Question about Cameras
Card locked. How do I clear locking? - Cameras
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 31, 2010
Card locked message on a570is
Solution: I had a similar problem with another camera: no matter what position of the lock on the card was, the camera kept saying "card locked". I got the card out and looked inside the space where the card resided. There's a small pin there that is responsible for sensing the lock on the card. Sometimes the pin gets "tired" and you have to raise it a little bit: just try to straighten it up with a clip or a nail.
After I did it, the problem was solved.
Jul 05, 2012 | Canon PowerShot A570 IS Digital Camera
I HAVE A NOKIA 5130 XPRESS MUSIC HAND SET AND ITS MEMORY CARD IS NOW LOCKED .IF ANY SOLUTION FOR THIS PROBLEM?
Hi sunilkumsrmo
  • Just format your memory card ..
  • It will be cleared
  • else you don't want to lose the memory card data means go to ->this link i attached it and download that recovery software and recover the data,then you format the card the lock will be cleared....
Jan 01, 2011 | SanDisk 2GB microSD Memory Card
To clear sd memory card password
i cant to delete files from my memory card
Mar 20, 2010 | SanDisk 2GB microSD Memory Card
Get the error The Card is locked when I switch on
lock and unlock option is on the card,select unlock option,then try.
Mar 09, 2010 | Casio Exilim EX-S880 Digital Camera
Kid tough fisher price digital camera won't work
Maybe your card has the lock on. Remove the memory card from the camera and check the lock on the actual card. This may be your problem.
Nov 24, 2009 | Fisher Price Fisher-Price L8341 Digital...
Canon A620 LCD shows "memory card locked" for each card I insert
This worked for me!  I have the Canon Powershot SD780 IS and although my card WAS NOT locked, the camera "malfunctioned" and the switch in the camera needed to be gently pushed back IN, not DOWN on my specific camera type.  This is great, I was just going to go out and buy another camera today!  Thanks for the post Stephan!
Nov 10, 2009 | Canon PowerShot A620 Digital Camera
How to clear memory card, error card lock on a
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Oct 11, 2009 | Canon PowerShot A630 Digital Camera
My vivitar camera when openned staes card locked how do i clear this
on the left side of the memory card there is a lock switch. if the switch is up, its not locked. if the switch is down, its locked. theres also another type of sd card when theres a tiney memory card that goes in the bigger one. take the tiny card out and its locked. put it in and its unlocked. did i help?
Oct 09, 2009 | Cameras
My camera wont take pictures says card locked
There is a lock on the SD card
Check this is good.
Regards
Richard.
Feb 02, 2009 | Vivitar ViviCam 3935 Digital Camera
Pentax Optio M30 - screen reads CARD LOCKED How do I clear??
the sd card has a lock on it, switch it in the up position. this will take it out of lock. good luck
Jan 22, 2009 | Pentax Optio M30 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
