Question about Yamaha Audio Players & Recorders
Hi there , I have a question for you and hope you can help me answer. I have a subwoofer that hasn't been switch on for a few years and it is neither connected to the mains outlet nor connected to any electrical device . The only thing the subwoofer is connected to is a pair of satellite speakers and the switch on the subwoofer itself is switched off . What happened is that when i used a electronic multimeter to test the plug ends of one of the speaker cables (a 1/4 inch connector that is meant for the satellite speakers) that is connected to the subwoofer , it shows some currents that averages around 18-22mV and it fluctuates greatly. What I need to know is , if the subwoofer is already at OFF position , why does the multimeter shows some current ? Is there any current generating from the subwoofer at all even if it was switched off for a few years ? The model in question is Yamaha MS50DR .
robotek
  • 1512 Answers
SOURCE: Goodmans Amplifier Speakers , Humming, Capacitor wrong way still worked for a year!
Hi, wow...caps of that value usually go boom real quick when fitted back to front. I too am amazed it has functioned that long. Just double check that incorrect screen printing on the board has not tricked you. Have you put your multimeter across the bottom of it to actually see constant reverse DC volts(ignoring the board markings for now). then replace the offending items, just check that the voltage they are being run at is at least 2-3 volts less than 50v rating of the cap. alot of gear runs really close these days and the supply caps fail early, we see alot of it here in Australia where our supply is 240v you see it at the socket alot of the time at 250-255v Hard on gear designed originally for 220v. I would sub the caps out with 63 volters anyway to be sure of some longevity. Good luck, I am interested to know how you go. Let me know please.
regards
Graeme
Posted on Feb 29, 2008
Agent Jason
  • 78 Answers
SOURCE: Connecting multiple A/V cables to 1 TV
Hi zantar412,
Yes, there are devices to help you. You should shop for an “RF Modulator.” While the intention of this box is convert an A/V signal to RF for older televisions, many modulators offer multiple inputs which can be chosen with a switch. Be sure to check both the input and output options on the box that you buy to ensure it will be compatible with your components and television.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 30, 2008
lynchms
  • 93 Answers
SOURCE: best hook- up Polk psw10 sub woofer to yamaha rx-v663 receiver
You will not need to y connect your subwoofer, if you have only one RCA sub out on your receiver the other end of the RCA connector cable goes into the left input on most powered subs, there is no loss of signal, the option exist as some receiver do sport a double RCA sub out.
Posted on Feb 12, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
sergiomc1
SOURCE: Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Posted on May 09, 2009
Seems like lots of these questions that haven't been answered are more than just a few years old. Why doesn't someoen go though the questions and bring them up to date. I have.. but seems just everyon
Hi Allen,
You'd be surprised how many people you would be helping even by answering old questions. Some people may have the same issue even if the question was asked some time ago.
I also see older questions, but if possible I still answer them to help anyone that might have the same issue.
Welcome to Fixya and I hope that helps to clarify.
Sep 04, 2014 | FixYa Computers & Internet
Hey, I hope someone could help me out! I got a sunfire EQ 12 true signature subwoofer. It worked great at beginning. However, the issue is auto off. It will turn off after a few minutes no matter for...
Auto-off will be a software issue, so no, you can't turn it off. Send it back as a warranty repair. They have a 1, 3, or 5 year warranty. Look at the the support page. Also shows factory repair.
SUNFIRE True Subwoofer EQ 12 Signature TS EQ12
Jul 29, 2017 | Audio Players & Recorders
I hooked up the radio and drove around the block while it was playing then when I shut off the truck and went to turn it on the next minute the radio would not play. What wrong?
First, I hope you used a wiring harness to install the radio. If not, I recommend you reverse the work you did, purchase a wiring harness and use it. As for the specific question, it sounds like you have your power leads connected wrong. There are two powers, a constant and a switched. If you hooked everything up with the key in the switched position, that wire will appear to be constant. Check those two things. Also, make sure your ground hasn't worked loose. Happy hunting
Aug 22, 2011 | Car Audio & Video
We've been given a spare Bosch Maxx 900 washing machine by friends which hasn't been used for a few years. Have plugged it in, connected the hoses, and switched it on for a standard cycle 40...
Hello is this a front loader machine and if so in the back of the machine there are 4 bolts that go thru a 3' piece of plastic. they should be around the drum area they use these to keep drum stable while being transported so look for them. Hope this helps you out
Jul 21, 2011 | Bosch Washing Machines
GE MICROWAVE jvm13508w 002 trips circuit breaker when pressing start button, runs for a second or two then i have to reset at breaker panel only microwave and gas stove clock on this circuit. beendoing...
Years? Wow! I'm glad it hasn't caused a serious problem or fire!
In some cases, this is due to a bad door switch or door switch mount, or a shorting high voltage capacitor.
If you or someone you know can do testing, first see these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Then see this:
http://www.gallawa.com/microtech/cap_test.html
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
That model should be "JVM1350BW002", by the way.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
May 24, 2011 | Microwave Ovens
Subwoofer suddenly making buzzing sound but is not hooked up to anything,fuses arent blown and its been in the same spot for a few years and never had a problem.happened suddenly.moved it to another spot...
hi pls make sure that there isn't any other magnetic or electromagnetic device near the speakers because due to induction ur speakers magnetic field gets distorted which makes that buzzing sound irrespective of no fault wiring may be this may help u or see that the wiring near the woofers speaker magnet is attached strongly so that it doesn't distorts any more was this helpful if yes pls vote
with warm regards - bonefirediv
Mar 25, 2011 | Car Audio & Video
The driver power seat on my 2005 Cadillac STS have stopped working. I have changed the fuses and relay switch and it's still not working what could it be?
If non of the power controls for that seat are working, then I would check the plug under the seat and make sure it hasn`t come loose. Hope this helps
Please take a moment to rate my answer............Thanks
Dec 01, 2010 | 2005 Cadillac STS
Hi I bought Razer Mako speakers few days ago, and from the start i've got this problem... The speakers stop working (there's no sound) after few minutes (from 7 to 15) of playing, the same for different...
I had the same problem today. Don't know what caused it. But I turned off the Makos using the switch behind the subwoofer waited about a minute then turned them back on, problem solved.
Hope this helps you and others who encounter this problem.
Sep 07, 2010 | Razer Mako 2.1 Speakers
Center/subwoofer speaker out...mixed
Hi all, I also purchased a logitech x-540 a few days ago and also have the center speaker outputting sound when i test or play the subwoofer. I didn't think this is normal and am now confused. Maybe its a problem with the audio drivers? MB is a ASUS P6T Deluxe V2 with Soundmax drivers. Hopefully someone can help to diagnose/ find a soluytion.
Jun 27, 2009 | Logitech X-540 Computer Speakers
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
