Question about Denon AVR-1908
I am not getting any cable sound from my TV. I'm using a Motorola cable box (VIP 1216) connected to the Denon. Everything was working fine for the past couple of years then the TV sound went out and we were listening only to the surround sound on left and right channels. While trying to fix this sound problem, the surround sound went out. Now I have no sound to go with the TV. If I play a DVD, sound now comes out of the TV instead of the surround speakers. How do I get back to my original setup?
  • 1 more comment
  • cravewaves Aug 31, 2010
    Everything is hooked up to the receiver. The DVD player goes to the receiver. Nothing is hooked directly to the TV except the receiver. I have a Zune hooked up to the VCR inputs and it plays just fine, outputting through the surround speakers. DVD now playing through the TV speakers which it never did before. Cable TV provides good picture but no sound. Previously, I had sound on either the TV or surround from the cable inputs. My best guess is that some of the Denon settings have been changed by the cable remote, which also has some receiver functionality. I am seeing a small box on the receiver screen that says "analog." I'm wondering if the receiver is looking for an analog signal. I've tried to change the settings to digital without any success. I've used the auto detect and I keep getting the analog box on the screen.
    Also, when I set the receiver for cable inputs the screen used to say "TV/CBL" and now it says "TV/YBL"
  • cravewaves Sep 01, 2010
    Thanks for the advice. There were no error codes on startup. I was hesitant to go through the autosetup with the microphone because I could view the results of the last autosetup. I tested all the speakers and they worked fine. Regarding turning the A and B zones off, I have had that problem in the past and know how they can be accidentally turned off. After looking at the screen carefully, I noticed the letters DVD near the top of the screen. I played around with several dials and buttons and changed this to TV. I'm not sure which button actually did the trick but everything is back to normal now. Thanks for your help.
    Thanks for the help. While it did not directly solve the problem, it got me looking at the screen and I changed some settings to TV rather than DVD.
  • 864 Answers
How is everything connected? is everything hooked up to the reciever? just wondering cause now you say the sound now comes out of the tv? how is the dvd player hooked up does it go through the reciever or is it plugged into the tv now. If you can outline the details of your setup i can help assist you. That way i can understand how you have it hooked up and then help trouble shoot from there. Thanks, Midwest-tek
Posted on Aug 31, 2010
  • Nathan Ayers
    Nathan Ayers Aug 31, 2010
    ok well there is from as far as i can tell in the reciever no way to set it back to default. But in the manual there is an auto setup and a way to ensure your settings. here is the link to the manual http://www.usa.denon.com/AVR-1908-OM-E_1... it is on page 25. If you could go through the auto setup it would help me cause if it has any problems it will give you an error code. Then if you do get an error code we can figure it out from there. But to me i am wondering if you hit the A or B zones and you have turned off the speakers itself. On page 9 it says there is a rear of the remote. there is zone 1 and zone 2 power. try making sure zone 1 is enabled. Cause if the dvd player is hooked up then that means the audio is passing through the unit. When you open the on screen display of the reciever does it show any error codes? or information that pops up?
Here's my setup: 46"Panasonic Viera
I'd call the cable company, it sounds like you have an issue with the cable box.
Feb 22, 2011 | Televison & Video
No sound from any source from speakers
check your connections again and ensure you have the audio going out. With many tv's you need to change a setting in the menu, double check that as well.
May 05, 2009 | Denon AVR-687
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Feb 25, 2009 | Denon AVR-5803 Receiver
We have a Denon AVR Surround Sound receiver, a Samsung HDTV, an XBox 360, an ASD-3W Denon Ipod Dock and Klipswitch speakers with a subwoofer, center channel and too bookshelf speakers. We need help...
HDMI input connect as follows:
1. Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon.
2. Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon.
3. Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung.
You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition to the HDMI cable and last,
4. On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
Jan 08, 2009 | Denon AVR588 Receiver
Denon avr-1907 sound from TV stopped working
Help with hooking PS3 to a Denon Receiver. It worked before, but I had to move everything to a different location and when I hooked it back up the PS3 has sound but no picture. I have it hooked directly to the receiver with and HDMI cable (the receiver is hooked up to our cable box which is directly hooked to the tv via HDMI cable).
Jan 03, 2009 | Denon AVR-1907 Receiver
Audio troubleshooting with an AVR Denon 900
ok i have the same reciver do you use hdmi to go to your tv or componet what ever you use there will be an audio out for rca on the cable box if you dont use a cable box keep reading but use hdmi to tcv then the rca audio out to the denon avr 900 obviously out it in the vdp/tv unput. and if you dont use a cable box your tv shoiuld have an audio output in the back of it for rca connect rca to audio output then other end to the denon avr 900s vdp/tv input
Dec 27, 2008 | Denon AVR-900 Receiver
Surround sound
Hi
Your receiver is capable of video conversion, so there should be no problem using your component cable.
Does your TV accept component, or only S-Video? If you can run component to your TV, the best quality signal path would be using a component cable from your Verizon box to your receiver, and component from your receiver to your TV.
Make sure you have set up the video input correctly, so that it is set to accept the incoming signal on the correct sockets.
Mar 21, 2008 | Audio Players & Recorders
Stopped consistently producing sound
Try plugging and unplugging a pair of headphones. The headphone jack in these receivers are flaky and sometimes think there are headphones hooked up even when there isn't. Full repair would require the headphone jack to be replaced. If you don't use headphones at all, you can take the top cover off and unplug the cable going to the headphone jack board and eliminate the problem that was as well.
Mar 01, 2017 | Denon AVR-1603 Receiver
Denon AVR-1908 Logo
280 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
