Question about Mitsubishi VS-50111 50" Rear Projection Television
Turning on TV
My Mits HD1080 has some power up problems. The TV would turn off or not power up or turn on intermit - but now it won't turn on at all???
Any suggestions on the problem or how to fix? - Lee -
    New Friend:
  • 50 Answers
Check if there is any loss connection in the power supply circuit...
Posted on Aug 11, 2008
My Mitsubishi hd1080 tv will not come on when i turn the power button on the green timer light comes on but the tv goes back off
The TV reset may help you. If the timer was set by accident many of these TV's that have the sleep timer have this problem. Try the factory reset initialization.
Nov 19, 2014 | Televison & Video
WHY DOES IT KEEP TURNING OFF
Yes. Rear-proj.with 3 picture tubes. These, like most newer tvs have self-checks that shut the tv off if the fault could worsen problems for the TV (such as damage picture tubes.) or it's not able to put a picture up.
After it shuts off, you can press menu and input/device together for 5 secs, and it will flash a 2-digit code (such as "23" or "24", etc.)(vertical or horizontal error.) Though you will need to call a repair shop for repair. It's usually better if they are Mits. factory authorized, as they'll likely have more exper. on Mits.
Apr 24, 2014 | Mitsubishi WS-65511 65" Rear Projection...
My Mitsubishi HD1080 medallion projection TV won't turn on. You turn it on and it shuts off in 2 seconds by it self.
It's the problem of overheating in the power supply board of the TV.on the power supply board of the TV there are few capacitors and IC.any of this IC is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.This will help.
May 17, 2011 | Televison & Video
I am having a problem with my Mitsubishi medallion HD1080 . I turn it on and it turns off right away. It won't stay on for 3 seconds shuts off by its self. Can somebody help me?
It's the problem of overheating in the power supply board of the TV.on the power supply board of the tv there are few capacitors and IC.any of this ic is got short or may be weak.so due to this when you start the TV the current passes from electric outlet to the power supply board of TV.but when the current passes from that weak/faulty part at that time current gets stopped or slow and the board overheats and TV shuts off. this is a common problem faced by many other users too.the possible option to solve this issue is to check the power supply board by a meter and continuity tester and replace the faulty component on the board which is short due to which power supply board is getting overheated.its bit technical job but yes its not at all a costly repair to do or get it done by the technician. for required parts it can be easily available from local electronic hardware shop.
Hope this will helpout...
May 17, 2011 | Mitsubishi Televison & Video
Wavy lines all over the screen on a 55 in. Mitsubishi DLP 2005 Tv that has intermitent wavy lines around all the edges of the people and edges of the screen. Jerky picture and almost makes you sic...
You probably have a V26 chassis. The only fix to this problem now that parts are no longer available from MITS is to call their Consumer relations dept. at 800-332-2119. If you have a qualified tech come out and estimate the job, Mits will offer you an attractive discount on a new model. To repair your problem would be around $750
Bill W
integrityhomeworx.com
Mar 22, 2011 | Mitsubishi Televison & Video
Tv turns off intermitently
hi
check your AC cable (change)
2-connctor that ac cable connect into
3- check the button for turning on (not stick)
Jul 25, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
Won't come on
The power board has failed and will need to be repaired or replaced. you can remove this board and, replace individual parts and save a lot of money. You will be inspecting for swollen capacitors and resistors. also, look for discolorations on the board itself.
Feb 19, 2009 | Mitsubishi WS-55807 TV
Mitsubishi HD1080
I will need to know your model number in orderto help you locate a PC board for it.
Jun 15, 2008 | Televison & Video
Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-50111 50" Rear Projection Television Logo
150 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
