Question about Tripp Lite Lite 16-Port 1U Rackmount Console KVM Switch (B020-016)
We are facing with Tripp Lite KVM (Model : B020-016-17). When we power on the device, it shows “No input signal” on screen only once and its all leds for signal starts blinking repeatedly. We have tried inputting tripp lite cable randomly in different ports, but on every port we get the same result and we have also tried to take output on another monitor by plugging CRT monitor, keyboard and mouse but the same result was there and we have tried resetting the device also.
2 Suggested Answers
  • 1684 Answers
SOURCE: Tripp Lite KVM monitor light doesn't come on anymore .....
The switch may be the problem but it also may be the monitors internal power supply. To check you can open the case by the little switch and remove the plunger ( the little pin that moves up and down) If you get a picture back then the switch is the problem and you will have to bend the flat spring up to give it a little more movement. I would be if the monitor is about 2-3 years old that the problem is in the power supply board. After a few years many LCD monitors have issues with the power boards blowing capacitors. It happens on desktop monitors and rack mount units too. If you have an external power adapter for the monitor check the voltage output and replace if it is not steady. If the power supply is internal to the monitor then you will need to open the case and check the capacitors for heat damage. Check our site at:
www.ccl-la.com/badcaps.htm for pictures of what to look for. Replace any that look like the pictures and you should be back going again. The values that you will need are going to be marked on the sides of the bad caps. Be sure to use a high temp replacement or the problem will be back in a month or two. If yo don't want to do the repair yourself we do offer a repair service of the monitor for $40 plus return shipping. If you have any questions just let me know.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Posted on Sep 22, 2009
My tripp lite smart1000 lcd don't want to charge
Wait for the power to come back on. If it's already back on, unplug the unit from the wall, unplug all devices from the unit. Plug the unit in, turn it on, let it sit for an hour before reconnecting devices to it.
Oct 19, 2014 | Tripp Lite Computers & Internet
Think has a short in it!!
you can also use an ATX PSU by put a wire between green and black to switch the power on and put your died psu's wire into black and yellow plug (+ on yellow - on black)
Dec 06, 2012 | Tripp Lite Computers & Internet
Tripp lite avr 550 ups keeps on discharging while power is still on
Check the fuse. Check the input voltage. Since it's AVR, it keeps discharging if the input voltage is below the minimum
Aug 05, 2010 | Tripp Lite AVR AVR550U UPS System
Tripp Lite OMNI 1000 LCD will not stay on
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Feb 19, 2010 | Tripp Lite OMNIVS1000 UPS System
How do you switch between ports on a tripp-lite two port ps2 swi
usually you tap the <SCROLL LOCK> key twice then either hit the <backspace> key or the left or right arrow keys.
Oct 10, 2009 | Tripp Lite (B034-002-R) (B034002R) 2-port...
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 22, 2009 | Tripp Lite Lite 16-Port 1U Rackmount...
Tripp Lite B034-002-R 2-port
press numlock twice. There may be other hotkeys, but that's the one that I use. Occasionally mine gets confused (because of reboots and hibernation) and I need to unplug the usb cables from each PC and then plug them back in. Then it works again.
Jun 25, 2008 | Tripp Lite B034-002-R 2-port KVM Switch
Tripp lite internet office 500
Quit out the screw in the back of the equipment, QUit out the battery power supply under the device.
Greetings
Dec 06, 2007 | Tripp Lite Lite Internet Office 500 UPS...
Tripp Lite Lite 16-Port 1U Rackmount Console KVM Switch (B020-016) Logo
207 people viewed this question
Top Tripp Lite Computers & Internet Experts
 Kevin Kershner
Kevin Kershner
Joseph Hoffmann
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
