Question about Toshiba Satellite A135-S2276 Notebook
Hard disk for toshiba satellite 5205 isnt available...can i change my bios setting and use some other hard disk???
Hello\r\nHard disk for toshiba satellite laptop is not funtion. my hard is vaberation in drive. and don't disply any text on lcd. so what is sulotion of harddisk with out formating.
please detial given
Posted on Sep 03, 2010
  • 113 Answers
Yeah u can
Posted on Aug 31, 2010
Toshiba Satellite L355D-S7815 re-soldered cmos battery onto mother board and re-set the bios, now I have the f2 and f12 option available, tried to boot cd/dvd drive with windows 8 disk and it will not
Go into the BIOS setting abd check it the BIOS detects the hard disk and CD/DVD drive.
If it detects these drives then go to the boot device order and select the CD as the first boot device then the hard disk as the 2nd boot device.
Apr 03, 2013 | Computers & Internet
How to change disk controller in bios on Toshiba Satellite A135-s2276?
Hello here is the homepage:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1596141&
You need this for the drivers.
And you can downlaod a manual
Press the "F2" key to access the Toshiba Satellite's BIOS menu. Use the right arrow key to navigate to the BIOS tab labeled "Boot."
Read more: How to Change the Boot Order for a Toshiba Satellite ' eHow.com http://www.ehow.com/how_6383103_change-boot-order-toshiba-satellite.html#ixzz2Cn6HdU2k
Turn on or restart your computer and watch for a message during the post about a particular key, usually Del or F2, that you'll need to press to ...enter SETUP. Press this key as soon as you see the message.
Go to boot and select the boot order.Use F4 or F5 to change.
First boot device: Cd/dvd drive
Second: the harddrive.
Leave the bios and save the settings.
Place your windows cd in the drive and reboot.
Now you can install windows again.
Good luck
Nov 20, 2012 | Toshiba Satellite A135-S2276 Notebook
How to do i enter bios setup in toshiba 5205-s705
Hold down the F1 key, then, while continuing to hold it down, press the power switch. the system will turn on, then prompt you to check system and press F2 (thats from memory, it maybe F1 again) to enter BIOS.
With many Toshibas you can hold down any key to do this, as it simply generates a keyboard error, prompting the same message.
Hope this info helps.
May 19, 2012 | Toshiba Satellite 5205-S705 Notebook
Forget password bios toshiba satlite 5205
To reset the BIOS read the information from this link.
In case of your Toshiba Satellite laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Oct 20, 2010 | Toshiba Satellite 5205-S503 Notebook
I have to change the body of the Toshiba Satellite 5205-S705 Laptop. I want to know how to open the laptop ?
Try this link and have step by step of disassembling of your laptop.
www.irisvista.com/tech/laptops/Toshiba1415/sat1415_1.htm
Aug 25, 2009 | Toshiba Satellite Satellite 5205-S119...
Toshiba satellite 5005-S504 boots over and over and over non stop
It sounds like the hard drive is dying. I had a computer do the same thing and it turned out to be the hard drive. You should still be able to access the bios though. Try hittind either delete or F1 as soon as your toshiba screen appears.
Jul 10, 2009 | Toshiba Satellite 5005-S504 Notebook
Hard disk not found error during Clean XP home Install
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jul 04, 2009 | Toshiba Satellite A35-S1592 Notebook
5205-s503
Its a little lengthly to explain so I pasted the website that talks about what to do with a Hard Drive Password Lock. Good luck and let me know if you have any questions. Rate this with 4 diamonds before logging off..here is the website:
http://www.computing.net/answers/security/hard-drive-password/14916.html
Mar 07, 2009 | Toshiba Satellite 5205-S503 Notebook
Hard drive failed - replaced 60GB with 250 GB M35X can't format
Does your BIOS recognize the new hard drive?
Are you reinstalling from a Toshiba recovery disk or an operating system disk?
Additionally, there is a setting in the BIOS to turn on or off ACPI function for the hard drive. Find this in the BIOS, change it, and try reinstalling again.
When it works, be sure to change it back after installation.
Good luck.
tony
Jan 30, 2009 | Toshiba Satellite M35X-S109 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
