Question about Nikon D40x Digital Camera
Dark Images At some point, the images from the camera became very dark in automatic mode. Previous to that, the images were perfect. I have checked all settings many times and changed back to default settings. Nothing has seemed to work other than to change mode to "P" and set for extra exposure. Thanks.
  • Anonymous May 12, 2008
    hi got the same issue.. exactly the same..
  • rahuliyer Apr 27, 2009
    I've got exactly the same problem. Years of beautiful images, then suddenly the images went dark and grainy. I've reset the camera settings to default...no luck.
  • 111 Answers
Even in automatic mode, camera still lets you pick what ISO to use. If ISO-Auto is OFF in camera menus, this can give some dark images. Press and hold ISO button and rotate command dial to give a higher ISO, or turn ISO-Auto on in camera menu with crayon icon. Also note that the camera saves exposure compensation setting for each mode,
Posted on May 15, 2008
Seems to be a common theme here. This is the second post I've found describing the same issue, and I have the problem too. I'm going to send mine back.
Posted on May 24, 2008
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Taking picctures outside they come out completly white and inside they are fine.
Not sure what type or model of camera you have. But most camera's have a Mode dial. The best thing to do is to turn that dial to the little green camera logo. That is the automatic mode. If you have chosen the moon and star, you only can make pictures in bad light situations.
Dec 09, 2013 | Samsung DigiMax Cameras
My pictures are coming out too dark
There are four ways to make the image lighter
a) more light (flash, sun, etc)
b) slower shutter speed (allows more time for light to "expose" the sensor)
c) larger aperture (bigger hole = more light)
d) higher ISO (basically, amplify the available light more).
If you are using a point and shoot camera, the flash is usually only good for about 10 feet, so trying to get a good bright picture of subjects further away won't work.
Items b, c, and d are handled by the camera in automatic mode. In manual mode, set the iso has high as it can go. Set the aperture as large as it can go, and decrease the shutter speed.
Depending on the camera, you can enable the histogram to see if the images are too dark, usually by pressing the display button while taking pictures. If the histogram is off to the left edge, the picture will be too dark.
In post-processing, (e.g. photoshop), you can use Levels (control-shift-L for auto-levels) and it will move the histogram to the right, making the picture look brighter.
Feb 27, 2011 | Cameras
I am using D90 with programe Auto ISO 400, in clear day sun light my picture get very dark, but on same settings in door with auto flash I get very clear result why?
ISO400 is too high of a sensitivity to use in full day light. Set the ISO outdoors to ISO100 and learn how to use your exposure compensation. The meter in the camera is easily fooled in bright contrasty conditions, so if you are getting consistantly darker shots outdoors increase the exposure compensation a stop or two. Another way is to learn how to use the camera in manual mode and you find you will have better control over the exposure.
Oct 21, 2009 | Nikon D90 Digital Camera with 18-105mm...
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
My Canon EOS Digital Rebel XT is taking pictures darker than normal. Why?
First, to test be sure you are in Automatic mode. The dial should be on the Green Box setting. If its on other settings its in manual mode and can be set wrong. take a test picture in this mode, If its looking normal, then you were either int he wrong mode or your manual settings were off. But if they are still dark try your ISO settings, if too low a number it will result in dark images. For example ISO 100 is perfect for outdoor daylight, but ISO 400 is better indoors.
Next try the F stop settings and arppreture. If things improve, you have found the issue. This camera is professional grade so it will do exactly what its set to do even if the outcome is not what you want!
Whe all else fails use the menu and reset the camera to factory defaults.
Dec 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon S2IS Black Screen in Auto mode
sir, ur problume related to CCD u replace CCD
Apr 01, 2008 | Canon PowerShot S2 IS Digital Camera
Dark pictures
Be sure that you are capturing images in the right shooting mode. For example, if shooting a night scene your image will be underexposed and dark if the image is captured in the Program Auto mode for regular photography, or in any mode other than Night Scene. Be careful that when capturing images, nothing is obstructing the flash.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Dark pictures
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Dark pictures
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Nikon D40x Digital Camera Logo
118 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
