Question about Homelite Mighty Lite Lawn Trimmer
Primer bulb is broken. Is it relplaceable? - Homelite Mighty Lite Lawn Trimmer
  • 183 Answers
Yes. Even though your Homelite trimmer probably has a RuiXing carburetor on it, Zama makes a primer bulb that fits it. The Zama part #0057004 will fit perfectly. Your local repair shop should keep this part in stock, or try www.amazon.com
Posted on Aug 31, 2010
Is the primer bulb replacable on 200 classic chainsaw.or do I have to buy a new gas cap.
Hi Shirley:
My apologies if I'm incorrect, but I've never seen a chainsaw that had the primer bulb connected to the gas cap.
So,,,,,
I'm hoping you're asking two questions at the same time.
1) Primer bulbs are replaceable but it's extremely rare that it is necessary
2) Gas caps are replaceable but only needs to be done if they are broken.
If you reply as a comment on this post I'll be able to respond to you.
Cheers.
Oct 14, 2015 | Homelite Garden
Primer bulb broken(in fact the rubber is broken)can you please tell me how to change the rubber part? and also the throttle doesnt functioning properly( only maximum)
Look in where the bulb goes into the shroud. There will be a snap ring in there. just remove the snap ring and the bulb will come out. Make sure you replace the snap ring and check the hose to the carb.
May 06, 2013 | Briggs & Stratton Garden
Tecumseh carburetor primer not working
thehole for primer fuel is clogged have to rebuild carb
May 06, 2013 | Garden
Primer bulb does not work
if you have gas in the primer bulb its working. gas is sucked from tank to carb , out return tube to primer bulb and back to the tank from the primer bulb. most likely dirt in carb or hard diaphram not opening needle valve allowing fuel to be sent. carb kits are around 12 bucks . but carbs for troybilts are usually only 20 bucks. I would just replace the whole carb if the case. if the bulb stayed empty I would look for broken fuel line in the tank that holds the fuel filter. they rot and break off within a year or two.
Apr 20, 2012 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
How to instal primer plunger on Toro Snow blower 1000E
The new primer bulb should have come with a plastic retaining ring. If you have the new ring then pull the old ring and primer bulb out with long nose pliers.
Then you insert the new rubber bulb until the outer part of the bulb face mates with the carb face. Then install the ring press both pieces into place until it is just below flush.
(If the new bulb did not come with a new plastic ring... you are going to have to ever so gently coax the old ring out with your fingers crossed hoping it does not break.) I have personally broken more than 50% of the old rings... trying to get them out.
Thanks for using FixYa.
Kelly
Apr 21, 2010 | Toro Lawn Mower With Toro Power Tools
My primer button as broken how to replace it and where to buy the
Lowes Home Improvement store carries them, also lawnmower repair stores have parts departments that have them. Mine cost about seven dollars.
Apr 19, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
When I try to use the primer bulb there is no air
check your filter and lines. one may be broken, also your primer may be bad replace it and any bad lines you find
Oct 17, 2009 | Troy Garden
I have a McCulloch 3200 chainsaw on which I installed a new primer bulb and fuel lines. The old fuel lines were broken. I figured out which line runs to the carb from the primer bulb but where does the...
From the fuel tank to the carb, from the carb to the primer, from the primer back to the fuel tank. The bulb sucks fuel through the carb excess fuel is returned to the tank. HTH
Lou
Oct 08, 2009 | McCulloch Garden
Primer bulb does not fill with gas
Check the primer bulb for cracks,it will not pump gas if it is torn or cracked. Then check line from bulb to gas tank to see if there connected or are broken.
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Homelite Mighty Lite Lawn Trimmer  Logo
343 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
