Question about Haier BC112G Wine Cooler
Motor in wine frige is noisy???why - Haier BC112G Wine Cooler
  • Haier Master
  • 909 Answers
That motor is an evaporator fan motor. That noise occurs when the bushes in the motor start to wear. The motor is not in effect repairable but has to be replaced. Normally a 9 watt evaporator fan motor is installed into those wine coolers.
Posted on Aug 31, 2010
Compressor in our wine fridge is getting pretty noisy, what do I need to do?
If you mean the motor for the fan because a condenser is just a type of radiator. So the condenser fan motor must be the noise if you are sure the refrigerant pump is not the noise..
Dec 07, 2016 | Optics
FAN MOTOR MAKING NOISE SLOWING UP BEEN RUNING ABAUT 6 YEARS FIRST PROBLEM EVER
The motors are filling up with dust and dirt that's why it getting noisy and slowing down. You can spray chemicals to the motor shaft like WD-40 to loosen the dirt that has accumulated and make the motor run smoothly again. Further, you can put a bit of oil to the motor shaft to make it run smoother for a longer time. To do this, you'll have to disassemble the motor to expose the motor shaft (a piece of metal that connects the propeller to the motor coil).
Apr 02, 2014 | Danby DWC283BLS Wine Cooler
Noisy fan problem solved..... at least for now.
Not familiar with Danby or wine coolers, but I have messed with enough appliances including fridges. The same exact fan and motor are often used by different manufacturers and are "off the shelf" items you can get at most appliance parts suppliers. See if you can get any part numbers or info off the fan motor or from Danby's web site. Then see if a local supplier has one. If the fan has spade connectors, you may be able to swap it out without having to cut/splice wires.
Oct 15, 2012 | Danby DWC283BLS Wine Cooler
Why are wine coolers so noisy?
Compressor-run wine coolers may be slightly noisy at times; however thermoelectric coolers are completely silent.
Jul 31, 2012 | Furniture
Noisy when running
condenser fan blades are cover with lint or the fan motor may be going out. Clean fan blade first before doing anything else. If noise stops after cleaning the fan blades; hooray! If not you might have to replace the fan motor itself. Test and re-check before taking other step(s)
Jan 04, 2011 | Haier BC112G Wine Cooler
Fridge fan motor is making a wining noise constantly when fridge is shut, seems continually cooling
if fan motor making noise its not turning fast enuff to get frige cold enuff to shut off replace it
Dec 27, 2009 | Fisher Refrigerators
I have an LG GR-409GUPA Frige Freezer which has recently started being very noisy, not all the time, but periodically when the motor kicks in. Sometimes it stops if you open the freezer door, and sometimes...
Weak motor spring lets motor hit shell on startup due to torque. experiment with Shimming the motor mounts to reduce/eliminate noise.
Has no effect on motor performance/longevity.
Sep 08, 2017 | LG LFD22860 Stainless Steel Bottom Freezer...
Strange noise coming from new Oster 5 c.f. frige...
I did not post a problem with a wine cooler...We all know that problem was caused by the wrong fuse that was installed at the factory.. My question was about the Oster 5 C.F. frige...no, I did not get any answers...No, I do not want your premium service...I just thought I may get some free insight on my problem...
Dec 17, 2008 | Oster 12-Bottle Wine Cellar - Black
Haier HVT12ABS Not cooling noisy motor
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you bought it before 2006 you have 1 year parts and labor, and 5 years on the motor ! if you called them and they told you one year, they must not have known the date you bought it!
Try the manufacture!!!!!!!!!!!!!!!
They will have the part
Discount Parts
Major Appliance
& Consumer Electronic Parts.
TOLL FREE 1-(888)-338-3790
8:00AM - 12:00 MIDNIGHT
7- DAYS A WEEK
Please rate me solved before you sign off.
Thank You
Sep 14, 2008 | Haier HVT12ABS Compact Wine Cooler
Haier BC112G Wine Cooler Logo
670 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
