Question about Sony KP-51WS500 51" Rear Projection Television
Hi. I own a Sony KP-51WS500 rear projection system where several months ago the red arced lines started to appear accross the entire screen, dim at first but growing in intensity. In the last few days the whole image began to turn pinkish (less intense in HD channels, but more intense in dark scenes), but today all went nearly solid red. There is an error light flashing 5 blinks on the front panel, and the red CRT is running very hot (I took off the back cover). There is also a black 'bladder' on the front of the CRT frame that is buldging out, which I assume is the cooling fluid pressure relief. I assume that the red CRT is failing and is being overdriven by the AGC. If so, is a replacement CRT available, and is it worth fixing?
  • ebmfuser Aug 31, 2010
    Sounds like a plan. I would like your assistance (instructions) with this. Thanks again.
    Top Expert:
  • Sony Master
  • 14,553 Answers
This is a model prone to all three tubes failing in this way. When the sets were less than a year old there was a program from Sony to replace all three tubes--it seems the wrong tubes were installed.
The tubes are now only available on a rebuild basis--take out old one and send out for rebuild and very expensive.
An alternative exists, it involves (in your case red) getting at the RED SCREEN CONTROL AND TURNING IT DOWN UNTIL THE SET DOES NOT SHUT DOWN and then adjusting it further. No parts will be involved and should take less than 20 minutes.
Set will shut down if screen turns bright red, green or blue as it detects too much current is being drawn.
If you want to know how to attempt this, rate this solution as very helpful and I will assist you.
SD TECH
Posted on Aug 31, 2010
Testimonial: "I got the info I needed, and quickly. Great job."
  • 3 more comments
  • aharman3 Oct 02, 2010
    could you please send me the solution? Very helpful!!!
  • 4gilberts Nov 03, 2010
    Having this same problem...can you help?
  • bozzie4402 Dec 11, 2010
    I am having the same problem but now my screen is completely black...please help!
  • Shelley Whiteside
    Shelley Whiteside Jan 30, 2011
    I am having the same problem, only with green. Could you help me with what I need to do to make the needed adjustment? Thank you.
  • Jessica Pollinger May 19, 2011
    I am getting the blue screen. Will this work for me as well? I would love to be able to still use this TV!
KP-51WS500 it started a couple months ago the
Hi, that is look like ,,you have defective convergence module if it is a dlp it is probly the light bulb,
hope that will help you to find a good tech
to fix it.
have a nice day
May 05, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 tv went red screen on me it has 4 blue lines going across also has blinks 6 times.. what do you think this might be..
Off hand I would con dim the Red and Blue CRT"s. If you were to replace two of them I would also do the Green CRT as well. The cost of just doing two of them is way too expensive in my opinion and you would be better served to replace the set instead of investing the amount of money needed in a 6-8 yr. old set.
Hope this helps,
Skyassoc
Jul 15, 2009 | Sony KP-51WS500 51" Rear Projection...
Red lines across screen
had tv that did the same thing after three years but they were green cost me 300 bucks to get it fixed and the guy said every 3 to 5 expect it
Jul 03, 2009 | Sony KP-51WS500 51" Rear Projection...
Red screen and lines, then TV shuts off automatically
Adjust RED screen drive down, or disconnect,unplug CRT board from red tube turn set back on if it plays without shuting off RED tube is shorted or video IC on CRT board is bad.
Jun 19, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Faint red curved lines on Sony KP 51ws500.Converged = no work???
Hi There!
This sounds like a typical problem related to a older CRT.
If you remove the front cover of the tv, you can then remove a wood panel. Behind this panel you will see a block (high voltage splitter) it will have 6 "knobs" on it, 3 will say focus, 3 will say screen.
They will also be labeled R - G - B
Put the tv on a blank input so you can see the lines clearly on a black screen  - Find the knob for red, and SLIGHTLY turn it down until the red lines disappear.
Dec 22, 2008 | Sony KP-51WS500 51" Rear Projection...
Screen slowly turns blue...
I had blue lines showing up on my screen, then the other night my screen started to flutter the blue, bright to dim and back. So I followed this link to resolve the blue lines and the blue flutter was resolved as well. Hope this helps.
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Jul 26, 2008 | Sony KP-51WS500 51" Rear Projection...
KP-51WS500
Try this link it has many great reviews. It is very informative for the DIY.
Nov 28, 2007 | Sony KP-53HS30 53" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
273 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
