Question about Bosch WFMC 3200 Front Load Washer
Metal door hinge broke off on Bosch model WFMC3200UC. Need replaement hinge
4 Suggested Answers
SOURCE: BOSCH WASHER REPLACEMENT PART
I have the same problem. Bosch no longer stocks the replacement for my particular washer which has the same model no but could be a different fd #. I now have the wrong part as directed by bosch which doesnt have the hose connection. I am not sure what to do with the hose leading to nowhere. Bosch is living off of an undeserved good reputation.
In the present, the reputation is not deserved. Bosch products should only be recommended to enemies. The company and the especially the customer service is beyond deplorable. I hate these appliances. I feel ripped off! The part by the way, which is wrong, is 100.00 with tax.
Posted on Jun 05, 2008
SOURCE: Bosch WFMC3200UC
I'm having a hard time understanding what is happening with my Bosch. Mine is filling and then immediately emptying out. Then the door unlocks but the timer indicates 45 minutes left (or so) and the door lock light is still on. Usually the only cycle that spins now is the spin cycle, but this doesn't help me get the soap out of the clothes still in the drum.
When the machine fills but doesn't rotate, the water level seems low as well. I had a repair man out who thought it might be the door latch sensor needing replacing (honestly, my toddler was pushing that button repeatedly), but I don't think that's it.
What does work: I unplug it for a while. Then if I'm lucky and the laundry Gods are shining down on me, I can wash normally (usually I'm luckier on Permanent Press but I always used to use the Cotton side). However, once I turn the machine "off," that's it all the problems persist so I have to wash it all, one load after another.
Posted on Aug 20, 2008
  • 3 Answers
SOURCE: BOSCH WFMC3200UC WASHER
Go to http://www.repairclinic.com/SmartSearch/smartsearch.aspx and type WFMC3200UC under search at top. Then select gasket/seal/o-ring from part type drop down menu.
Posted on Sep 15, 2008
How do I repair/replace a broken door?
Hello there, you will need a new hinge and probably the inside round piece of the door. Can you upload a photo? Please indicate the
E-Nr of the machine. You can find it on the label around the door and/or at the back of machine.
Jul 02, 2015 | Bosch Washing Machines
I HAVE A BOSCH FRONT LOAD WASH MACHINE MODEL WFMC3200UC. IT WILL FILL AND THE LIGHT COME ON TO WASH AND THEN IT STARTS PUMPING OUT THE WATER.
B This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Sep 02, 2011 | Bosch WFMC 3200 Front Load Washer
Need instructions for moving -- have four bolts!
Hi.
Here the full set of instructions for the model Bosch WFMC 3200 posted in title:
WFMC3200UC/01 Manual 1
WFMC3200UC/01 Manual 2
Here repair manual available for $9.95.
Regards.
Ginko
Jun 07, 2011 | Bosch WFMC 3200 Front Load Washer
Door Fell Off and broke off the hinges Not the hinge itself but the white plastic part of the door that attaches to them How can I fix it
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number. You could also try the Bosch site direct.
Good luck,
John C
Mar 21, 2011 | Bosch WFMC2100UC Nexxt Essence Washer
I have a Dometic rm2652 refrigerator the door hinge broke
the hinge is not plastic, only the insert sleeve that goes into the hole atop the door is plastic. If the actual hinge (metal arm) is broke, then you need to order a new part (not difficult if frig is 20 years or less). If you cannot find the part, go to a metal shop and show them the broken part, they usually can repair it or remake a new piece.
If the hole in the door went bad (that is: if the hole tore open and cannot hold the hinge pin) you need to have a metal repair brace added to the door. This will involve the metal shop or a good mechanic that can come to you and do the neccessary repair at the house; otherwise you need to bring the door to the metal shop. macgivor
Dec 27, 2009 | Dometic RM2652 Refrigerator
Door hinge is broke on Bosch Axxis+ Front loader
There are 4 screws in the door that hold a plastic hinge cover on
.The door will then set into the hinge just fine (PLENTY OF ROOM) and then you put the hinge cover back on and screw the screws in to hold the door onto the hinge.You will likely need a 2nd set of hands to keep from breaking the door.
Oct 10, 2017 | Bosch Axxis WFL 2060 Front Load Washer
Front Door Seal
Call the Customer Service number located in your manual. Discribe to them what you have said here and they will send one to you for FREE! This is a problem that should NOT happen.
Moving forward, once you get it spray it down with Lysol Mold and Mildew Prevention and let it dry a couple of days before you install it.
May 13, 2008 | Washing Machines
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Apr 28, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
50 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
