Question about Philips HTS3410D/37 700W DVD Home Theater System System
The Philips HTS3410D DVD Home Theater System is making a buzzing sound whenever it is plugged in. As far as I know, the speakers and bass work just fine, it is just the system that has the problem. I plug it in and it immediately starts to make a buzzing noise. Whenever I press the power button, it seems like it is going to turn on, but immediately turns itself back off and the buzzing continues. I took off the cover and the sound looked like it was coming from around the power supply area, but I'm unsure about it. I took some pictures if anyone could kindly identify it. http://img.photobucket.com/albums/v670/wildguy3922/CIMG0014.jpg http://img.photobucket.com/albums/v670/wildguy3922/CIMG0013.jpg http://img.photobucket.com/albums/v670/wildguy3922/CIMG0012.jpg http://img.photobucket.com/albums/v670/wildguy3922/CIMG0011.jpg The pictures are the section of the inside that is making the buzzing sound. It has a thin black cover over the board. I don't know if it would be a small part that is easy to replace or the entire part has to be replaced, but I would really like to repair it instead of investing a lot of money into another system. If anyone can help me, I would greatly appreciate it.
  • 4 Answers
SOURCE: refurbished philips dvp642/37 playing and stops playing
the problem is not the power supply capacitor. it will eventually fail, and need to be replaced, but when it does you'll know it because you wont be able to use the DVD at all. it wont turn on, and the standby light will just flicker.
the problem is that your mechanism/lens is probably dirty or dusty or out of alignment.
this device is kind of sensitive moreso than other players. by "sensitive" i mean "cheap"
try cleaning it with soft, lint-free cloth, and windex.
clean your disks as well.
if that doesnt work, you may just need to buy a new DVD.
at $60 its a good deal, even if some of them do crap out too soon. you can spend more $ on a better quality player if this fact bothers you.
Posted on Mar 09, 2008
  • 5 Answers
SOURCE: magnavox 60
It's probably the magnets on the neck of each CRT that moved since you removed them or the CRTs weren't put back in the exact orientation . Use a white paint pen to mark each one as they are now. If there's a clamp or two metal rings that locks them in place you can try rotating them as a group (their location up and down the neck is also critical).  If not you will have to adjust them individually and then do a complete convergence adjustment. That's a big task. Good luck.
Posted on Sep 30, 2008
rongxin
  • 57 Answers
SOURCE: dvd player won't stay on
your unit sir or maam, it has a deffective parts you need to replace the parts the two channel of the power output ,because this parts is shorted,you need a good technician to fix it. and buy the parts to replace it
kira_ryuk99@yahoo.com
Posted on Jan 11, 2009
SOURCE: I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Posted on Dec 29, 2009
  • 11800 Answers
SOURCE: i brought a philips home
Yes, you can replace it, but only with an identical model. And you must find it on second-hand sites like Craigslist and buy it yourself since it's out of warranty.
Or you could try to fix it: use another type of video cable, open the case to look for burned parts and replace it, look for loose wires and resolder them , look for broken connectors and glue them back together.
Posted on Aug 18, 2010
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Does this model have a digital input?
This model does not have a digital input at all - only red and white inputs.
Mar 15, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Phillips hts3410d no sound VERY dim led
Have you had any thunderstorms recently in your area? if so, this could be a pulse sent threw your system form an electrical storm. this happens often during dangerous thunderstorm activity. Also, your electrical wiring in your home can produce this as well due to a faulty circuit breaker box or lose ceiling fan hook ups. the best scenario could be a defective product. this way, you can get a full refund or a replacement set up.
Jan 28, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Dvd player won't stay on
Jan 11, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
Philips HTS3410D home theatre system. DVD is stuck inside - won't play, won't open. any ideas?
Power off the system
Unplug the power cord
Wait 5 minutes
Plug back the power cord
Power up the system
Press the open/close button
Load a DVD and play
If the tray still will not open, the cover will have to be removed and manually operated. You may have to have a technician look at the unit.
Please rate this solution - Thanks
Dec 27, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
STANDBY LIGHT KEEPS BLINKING
Unplug the power cord, wait for 5 minutes, plug the power cord back in and try to operate the unit.
If this does not work, you will have to get a technician to look at it for you.
Please rate this solution - THANKS
Dec 26, 2008 | Philips HTS3410D/37 700W DVD Home Theater...
Unit is behaving oddly
there is probly a short in the wiring some were
Jun 12, 2007 | Philips HTS3410D/37 700W DVD Home Theater...
137 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
