Question about Krups Coffee Makers & Espresso Machines
Where can I order a krups xp series seal MS-0A01503? It is a seal for the plunger that expels the coffee cake after brewing. It started to leak and I need to replace it.
    Scholar:
  • 82 Answers
Nelson Appliance has this: http://goo.gl/bsjqj. I think this is what you are looking for. The description they give is: Boiler center gasket / seal #MS-5015004 for use with Krups XP7000 series espresso machines.
Posted on Jun 23, 2011
Here is a link where you can order parts for xp2010
Krups XP2010 Espresso Maker Parts
Posted on Oct 15, 2014
Krups ea 8050 eror code 14
Not enough grounds going in to make the cake of coffee the correct height for brewing or the switch that detects the cake height is faulty.
Oct 21, 2014 | Coffee Makers & Espresso Machines
Krups ea 8050 error code 14
Leaking Krups xp 7200 Coffee Maker
It is a Torx T15 screw. Common leak point on those is the barista seal at the bottom of the brewing chamber but that is by no means the only leak point. You need to get the covers off with your new Torx driver and see where the leak is
Apr 01, 2013 | Krups XP Coffee Makers & Espresso Machines
I own a Breville 800ESXLespresso machine which i already decalcified, that leaks from brew head and handle moves while brewing
If you've had the machine for a while, your brew head seal (gasket) is probably damaged or shrunken from age/heat and needs to be replaced. That's most likely why the filter holder moves and leaks while brewing. Breville brew head seals are rather difficult to locate, but I personally stock them and sell them at a reasonable cost. I sell lots of new and used parts for various coffee machines, but specialize in Krups. If interested in purchasing a Breville brew head seal, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I accept Paypal to make the transaction safe and secure for us both.
Nov 27, 2010 | Breville ESP8XL Espresso Machine
Hi. I have a Krups XP7245 combination espresso/coffee maker that leaks when I make coffee. This is a recent problem. It's out of warranty (of course), and I'd like to disassemble it to try to resolve...
I had the same problem with the XP7240. The rubber seal in the plunger that pushes out the coffee cake after brewing is worn or dirty. You need to romve the cover by taking of the top (screws in the bean collector and cover tray for cleaning tablet). You have to be rough because parts are clicked together. The face of the machine comes off by pulling it upwards (it is just clamped with plastic nudges). Once that is done you remove the 4 screws that were hidden by the stainless steel face. Then remove the electronic board (leave connections on except for bean grinder and boiler). Grinder can then be removed followed by the cream cover. Remove the 15mm steel nut on top of the arm. Remove the front and display. Then use a torix on top of the brew plate and an allan key on the bottom of the plunger. Unscrew, remove spring and seal (very small cup). Let me know if you need more instructions (take a rainy sunday afternoon to do this)
Aug 13, 2010 | Krups Small Appliances Espresso Machine
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
Hi, I need a 'joint seal' for my Krups XP4000 expresso maker, and ideally also one for my old Krups XP 962 expresso maker. I got them in France where they are called 'joint porte filtres' ref cde MS 620342...
The part for your XP4000 is the brew head seal. A Google search turned them up here:
http://www.smallappliance.com/product.asp?cur=USD&cam=krups_parts&sid=18954&gid=18960&mid=15&pid=2870&prdCls=P&shopBy=Brand
This page is their Krups model list:
http://www.smallappliance.com/department.asp?cur=USD&cam=krups_parts&sid=18954&gid=18960&mid=15&shopBy=Brand
It doesn't show the XP962 but it gives their phone number and says to call if you don't see what you need. So maybe they can help.
In general, when you want to search for something on the Internet, start with a good search engine (I use Google but there are others of course) and give a search string like "krupps kp40000 parts". Then you can check out the links it gives you until you find what you need.
Nov 22, 2008 | Krups Small Appliances Espresso Machine
The group head seal is cracked and is leaking when making coffee. Where can i get a new seal?
I sell lots of new and used parts for various coffee machines, but specialize in Krups. If interested in purchasing a Krups brew head seal at a resaonable price, contact me at cowboy_romeo@yahoo.com and I'll make arrangements. I purchase the groups seals directly from Krups and they will arrive sealed in the manufacturer's original plastic packaging. I accept Paypal to make the transaction safe and secure for us both.
Jul 17, 2008 | Krups XP4030 Espresso Machine
Water in dump box. Saeco Vienna Deluxe.
Had the same problem. I found that the rubber O ring around the plunger was split and leaking water into the dump box. It could also be that your O ring, if not split, is too worn to continue sealing. Try replacing the O ring. I am in process of doing that myself as I just found the problem.
Another possibility is that the filter that filters just before expelling the coffee is clogged and the coffee cannot escape, if that is the case you probably would be getting coffee and not clear water, I would opine.
Feb 17, 2008 | Saeco Vienna De Luxe Espresso Machine
Krups xp 4020 leaking
My Krups leaks like a sieve and I found parts (seals) available at  smallappliance.com
Sep 10, 2007 | Saeco Vienna SuperAutomatica Coffee...
Coffee Makers & Espresso Machines Logo
840 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
