I have a full signal from router an still can not go on internet .I have huighesnet for server of internet and if I unhook the wire from the router and hook up to the laptop it work soso, I do not no that if hugesnet is bad or if my router need some work I have had the router for about 3 or 4 months I do not have my receipt from when I got it but the serial # 12951723422221 model #F5D7234-4V5
    Scholar:
  • 55 Answers
If you have full signal and cannot go on the internet, you probably have a wireless driver problem. Try reinstalling the wireless driver and see if that helps. you can probably find the driver in by googling "(dell) drivers download" or whatever computer you might have.
If you have played with optimizing vista or xp or whatever you have, you might have disabled some services that are required. so I recommended setting them to manual (to do that control panel and search for "services") then let windows fix your problem automatically by hitting a troubleshoot button.
Posted on Aug 31, 2010
Ihave a dlink router with dhcp enabled, it seems to conflict with server dhcp(sbs 2003), I disable the dhcp on the router, now i lost the internet connection. pc's on the network all have static i
Do the server connected wired or wireless?Your server IP need to be in the same range of your router like 192.168.0.102.Can you wire your server directly to modem or to the router?
Apr 18, 2013 | Computers & Internet
I wont to play game in lan with my home frends bat my computer canot find a lan .the game is full . my net is with dinamic ip..what i can do?thanks
D-link router provides signals through cable wired connection where each persons computer shares signals from the only computer that has network services. For example, one of the computers that has the internet on which router is connected either has capacity to network several additional computers or not. Usually the server computer that has connections with ethernet cables makes sharing signals possible beyond dial up phone line networked cable conections.The routers splits signals between computers requesting connectivity only becomes possible when enough capacity exist to several computers. The type of network strutures makes the link possible. For example, D-link router should allow to network more than one computer else another router that makes signal expansion possible is prefered. Circumpectively, ascertain that the computer from which video game is installed has the expansive capacity either in cables connection ports, wire links where router becomes the location where each device derives resources.
Feb 22, 2011 | D-Link 802.11g Wireless Router WBR-1310...
I am not able to connect to the internet using my Linksys WRT54G V8. When I connect the cable directly to my laptop, I am able to access the internet, so it is definitely a problem with the wireless...
Title: Setting-Up a Wired Computer to Obtain an IP Address Automatically Article ID: 4033
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
The wireless on my new router is not working but the wired is.My wireless can connect to the signal but it stills says no internet access. it was working earlier today but not now. I have a Linksys WRT320N...
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Make sure that the DHCP server on the router is enabled
Click Here for step by step solution
May 10, 2010 | Cisco WRT320N Wireless Kit
Connected but could not access internet
When connected via wireless open a command box and type "ipconfig /all" and note the DNS settings assigned to your laptop. Then do the same with the wired connection. If the wireless connections are not receiving valid DNS settings, that would explain why you won't be able to access any Web sites. You can then re-configure your router to issue the correct DNS settings as per those issued to the wired connection. You could alternatively add these DNS servers as static settings on your laptop, but its best to do it on the router and leave your laptop set to automatic.
Dec 11, 2009 | Linksys Wireless-G WRT54G Router
Why does it take a long time to carry out basic task like going through emails.when getting on line would experience long delays in spite of having broad band? I have to sut down and reboot almost all the...
Assuming you are saying mostly when working on Internet you are having slow performance issues.
Causes can be from a number of sources. Are you connecting wireless to Internet? Source signal may be to weak or unstable. Preferrable to keep signal at 80% or better.
Web sites and how your connectivity navigates through the Internet cloud (server to server to server and so on) can be hampered by any point along the way.
If you are using a wireless router that is shared by mulitple computers, try isolating and removing other computers and any network devices (wireless print servers). You can also try connecting with an Ethernet cable directly to router or modem.
Oct 04, 2009 | Computers & Internet
The other night I thought that one of the connections to my internet server went out and I unplugged it and my router. Now my server and desktop are working but my laptop say that it is connected and has...
Plug in Internet cable into WAN Port, Switch OFF your Router and then ON, Disable Wireless Network Card of your Laptop and then Enable. Verify IP configuration of the router and Internet Server. Also check if it is DHCP or Manual. Follow instructions.
Best of Luck,
Regards;
Hassan
Aug 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Limited access to internet with toshiba satelite - signal strength excellent
seems your laptop is not getting a ipaddress back from the router or dns server.. I would check your wireless settings, maybe reset the router, hold down the reset button for 30seconds try again. sometimething might be wrong in the wireing.
Oct 21, 2008 | Computers & Internet
Wireless router dynamode
areejshaukat,
if ur laptop detect full signal from ur router, click on the signal and let ur laptop connect to the signal..coz even ur laptop detect the signal,it doesnt auto connect,so u hve to connect it manually..
Apr 07, 2008 | Computers & Internet
Internet problem
Are you attempting to access your own wireless router? Do you know how to access your wireless router configuration? Does your wireless router support wired connections? If so, does your computer work on the on the wired connection? What is the manufacturer and model of the wireless router, laptop computer and if a separate accessory the wireless network card?
Thanks
Dec 05, 2007 | Computers & Internet
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
