option on the remote to change the input signal to PAL NTSC or SECAM. If your tv does not have that then there is literally nothing you can do apart from get a different tv with this feature.
Dec 25, 2008 | Nintendo 64 Console
Play back is in black and white
Set your TV in auto mode or according with your CAM system PAL or NTSC and some of the CAM you can set for AV out in PAL or NTSC system
Cheers
Nov 03, 2008 | Sony Handycam CCD-TRV308 Camcorder
Black and white
hey friend
It's Format Problam.. yr Country Standard Format is May Be PAL so when u play NTSC cd/dvd output is black and whight you have to change setting video format to AUTO and also chek yr pricute colour sillaction is set as AUTO..
Thaks for usig Fixya
Jo_Chimay.....:)
Mar 31, 2008 | Yamaha DVR-S150 DVD Player
DVD player will only play in black and white
are you using a/v inputs or composite inputs .
Mar 27, 2008 | Disney Princess TV/DVD Combo
Original DVD plays black and white
It seems that you have get the color system setting of your Tv wrong. Sony uses the Pal(it's a format for the transmission of signals) color system , so check into your TV's color system settings and change it to pal , if that doesnt work then change it to Ntsc.
Aug 18, 2007 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Bush DVD2055HDB HDMI DVD Player.
the PN onremote to tv set this is all about the system on tv ie pal is always for colour , and auto is always determined by the tv this si automatical set by tv depending on in coming siginal ie from advd machine. NTSC is always afaded colour some times it may appear as black and white
Jul 29, 2007 | Bush DVD2038 DVD Player
Spectra Logic Hello Kitty 13" TV Logo
585 people viewed this question
Top Spectra Logic Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Spectra Logic Televison and Video Expert? Answer questions, earn points and help others
