Question about Kenwood KAC 6201 Car Audio Amplifier
I have a California Profile AP1000M amp and i bought it used. It worked fine for @ a week. Now I turn off my car and the amp stays on. I even put an in-line toggle on the remote wire. Even with the remote wire disconnected, the power stays on. The amp plays fine, but it gets hot as hell. Ive tried almost everything to check the problem. What could the problem be? It has a good ground, new remote wire, etc.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Kenwood Master
  • 2,226 Answers
You probably have a shorted part inside the amp
Posted on Aug 31, 2010
How do I connect a DVC (4 ohms each) single subwoofer to a Profile California 2600 amp (2 ch. with bridging) for best match?
As long as you are using only one rca signal input, and physically splitting it with a splitter or even just leaving only one channel connected, and the other empty, wire each coil to each of the amp channels. There won't be stereo separation (of your woofer). It should be ok. Better than 2ohm bridged load, or 8 ohm. You will lose output at 8 ohms, but your amp will never overheat and your soeakers will last forever. Lol.
Feb 03, 2015 | Profile Car Audio & Video
Takagi t-k3 runs hot on low to med flow on high turns cold & flame shuts off
OMG 95 PSI is too high a pressure for a tankless! What was the W.C. in inches on the manometer?
Also on a T-K3 12 isn't a Code but a partial Code. You need an R/C to make this easier as counting led flashes produces wrong codes.
you'll have to find the correct code it's throwing not a partial.
And put a Pressure Reducer on this to below 60 PSI. 95 PSI is only impressive when it blows the tubing out after a few years.
Call Takagi in California not A.O. Smith in TN and they'll help someone fix this
Sep 20, 2014 | RTO Takagi T-K3 Flash Gas Tankless Water...
My 2003 Mercury Mountaineer has an electrical problem. It started about a year ago with the key fob not working, I have bought 3 and all won't work even after re-programing. now tonight I went to
Could be a windshile leak down the A-Pillar & water
gets into the delayed accy relay for the GEM Module
(Body Computer as ford called it for a few years) & you
get what you have now
Try Goolge as I did a few weeks ago for a relative
He had the same issue with the blower being on &
killing the battery
No real fix I found for the windshield leak
Seem a robot didn't put the rubber sealant
on correctly at the factory fo about 5 years
on several fords.
If it isn't water related then the GEM Module
controls all those body features
If you get a used one & match up the numbers,
you supposedly can avoid buying a reman gem
& the expense of having to reflash it to your factory
built combination
Jan 27, 2013 | 2003 Mercury Mountaineer
I have a California Profile 600 watt amp, I have multimeter and have power all the way to my 10
Power from ignition is setup to turn power On,
Check if +12V is available on "REM" terminal.
Check the speaker wirings , if speaker is connected to the
speaker output of the amp securely.
Oct 21, 2012 | Profile - California: 2 Channel 600W...
Headlights won't turn on in my 1999 ford mustang gt
Sounds as though you have an exposed electrical connection that's either getting splashed from the tires, or the moisture is creating a temporary disconnection. This can happen, but once it dries it will resume working. I would have your electrical system checked. I would also have your headlight switch checked for a possible short.
May 08, 2012 | Ford Mustang Cars & Trucks
My Outback AC when you turn the car on sometimes does not blow cold air and at other times it does. Turning it off and then on sometimes gets it going. Over the last 12 months sometimes it works for...
Howdy Grichards360,
Not knowing the AGE of your AC only makes it a wee
bit harder to speculate... (good news though)...
INTERMITENT operation = cheap & easy.
SUFFICE it to say REALLY EXPENSIVE issues
are like HATE & UGLY... They stay (and accumulate).
My BEST GUESS is your system pressure is
right at the THRESHOLD where designers
have CORRECTLY (even mercifully) decided it is
marginal enough not to USELESSLY operate the
components at all...
An ideal time (and stable enough system) to
"top-up" your refrigerant charge... (see below)
unless you live in CALIFORNIA ... you should easily be able to purchase a kit to accomplish this TASK yourself.
Two CAUTIONS here:
1). Refrigerants can be quite dangerous...
(read & heed precautions (especially refrigerant TYPE)).
2). "Top-Up" is a STUNT... Proper maintenance would
dictate a serious consideration be given to PROPER
lubrication. If this is the first time in 10 or 15years you will
PROBABLY be fine...
(ELSE: study up or comment back).
Hope this helps
Carnac the Magnificent
May 29, 2017 | 2003 Subaru Outback
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a California Profile 1200w amplifier. I'm operating two 10 inch Sony SP5 4ohm subwoofers unbridge. The amplifier hits hard for about 30-45 minutes then it partially shuts down. Bass also drops off...
Overload. Looks like your amp is 4 ohm stable. You are wiring each speaker separately from the
amp (Left + and - to one and Right + and - to the other) and if so you are correct. You may need
to increase the available amperage to your amp with a larger guage wire. I am assuming you are using 4 gauge. If not, bump up to 4 gauge. If so maybe add a second, sealed cell, battery as a stiffener. The capacitor idea wont help enough for the $$ invested. The battery should give you reserve amperage and keep the system happy. Be sure to run a fail-safe (250 amp) fuse at the battery just in case a wire shorts to a ground, your car wont burn to the ground. Just wire the battery to a system connection and the both go to the amp. It will also give your vehicle electrical system a much need boost that will save your alternator.
Here is a real cool site you can use to answer all your electrical question and build your own boxes!
http://www.bcae1.com/
Mar 12, 2011 | Profile - California: 2 Channel 1200W...
Strange electric outburst
are your cables ran seperate? run the rca and remote wire opposite side of car where power wire is. rca and remote wire can pick up signal from elctric static from power wire.????
Jul 02, 2009 | Profile AP600 Car Audio Amplifier
Sony xm-1002hx
If the fuse blows only after the remote voltage is applied, the output transistors have likely failed. Never use a fuse larger than the one recommended by the manufacturer. It can lead to more extensive damage (including damage to the circuit board) which will make the amp much more expensive to repair.
Sep 23, 2007 | Sony XM-1002HX Car Audio Amplifier
Kenwood KAC 6201 Car Audio Amplifier Logo
75 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
