Question about HP Photosmart D5160 InkJet Printer
Ink not working D5160 using refilled ink cartridge.. red light blinking
    Problem Solver:
  • 10 Answers
I have a D4360 that I use refilled cartridges with, and have had that problem. I found out that when I get a red light and no ink with a refill, the circuit strip on the cartridge is bad and not making a connection. You'll need to take the refilled cartridge back to where you got it, with the receipt, and let them test and replace it.
Posted on Aug 31, 2010
Ink light and paper light keep flashing alternately on my epson l110, how can i fix this ?
It may be a paper jam error. I find when you use an old or rough page in your printer, it don't properly go to its way and cause to displace a sensor that is situated at under the Head carriage of this printer which can be seen in following pictures.
Solution: check if this problem is occurred after paper jam then check the sensor is on its proper place or not if not then open the printer upper cover, open the lock of carriage rod from both sides. Set the sensor at its proper place and then check it.
Apr 17, 2015 | Epson Workforce 1100 InkJet Plotter...
Why is power button light blinking green on Epson SX200 printer?
Regarding your recent inquiry about the Epson T071 ink cartridge error message ("Ink Light is red", "Cartridge Not Recognized", "Replace Cartridge", "Installed ink cartridge is expended." or similar cartridge/printer alert message) associated with your Epson SX200 printer, the cartridge probably has a mis-programmed smart chip...
NOTE: If you had the cartridge refilled, the cartridge chip must be reset. Re-programming, which typically yields a green light to show success, it does not always result in correct smart chip reprogramming. It is also possible they may have forgotten to re-program the ink cartridge. If a compatible/clone cartridge, it could be a reprogramming issue or defective chip (which is common). Or, such a failure could be an electrical failure of the ink cartridge itself*. Unfortunately there is nothing you can do from home....the chip(s) need to be re-programmed (at refiller) or replaced with a new cartridge from vendor.
*OTHER POSSIBLE CAUSES OF FAILURE:
Either the external chip or internal ink sensor is electrically bad (the internal ink sensor detects if cartridge is really out of ink). If you return the cartridge to your retail refiller and they re-program the cartridge(s) a 2nd time but the "replace cartridge" message, or similar blocking message persists, then this is the likely cause and the cartridge will need to be replaced with a new one.
1) Confirm if this is just a nuisance/annoyance alert (i.e. "non-genuine" cartridge ) vs. an actual 'unrecognized cartridge' alert (i.e. Red X's on printer display / Windows pop-up message). Please visit the following Inkjet411 support page which will help you delineate the difference: http://inkjet411.com/?page_id=73
2) On some Epson printer models you may need to scroll thru the menu options AT THE PRINTER'S CONTROL MENU (i.e. right arrow key) to help determine which specific ink cartridge is actually causing the 'Unrecognized Cartridge' error condition. On the other hand, for general 'non-genuine' cartridge alerts, typically you can bypass these errors by clicking thru the acknowledgement prompts or via the arrow keys: http://inkjet411.com/?page_id=1939
3) We suggest you remove all the ink cartridges, inspect the smart-chips condition (on rear side) and ensure there are no cuts/gashes or ink residue present on the micro-chip surfaces. To be sure we suggest you clean the micro-chip surfaces; click here to see 2 different pictures of this along with cleaning instructions: http://inkjet411.com/?page_id=1939
4) If the error continues (following ink tank re-programming a 2nd time), then we suggest you install a new genuine Epson ink cartridge into the printer to verify the permanent PRINTHEAD is functioning ok. Here is how the PRINTHEAD works: http://inkjet411.com/?page_id=2054
NOTE 2: Following refilled cartridge installation, your printer/computer may display an ink alert message such as "non-genuine cartridge" or "you have not installed genuine Epson ink cartridges" - these are COMPLETELY NORMAL alerts when using refilled ink cartridges. Press proceed/continue/accept/yes/OK to dismiss the prompt. In some cases you may have to scroll over using the arrow keys to dismiss the alerts. Additional alerts may be displayed the first time you go to print or copy - dismiss the alerts accordingly to resume normal print operations. For more information on Epson ink cartridge alert messages please visit: http://inkjet411.com/?page_id=1939
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors or permanent PRINTHEAD damage (especially for 3rd party inks which contain volatile organic compounds or VOCs). We do NOT suggest refilling these types of ink cartridges.....refilling of Epson original/genuine ink cartridges is only suggested!
Epson T068 thru T130 Ink Refilling Services & Additional Cautions: http://www.youtube.com/watch?v=Jp575rE9y0Q
NOTE 3: If, after replacing the cartridge(s), with brand new Epson Original ink cartridge(s), is the only solution which corrects the problem, then you likely have a defective cartridge (internal ink level monitoring circuit), unrelated to the refilled cartridges. If, after replacing the cartridge, or cartridges, with brand new Epson Original ink cartridges, does NOT correct the problem, then you may have a defective PRINTHEAD (i.e. permanent electrical sub-assembly which the cartridges plug into). For more information please visit our support page which explains the natural degradation of PRINTHEADs over time: http://inkjet411.com/?page_id=2934
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
Sep 03, 2014 | Epson 20 Ink For Stylus S20 Sx100 Sx200...
I am using samsung Ml 1640 Mono Laser Printer .After finishing Toner Ink I refilled it and set the toner into the printer . Then both of the lights Green & Red light is glowing but the Red light is...
Samsung uses a chip that senses when the cartridge has ended its service life, the chip is located in the cartridge itself, refilling toner won't help, replace the cartridge with a new one. hope this helps ;-)
Feb 03, 2011 | Samsung ML-1640 Monochrome Laser Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
I have an HP Photosmart 5160. The red exclimation is blinking as well as the green power button. There are also 2 ink drops present in the screen. Any suggestions as to how I can fix this.
HERE is a link directly to HP's troubleshooting documentation for your model printer and possible solutions. Looks like the ink cartridges are low or empty.
Aug 31, 2010 | HP Photosmart D5160 InkJet Printer
Ink light blinks red after I have properly installed cartridges
When you say the red light blinks after you have properly installed cartridges, I must ask you one question. Are you installing a brand new cartridges or cartridges that you have refilled or had someone refill for you? On one hand , if you're installing new cartridges your problem is going to be in the software inside the printer itself. If you are using refills the problemand is the cartridge itself , as there is a chip on the cartridge that you can't reset or program.
Apr 10, 2010 | HP Deskjet F340 All-In-One Printer
Blinking red light, unable to turn off or print
From the looks of your printer. I'd say that one of your ink has a problem. The part where you put the cartridge in, is where your problem lies. YOu'll prob need to get it checked out by an HP dealer.
try changing the ink cartridge and see if that helps.
Aug 12, 2009 | HP Photosmart D5160 InkJet Printer
Red light on "check color cartridge" blinks constantly.
i have a printer hp all in one p380 the all lights are blinking
Jul 06, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Refilled ink cartridges not recognizby printer.
I fixed the problem by using original Canon ink cartridges and not getting them refilled. Apparently their chemists put a chemical in all of their inks so that only their Canon printers will recognize. It's a guarded trade secret that no one else knows about, unless it was analized. Other ink manufacturers produce ink that looks exactly as Canon ink, but that's where the similiarities end.
Nov 24, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Ink cartridge lights blinking
That is happening because you have "smart" chips on your cartridges, so even though you know there is still some ink left in the tank, if the chip says stop, the printer will stop printing. There is a way to bypass that and that is by using a re-setter. You can either buy one or ask to re-set your cartridge in a refill shop.
You can also try holding the "resume" button (triangle in circle for about 10 seconds for each cartridge, sometimes doing that resets the cartridges.
Do not refill the magenta and cyan cartridges if they are not empty, you'll just be wasting your money. Better use it to buy a re-setter ;)
Hope that will help!
Nov 27, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
HP Photosmart D5160 InkJet Printer Logo
248 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
