Question about Apple iPod MA446LL/A MP3 Player
My ipod model a1136
My ipod does't turn on when i press the select button a battery sign pops up with a triangle on front
Could you please help me?
I have an Ipod A1136 EMC2065. Serial number 9C72736FV9R.
My ipod is got wet and transtor burnt. I want to replace the transtor and I don't know the number of transtor. Can you tell me?
NKRLCMLO
Posted on Oct 10, 2008
  • 22 Answers
That means that you need to charge your ipod i had a simmilar problem ith a Zen NEON last week.
Let me know if it works jayden.mills1@education.nsw.gov.au
Posted on May 09, 2008
How do I delete videos
You can remove the videos by:
1. Open Videos.
2. Select Camera Videos.
3. Select a video.
4. Press and hold the Center button.
5. Select Delete, or to remove all the videos, select Delete All.
Or you can wipe the entire iPod by:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Jan 12, 2010 | Apple iPod nano
Ipod model no A1136 FROZEN : DO NOT DISCONNECT , CANT RUN
Try reseting it, It worked for me. Hold down the "Menu" button and the middle button for about 7-10 seconds.
Hope this helps!
Nov 07, 2009 | Apple iPod MA446LL/A MP3 Player
I want to know which generation is the Ipod 30G model A1136, thanks
There are two 5th gen iPods, A1136 model is the older 2005 model, not the later 2006 model.
Here is Apples link: http://support.apple.com/kb/HT1353#ipodfifth2 which will show the differences, but not by model number. The reason I know this model number is the first 5th gen 2005 is because I have one. Also older 2005 should have '2005' engraved on rear.
May 29, 2009 | Apple iPod classic 5th Generation
My mini ipod freezing, showing charger sign i could not turn it to menu
I would attempt putting the ipod into disc mode and see if your ipod is recognized by the computer after you reconnect it. I have researched this issue and found a knowledge base article on apples web site that may help you out with this.
Here are the steps to do it...
Putting iPods with a Click Wheel into disk mode
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
If it won't go into disc mode while not connected to your computer, try doing the above steps with it already connected to you computer.
If none of these steps work, it is sadly probably time to get a new ipod. I hope that it does help you out though. Good luck :)
Apr 22, 2009 | Apple iPod mini M9160LL/A MP3 Player
Ipod 30gb battery shuts off in 30 minutes
your issue could be one of 2 things.
Either your battery is becoming old and needs to be replaced or your mainboard is malfunctioning and causing the low battery signal.
If you have your music library backed up in iTunes, I would connect the iPod and restore the firmware. You can accomplish this by pressing the restore button in itunes.
If your battery is more than 2 years old, replace it and see if the problem goes away,
Mar 04, 2009 | Apple iPod MA446LL/A MP3 Player
How can I power on and power off my apple ipod a1136 model?
Generally speaking, if you have connected it to a power source when it has completly drained it should display 'Please Wait, Very Low Battery' (without the backlight). If it does, leave it until that message disappears. Pressing the play button should now wake it. However, If you have been charging it for a while and nothing has been displayed the battery my be dead all together. With the iPod connected press the Select and Menu Buttons together until an Apple symbol appears (non-backlit) it should then startup. If it turns off when disconnected from the power then you have a dead battery. If none of that solve it I offer a repair service at a very low cost.
Dec 13, 2008 | Apple iPod MA446LL/A MP3 Player
Battery Drain
Try to reset the ipod
Nov 28, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod A1136
press and hold the play/pause button for atleast 5 seconds that should do it, if not the click wheel is messed up
Sep 01, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod Model A1136, 30 GB.
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Feb 14, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MA446LL/A MP3 Player Logo
305 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
