Question about Fuji FinePix S5000 Digital Camera
Hi I have a fuji S5800 camera which fell and the mode dial was broken. Where can i buy the button and can i install it myself? Thanks very much Boaz
SOURCE: Accessories for Fuji Fine pix S5800
You Can not put additional flash on S5600, S5700 and S5800.
Posted on Sep 10, 2008
SOURCE: Mode Dial Broken Off
Hi All
It seems to be a common fault with this camera after contacting the store that i bought it from and being given the runaround I gave Fuji a ring and was told to send it to them and it would be fixed at no charge. Sent away on the next Friday and returned the next Monday week. Great service very happy.
Doug
Posted on Apr 03, 2009
  • 7 Answers
SOURCE: Fuji S5800 spare parts
I would see if Fuji would let you send it in direct to them. Alternatively search on ebay for spares or repair camera that you could take the pieces off of.
Good Luck.
Posted on May 13, 2009
SOURCE: Fuji Finepix S5800
I have just done this very thing. I ordered a new replacement OEM LCD from a seller in the US listed on E-Bay. Even with postage it was a third of the cost of sending the camera to Fujifilm for repair (and Fujifilm wanted a couple of quid less than buying a whole new camera!). To Dismantle the FujiFim S5800 and get the back off the camera you need to remove 5 screws, and dont mix them up as they are different lengths. I used a set of those small jewellers screwdrivers to do this. Make sure you have taken the battery's out and taken the carrying strap off. First remove the screw on the side just above the flap where the memory storage card goes. On the opposite side of the camera where the carrying strap bracket is you will find two screws in the recess, just remove the one screw nearest the back of the camera. Now turn the camera up-side-down. You will find 4 screws around the threaded hole for a Tripod. Remove the two nearest the back of the camera (they are also the widest apart). Now open the battery hatch and remove the screw nearest the outer edge of the camera which is effectively below the memory storage hatch. The back of the camera should now be easy to lift away and reveal the LCD screen. Be careful as there is a small semi transparent printed circuit cable that connects the rotary switch to the main body of the camera. I chose to leave this in place as I was reluctant to remove more parts than necessary - however if you choose to leave it in place be sure support the the back bit of the camera as you do not want to strain rip or excessively twist this cable. The LCD screen rests in place between some guides and had a small piece of black tape holding the end down at the ribbon cable end. Use the blade of one of the screw drivers to lift the corner of the tape away. and you can lift the LCD screen up. The Ribbon Cable looks like a push fit but in fact there is a tiny black hinged section holding it in place. Be very careful and lift this up and the old cable can be released and removed. You will find the same system holding the cable in place for the rotary switch so if you want to give yourself working room you could disconnect that in this manner. Fitting is now a reversal of the removal process. Put the ribbon cable into the socket as far as it will go, No force will be required. Clip the tiny black hinged section down and this will lock the cable in place. Re-assemble the camera and remember to fit the memory storage hatch while doing so. Note: the storage hatch has a small plastic lug that presses a switch. When the hatch is opened it cuts the camera off (personaly I think this is a bit of weak point in this camera's design, if this lug or switch wears or breaks the camera is not going to work - but that is by the by for now). Presumably this is so you don't add or remove memory cards while the camera is powered up. This means it is difficult to test the new screen without putting the camera back together. But all being well you should be back up and running. Just take your time, study all the parts first and you should be ok. Don't come crying to me though if you break it - remember all repairs are carried out at your own risk.
Posted on Jul 03, 2009
slimboga
  • 82 Answers
SOURCE: Broken Selector dial on my Fuji S9500! Any info
if you want the solution for the dial problem of the fuhji s9500
write me to my mail slimoncelli@hotmail.it, and i explain you to repair the problem.
Posted on May 30, 2010
Samsung wb100 dial mode selector fell off!How do I get another?
i am also having problem my mode dial has been broken it comes out from the camera
Apr 18, 2013 | Cameras
The mode dial on my Fuji S8000 fell off! I was taking a picture and it just fell off!! Is this a common problem and if so, does Fuji repair it at no cost?
Fuji recognise this as a fault and are currently replacing the dial without cost. Send it into an approved Fuji specialist...
Oct 25, 2010 | Fuji FinePix S8000fd Digital Camera
My Fuji Finepix S5800 tells me my brand new batteries are flat.
It sounds like you have bad batteries. I have had rechargeables that have suddenly done the same thing. I have learned that buying really cheap ones doesn't work out. If you buy a good branded set, I think you will find that they are much better. :)
Jul 17, 2010 | Fuji Finepix S5800 Digital Camera
My Fuji s5800 camera has a 'zoom error'
try pressing the unzoom button and holding it for a couple of seconds until it fixes itself. and if it makes a noise, till it stops!
Apr 10, 2010 | Fuji Finepix S5800 Digital Camera
Hi i lose my finePix S8000fd mode dial ring, could i got it? Thanks
The mode dial on these cameras break off that often that Fuji in Australia is replacing them at no charge - sort of a recall issue.
Call your Authorised Fuji digital camera repair centre, make sure they will replace it at no charge and then send/take it to them
Jun 25, 2009 | Fuji Cameras
Hi, I have a finepix s5800 camera. I went to install it on my laptop (its already installed on my other computer), but now I cannot find the installation disk..... what can I do? Will I need to buy another...
I suggest that you logon to the fuji website and update the picture program offered for your camera. But any picture program on your computer may read the pics when you attach the camera and turn it on picture display. I have an s7000 and rarely use the one offered by Fuji.  My olympus and canon programs also work with my fuji camera.
Jan 27, 2009 | Fuji Finepix S5800 Digital Camera
Good Luck.
Jan 19, 2009 | Fuji Finepix S5800 Digital Camera
Camera is a Fuji Finepix S5800. How do I get the date to print on pictures?
In playback mode press the f button, when the menu appears select print order (DPOF), then select with date.
Aug 16, 2008 | Fuji Cameras
Jun 18, 2008 | Fuji Finepix S5800 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
52 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
