Canmot creat pr replace flash; access is denied. make sure the disk is not full or wirte protecred and that the file is not currently in use
  • 808 Answers
Use reginout regcleaner it will fix ur problem
Posted on Aug 31, 2010
Pen drive access denied
USB ports and devices make connecting to another computing device convenient.
USB technology has been around since 1996, and is a feature found on most modern computing devices.
If your device is denied access to one of its USB features, do some troubleshooting to isolate and resolve the problem.
Viruses
Some computers come with a security feature that automatically denies access to a USB device, such as a flash drive, if harmful content is detected.
Installing an anti-virus software application and regularly scanning the computer and any connected USB devices can help you avoid experiencing denied access to a USB device.
Avoid opening USB flash drive files that you cannot identify or do not recognize, as these types of files are how viruses find their way onto unprotected computers.
Incompatibility
Inserting an incompatible device into your computer's USB port can also cause you to be denied access to your device's USB features.
For instance, if your computer supports USB 1.0 technology and you insert a USB 2.0 or USB 3.0 connector, the computer can experience interfacing problems that may cause a "USB access denied" prompt or situation.
If other USB devices begin to malfunction after inserting an incompatible USB cable into your computer, turning the computer off and back on again may resolve the situation.
Formatting
USB flash drives, also known as pen or thumb drives, are among the most common types of USB devices used in conjunction with computers.
Most USB flash drives are formatted using one of three types of formatting methods: FAT16, FAT32 or NTFS.
If you've formatted a USB flash drive using one method, used it on the computer and then reformatted the drive using another method, you can be denied access to the flash drive through the computer's USB port.
Wiping the flash drive clean and reformatting it again can resolve this type of problem.
Considerations
Many computer accessories, including printers and pointing devices, connect through the machine's USB ports and can interface interchangeably with multiple computing devices.
This feature increases the risks of picking up viruses and experiencing unauthorized reformatting. Limiting the amount of computers your USB devices accesses can help you avoid these situations.
Damaged USB cables can also make it impossible to access USB devices when they are connected to your computer.
USB cable damage usually occurs at the points where the cable and its connectors meet. Replace any damaged USB cables.
You have to be the computers administrator to change any values on any hard drive on your computer.
Click start control panel user accounts on the users tab click the name of the computer Administrator you must have full control.
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
http://www.webopedia.com/TERM/U/USB.html
Sep 06, 2013 | Computers & Internet
Tip
All Problems have ONE solution and that is: www.longPathTool.com Path too long....
<p><b><u><span>Delete An "undeletable" File</SPAN></U></B><br> <p><b><span> </SPAN></B><br> <p><span>Open a Command Prompt window and leave it open.</SPAN><br> <p><span>Close all open programs.</SPAN><br> <p><span>Click Start, Run and enter TASKMGR.EXE</SPAN><br> <p><span>Go to the Processes tab and End Process on Explorer.exe.</SPAN><br> <p><span>Leave Task Manager open.</SPAN><br> <p><span>Go back to the Command Prompt window and change to the directory the AVI (or other undeletable file) is located in.</SPAN><br> <p><span>At the command prompt type DEL &lt;filename&gt; where &lt;filename&gt; is the file you wish to delete.</SPAN><br> <p><span>Go back to Task Manager, click File, New Task and enter EXPLORER.EXE to restart the GUI shell.</SPAN><br> <p><span>Close Task Manager.</SPAN><br> <p><span>Or you can try this</SPAN><br> <p><span>Open Notepad.exe</SPAN><br> <p><span>Click File&gt;Save As..&gt;</SPAN><br> <p><span>locate the folder where ur undeletable file is</SPAN><br> <p><span>Choose 'All files' from the file type box</SPAN><br> <p><span>click once on the file u wanna delete so its name appears in the 'filename' box</SPAN><br> <p><span>put a " at the start and end of the filename</SPAN><br> <p><span>(the filename should have the extension of the undeletable file so it will overwrite it)</SPAN><br> <p><span>click save,</SPAN><br> <p><span>It should ask u to overwrite the existing file, choose yes and u can delete it as normal</SPAN><br> <p><span>Here's a manual way of doing it. I'll take this off once you put into your first post zain.</SPAN><br> <p><span>1. Start</SPAN><br> <p><span>2. Run</SPAN><br> <p><span>3. Type: command</SPAN><br> <p><span>4. To move into a directory type: cd c:\*** (The stars stand for your folder)</SPAN><br> <p><span>5. If you cannot access the folder because it has spaces for example Program Files or Kazaa Lite folder you have to do the following. instead of typing in the full folder name only take the first 6 letters then put a ~ and then 1 without spaces. Example: cd c:\progra~1\kazaal~1</SPAN><br> <p><span>6. Once your in the folder the non-deletable file it in type in dir - a list will come up with everything inside.</SPAN><br> <p><SPAN style="FONT-FAMILY: 'Tahoma','sans-serif'; FONT-SIZE: 10pt
on Dec 25, 2010 | Computers & Internet
I have transcend JF V30/4GB pen drive. Recently i am getting in the pen drive that i cannot do any format in the pen drive nor i cannot copy/delete the files in the pen drive. it was showing that...
Hello and Welcome to FixYa!
Kindly try this solution:
  • Connect the USB stick to another computer and copy all the data.
  • Download this file (click here) to that PC and format the USB stick using this program.
  • Now try to connect the USB stick to your ACER laptop and see if it works.
If you have any further queries, please do not hesitate to comment again. If this solution was helpful to you, kindly rate it.
Regards, Waqar.
May 22, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I repaired the viruses found but when I tried to open my flash drive it doesn't work, the computer says, ''Access is Denied''. What should I do? please help me, got many important files in it.
Were the viruses you found on your local hard drive or on your flash drive? Do a virus scan of your flash drive to be sure. Not sure what program you're using, but make sure you tell it specifically to scan that drive, otherwise it will just scan your C: drive, and that won't help.
I would also try accessing the flash drive from a command line. Click Start --> Run... and type cmd
In the black window that pops up, type the letter name of the flash drive, like e: and hit enter. If your prompt changes to E:\ your files are intact. If you get an error like "access is denied" again, then you'll have to get more creative. Truthfully it sounds like there's just more virus cleanup to be done.
If you're in a pinch, you could download something like Ubuntu, create a boot CD (it comes with instructions), and boot your computer into Ubuntu (without installing it). Once you've loaded Ubuntu, you should be able to see all the files on your flash drive and copy them to another device.
Hope this helps you! If so, please leave a rating!
Mar 13, 2010 | ASUS Computers & Internet
Hitachi SimpleDrive 320GB: Error moving file: Access denied!
The problem may be that your Security settings for the drive are not configured to give you Full Control.
In Explorer, right-click on the Hitachi drive and choose Properties.
Go to the Security tab.
Find the User you are trying to use and click on it.
Under Permissions, click Edit and enable Full Control for that user.
That should give you the ability to do what you need to.
If Windows won't allow you to change the setting, it's because you don't have Administrator priviledges. In that case, log out and log back in as an Administrator and go back and make the changes.
Nov 04, 2009 | Computers & Internet
Access is denied on picture and video clip file.
I had the same problem before. Unfortenatly this has to do with owner permissions set on on your old device and not recognising or accepting this permissions on the new.
If you still have your old device working then change the permissions for all files to "full control" for "everyone" and then copy. this is will solve the issue.
Aug 07, 2009 | Western Digital Passport WDXML800UE...
Error message: access denied
go to ur control panel and make sure ur not useing a guest profile u must be in a admin.profile to change any files and try deleteing all passwords for ur admin. profile this should fix it
Mar 27, 2009 | Dell Inspiron 6000 Notebook
Just got a sandisk cruzer 8 GB (with U3). I want to copy files from hard drive to flash drive. Error says :cannot create or replace 40: access is denied". But i can copy the same files from hard drive to...
Hi there
Have a look at the side of the flash drive for the copy protect switch and turn it off. Job done!!!!!!
Good luck and thanks for using Fixya
Jan 13, 2009 | Cameras
Cd error messages
Try to check if the file you want to copy currently used by the other application. You can check you task manager by pressing together the CTRL+ALT+DEL button.
Nov 02, 2007 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
