Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
I am trying to update the firmware on my Sharp LC32D47UT but it can't read it off of my USB
3 Suggested Answers
  • 8909 Answers
SOURCE: Is the Sharp LC32D47UT 32-Inch
Quite possibly as it can cope with NTSC and PAL
The elegant AQUOS® LC-32D47UT easily enhances the decor of any family room, living room or den. With a 16:9 aspect ratio, HDTV resolution of 1366 x 768 and breathtaking color purity, it is a next-generation TV to carry you into the high-definition future. The LC-32D47UT features a high contrast ratio, 6ms response time and wide viewing angles. The LC-32D47UT includes built-in ATSC/QAM/NTSC tuners, 3 HDMI™ and 2 HD Component Video inputs as well as a D-sub, 15-pin input for PC compatibility. The LC-32D47UT features a black cabinet, and the included table stand easily removes for wall mounting applications.
Features
  • True 16:9 - widescreen aspect ratio with 1366 x 768 HDTV resolution.
  • Built-in ATSC/QAM/NTSC Tuners - provide access to DTV and available analog TV channels.
  • High Brightness - Sharp LCD TVs are very bright, so you can put them virtually anywhere - even near windows, doors or other light sources - and the picture is still vivid.
Posted on Jan 08, 2011
SOURCE: how to update sharp aquos lc32d64u firmware
I was able to successfully update my Sharp's firmware by using a USB drive that was:1) formatted in (fat, not fat32)2) had only the one update file (.uvp) and3) a small USB drive (4gb - other posts said 2gb or less)
Posted on Nov 25, 2011
How do i upgrade firmware of sharp mx2700n copier
To update the firmware, set DIP SW 2 on the MFP control PWB to ON.
1) Insert the USB memory into the machine.
* When USB is not connected, "INSERT A STORAGE FIRMWARE STORED ON" is displayed. When [OK] button is pressed, the display is shifted to the folder or file selection screen.
2) When a firmware update folder or file button is pressed, the display is shifted to the firmware update screen.
* The number of buttons depends on the number of files in the inserted USB memory.
A folder name or file name is displayed on the button.
If the folder name or file name is of more than 34 characters, only 34 characters are displayed.
For a folder name, "<DIR>" is displayed at the head.
* When [ .. ] button is pressed on the file selection screen, the display is shifted to the folder or file selection screen. On the folder or file selection screen, the keys are disabled.
* The path of the folder or file is displayed on the title section.
If the path is of more than 50 characters, only 50 characters are displayed.
Read more >> http://electrohelponline.blogspot.com/
Aug 19, 2016 | Sharp MX-2700N copier
Mx-2300n firmware
The firmware is only available from a dealer. You can make an arrangement to get it on a USB thumb drive and update the machine using SIM 49
Apr 19, 2014 | Sharp MX-2300N Color Copier
I've got the sharp aquos 42" and when I try to
First,you have to go to www.sharpusa.com and look up your model number and see if there is updated firmware. If there is then download it to a flash stick then install it into your usb port and follow the directions. If your model is not onstar.gif the list PLEASE DON'T download just any firmware update.
Dec 27, 2010 | Sharp Televison & Video
Blue ray won't play Avatar?
There is a firmware update for the BD-HP22. I had the same problem with Avatar but after I installed the firmware update, it loaded and ran smooth. Use the USB flash drive that came with the player or any other usb flash drive to load the firmware update. Check the link below for instructions and update file from Sharp's website.
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
May 03, 2010 | Sharp BD-HP22U Player
I downloaded the firmware update for my sharp bp-hp20 blue ray player but my player won't recognize the file on my memory stick. Any suggestions?
There are usually two reasons that this happens 1. is that the file needs to be extracted first to the root of the drive ie. not in any folders. 2. is that some of the older sharp products won't reckonize any usb memory larger than 1GB. As is the case with my 52' Sharp AQUOS Special Edition LC-52SE94u TV. Could not read a 2GB Kingston, but reads the 1GB Kingston just fine to update firmware. And Sharp doen't tell you this not even in the online how to firmware update page.
Hope this solver you problem,
Scott
Mar 21, 2010 | Sharp AQUOS Blu-ray Disc Player
How to update sharp aquos lc32d64u firmware. won't read from usb device to update S0803271 to S0909081. firmware name is "SAL2A217.UVP"
Feb 08, 2010 | Sharp LC-32D64U LCD TV
Need firmware update
Download the file from here
Then upload the file to flash drive/thumb drive ( it has to be usb 2.0 , formatted FAT, capacity 1Gb or below)
Stick the drive into BD player.
Select setup>firmware upgrade.
Follow on screen instructions.
Nov 16, 2009 | Sharp BDHP20U Blu-Ray Player
Sharp BD HP21 Won't recognize USB drives
You have to make sure the files, you downloaded to your USB stick, are not in folders. Mine worked after this. I am still having problems with pixelation on newish discs. I read somewhere that if I plugged a USB thumb drive into the Sharp HP21 it will aid the processing and work better. Does anyone know if this is true as I often get poor picture quality on what looks clean LoveFilm BR discs. (No problems with standard DVDs.)
Sep 30, 2009 | Sharp AQUOS Blu-ray Disc Player
Sharp bd hp20x will not play the new "x files" blu ray disc movie. The on screen message is that I require an upgrade from the manufacturer to play this blu ray can you help please.
If you contact Sharp via the website, you can order a firmware update cd from them, or download one from the website (CD or usb version) Follow the instructions and within 5 minutes your firmware will be updated.
Worked on mine :)
Dec 05, 2008 | Sharp Televison & Video
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
100 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
