Question about Logitech ClearChat Stereo Headset Headset
Are the plugs supplied all that is necessary to connect to my computer
  • Logitech Master
  • 11,800 Answers
Yes, it will be automatically detected as just another headphone/mic set.
Posted on Aug 31, 2010
Why does my computer say no imput signal
If you have used a desktop computer or have a dual-monitor setup, you have likely seen the "No-input Signal" error message on your computer monitor. The error message may point to a number of culprits. Accordingly, the solutions run from simple to complex. Prior to attempting advanced troubleshooting methods, check the connection first. Power off the computer and the monitor. Remove the cable that connects the monitor with the computer, then reseat it. Try a different port, if possible, then reboot the computer.
Connect the monitor to another computer if possible to eliminate the monitor as the faulty hardware. Shut down the computer. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove all cables and devices plugged into the computer. Make a note of the port into which your monitor is plugged. Remove the left side panel when facing the front of the case. Unscrew screws or manipulate latches to remove the side panel. This process varies according to the type of case you have. Please consult your manual if you are unsure of how to remove the side panel. Attach the antistatic wrist bracelet's clip to a metal object, then ******** the bracelet. Locate your video card. (This will be the card that contains the port with which your monitor interfaces.) Remove the slot cover screw that secures the card into the slot. Remove any power cables that connect the video card to the power supply. Pull the card out of the slot. Examine the gold pins to check for any damage. Reseat the card if it physically appears to be undamaged. You should hear a click once the card is secure in the slot. Screw in the slot cover screw. Attach the power cable from the power supply unit, if applicable. Leave the case open for now. Reconnect only the monitor, power cable and any devices required to boot the computer, then restart the computer. Shut down the computer again if you receive the "No-input Signal" error message again. Remove any cables and devices you plugged in to restart the machine. Remove the video card with a spare or replacement by following the instructions above. Connect necessary cables and devices to reboot the computer, then restart it. Shut down the computer and remove cables and devices if the display still won't work. Unplug the power supply's cables from all devices on the motherboard. Make a note of each plug-in so that you can correctly connect all devices with the new power supply. Remove the screws that mount the power supply. Fit the new power supply into the mounting area, and screw in all screws. Attach all required power cables to devices connected to the motherboard. Attach the cables and devices required to start the computer. Reboot. Hope this helps.
Dec 07, 2012 | Computers & Internet
What is the best way to run the mic on desktop
Your condensor mic requires special electrical handling usually reserved for proffesional audio equipment, not a PC. You will need two pieces of equipment, a short XLR cable and an adapter cable.
1) Behringer PS400 Ultra-Compact Phantom Power Supply.
This will supply the mic with necessary Phantom Power.
2) Rapco Horizon ISOBLOX Transformer Isolation 1:1 BLOX Device
This will isolate the Phantom Power from your computer, allowing it to work as necessary.
The adaptor connector cable you need will be a female XLR (with pins 1 and 3 shorted, pin 2 hot), through a cable connect to a 1/8" mini plug. They connect in that order with a short XLR cable between 1) and 2). .
Aug 23, 2012 | CAD Microphones GXL2200 Professional...
No signal or network problem
Shut down the computer. Remove all cables and devices plugged into the computer. Make a note of the port into which your monitor is plugged
hope it can help you ma-friend
Aug 11, 2011 | Dual Computers & Internet
My old power supply had 4 wires going to the front panel on\off switch. The Dynex power supply does not support the switch. what do I use to turn the unit on or off. Will the unit function with out the...
Normally the front panel on/off power button and the front panel reset button plug into connector pins on your motherboard.
If you can find a User Manual for your motherboard it will show you exactly where the switch leads plug in on the motherboard. The motherboard's manufacturer and model number will be printed on the board somewhere.
Good luck.
Feb 05, 2011 | Dynex DX-400WPS 400-Watt Power Supply
Wireless router will not work without my ethernet cable connected
you need to go into the router settings and turn the wireless on and then it will work
Jan 12, 2011 | Toshiba Computers & Internet
Looking for new battery for Gateway MX6214 The one that came with it is Gateway 6msbg model #3UR18650F-2-QC-MA-1 What do I order for a replacement? Can't find anything with the above numbers.
If you are talking about the box that you plug the electrical cord into, it is called a "power supply". second of all, you can buy a plain ol' power supply at your local computer store (like Fry's Electronics store) and replace it with that one and it will work great! just make sure that you plug everything in on the motherboard the way it was before (you can do this by taking note of what everything in the computer is connected to and then replicate that with the new power supply-perhaps take pictures?). However, if you are computer savvy, pictures wont be necessary. Hope this helps!
Aug 08, 2008 | Gateway Computers & Internet
HUB power exceeded on MP3 Player
It sounds as if you have too many USB items plugged in at the same time.
When you connect a device to a computer via USB, the device draws its power from the computer. There is only so much power the computer can supply, and if you connect too many devices it can cause problems (hence the error message).
I would suggest that you disconnect any USB items that you are not actually using. If you are unable to do this, it might be necessary to by a USB hub with it's own external power supply.
Matt
Mar 02, 2008 | Audio Players & Recorders
Compaq computer speakers
Make sure that you have the correct power supply for the speakers. If you are connecting them to a desktop, look for the light green 1/8 plug on the back of the computer. Again, make sure that you have the power supply that came with the speakers. Do not plug the power supply in until you connect the 1/8 plug from the speaker to the light green plug on the back of the computer.
Feb 01, 2008 | Compaq (231111-007) Computer Speakers
USB connection
Yes, the Olympus CB-USB-4 (p/n 200 776) cable is necessary to connect your camera to the computer. This cable is supplied with your camera.
Aug 31, 2005 | Olympus Camedia D-390 Digital Camera
Logitech ClearChat Stereo Headset Headset Logo
24 people viewed this question
Top Logitech Radio Communications Experts
Charles A Stimeling
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
