I have a Magnasonic window-mounted air conditioner, model ACM6000. I want to remove the front grille to get to the filter, but I don't know how. I'm afraid to break the grill. There are no visible screws that hold the grille and I do not have a manual. How do I do this?
  • 3 Answers
Magnasonic has customer support email customersupport@rgccanada.com
Posted on Jun 11, 2008
Can i take my frigidaire ac out of the case without removing it from the window?
Good Afternoon Friend,
I understand that you want to know whether you can take your Frigidaire air conditioning, model# FRA256ST2, out of the case, without removing the case from the window. Yes you are. Below are step by step instructions for removing your air conditioning from the case.
    1)Unplug your air conditioner.
    2)Take the front grill off.
    3)Remove the filter.
    4)There are four panel screws, two on each side of where the front grill and filter were. Remove these screws.
    5)Gently pull out your air conditioner.
    For replacing your air conditioner, follow the steps in reverse. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer light status has changed successfully. Hope this is helpful.
    -Best regards-
    WP
May 31, 2014 | Frigidaire FRA256ST2 WallWindow Air...
Troubleshooting 8000
The filter slides out of the bottom of front grill. If there is no room to slide it down and out, remove the 2 screws (1 on each side) then remove front grill to access filter.
Dec 14, 2013 | Carrier XHB123D X/Y Series Heat/Cool Air...
Friedrich kq06j10 air
should be right in front of cover in front. either the grille in front pops off or whole front comes off
Aug 10, 2013 | Friedrich KStar KQ06J10 Air Conditioner
I just washed the air filter and after that the compressor is not working i dont know the model number but its a window a/c when i removed the cover there was a wire on the grill, is that wire has to...
Not sure is it does or doesn't relate to the problem. The best way to find out is to replace the wire as you found it. Turn the unit OFF and Unplug it before removing the front again.
Aug 05, 2011 | Samsung AW0503B Air Conditioner
Removal of front cover, so filter can be cleaned
On my air conditioner the filter slides out from the top of the air intake grill. It looks like part of the grill but look closely you should see the seam across the top of the grill. You don't have to take the front grill off.
Jul 06, 2011 | Frigidaire FAH106N1 Wall/Window Air...
How to remove the filter in a GE air conditioner?
1 Look for a tab on the top, right side or near the bottom of the front grille. The tab protrudes slightly from the grille.
2 Pull the tab with your fingers and remove the filter from the Hotpoint air conditioner. The tab is part of the air filter.
3 Insert a new air filter in the air conditioner until you hear the plastic part of the filter click into place.
4 Lift the bottom of the front grille up and out if the filter is not visible. Unclip the top of the front grille and pull it away from the air conditioner. Look for the tab to the air filter in the small cavity near the top front of the Hotpoint air conditioner.
5 Pull the tab and remove the filter. Insert a new filter and snap the front grille back in place.
May 30, 2011 | Heating & Cooling
My frigidaire air conditioners spit dirt all over the floor. My window unit and my through the wall unit in a sleeve both do the same thing. I called Frigidaire two years ago and they told me there were no...
1. Turn units off
2. Remove Filter
3. Spray a foaming cleaner on the coils (Dow Bathroom Cleaner)
4. Use a spray bottle filled with plain water
5. Replace Filter and Grill
May 25, 2011 | Frigidaire FAC124 wall/Window Air...
How to remove my LG window AC's cover?
You will need to lift up the filter cover by lifting the grill door . Inside the grill is found the screws for fitting the front grill. removing the filter, remove screws of the grill inside will make the grill come off. Do not pull out but there is a latch on the top that the grill has to be lifted up and taken out. Some models have screws on side and must be taken out before the panel is pulled
Aug 31, 2010 | Heating & Cooling
Where is the filter
It's behind the front grill underneath the vent. Some window A/C you can slide the filter out from the side or the bottom. Some you have to pull the whole front cover out. Some is part of the front grill and is not removable, and can be cleaned out instead of replacing.
Jul 09, 2010 | Goldstar R5050 Air Conditioner
How to clean the filter
The filter is behind the front grill. Pop off the grill, should just pop off, pull down from the top under the vents. the filter is behind there.
Sep 18, 2009 | Goldstar KG6000R Window Air Conditioner
Heating & Cooling Logo
88 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
