Question about Dell Inspiron 1545 Notebook
Every time I start up my computer it freeze.s before I can even open anything. I can't get to the start up screen, the control panel, or even shut it down correctly. I would like to know what the problem is, whether i can fix it, or around how much it would cost to get fixed. Thank you.
    Problem Solver:
  • 14 Answers
There is an application in Windows that causes your operating system to freeze. Maybe it's a virus or an application that is too high to handle the PC in startup. Try to use System Restore in safe mode option before booting in Windows to restore the previous state of your PC.
Posted on Aug 31, 2010
My dell says hybernating while on and hang
Hybernation is a power saving feature in microsoft windows. Often times this will cause the computer to freeze.
One solution is to disable hybernation in the power settings located inside the control panel.
On windows vista / 7 you can do this by clicking on the start button (lower left hand corner of the screen)
Then going to "Control Panel"
At the top right of the screen should be a search box, simply type "Power" Into this box and options to edit / change the power plan should appear. Choose edit power plan,
Make sure any options pertaining to hybernation are disabled, You can also adjust when the screen and hard drive shut off during inactivity. For desktops it is recommended to set all options to "Never"
Once finished click the "Save Settings" Button. and you are all set.
You can adjust these settings as much as needed, they can always be undone.
On windows 8 you can access the control panel by moving the mouse to the upper right hand corner of the screen and choosing "Settings" or "Computer Settings" the same procedures apply after this step.
Nov 20, 2014 | Computers & Internet
Runs slow,the entire laptop
Step 1:
Hangs When Idle for a Long b> Normally your computer will turn on a screen saver or enter sleep mode after a certain period of idle time, to protect your monitor from suffering a "burn in" of an image that appears on the screen for extended periods of time. This also helps to save electricity during periods of inactivity. Vista owners report via Internet tech help forums a seemingly rampant "bug" that causes the machine to freeze after being left idle for long periods. No single factor seems to cause this, and instead requires troubleshooting and trial and error to find a fix that works.
Screen Saver Failure
When your computer freezes after a long idle period, it could be due to a malfunctioning screen saver. Turn your screen saver off, by clicking "Start" and then "Control Panel." Under "Appearance and Personalization," click "Personalization" and select "Screen Saver." Select "None" under the screensaver drop-down list and hit OK. Pay attention next time your computer goes idle for reappearance of the problem. b> Power Saving Options b> Windows Vista provides users a way to select how their computers behave after sitting idle for a certain amount of time. In many cases, the hard drive and monitor are instructed to enter sleep mode or even shut down after they've been idle for a specified time frame. To check or alter your settings, click the "Start" button and then "Control Panel." Under the System and Maintenance icon, click "Power Options." Under this tab you can change the amount of time before your system goes to sleep, and the actions it takes after reaching the idle time. Malware b> When mysterious things begin happening to your computer for no apparent reason, there's a good chance a malware program is behind it. Malware are nasty, hidden programs that download themselves onto your computer to cause havoc and even steal your personal information. These invaders monopolize your CPU, clog your RAM, and generally make using your computer unpleasantly slow and frustrating. Their presence can affect everything from program operation to operating system functionality. Always update and run malware protection software regularly to keep these pests out of your computer. b> Update Windows and BIOS b> Your computer's operating system and BIOS files are responsible for proper operation and functionality. Over time, these files can become outdated, requiring patches, fixes and other updates to correct compatibility and security problems in your computer. Microsoft provides regular updates for its Vista operating system to correct reported problems. The BIOS in your computer is programmed into the motherboard, so the board's manufacturer may have an update available for your version. In many cases, the brand that sells the computer may offer a link to the BIOS update, so check with Microsoft for any updates available. b> Too Many Processes b> Your computer will register as "idle" if you haven't used it, even if you have programs open on the screen. After a certain amount of time, the system will send the data you were working on to the RAM as the system settles into sleep mode. When trying to wake the system after this idle period, it may have a hard time resuming the programs that are open, causing a freeze. Close down any program you are not actively working in to save the CPU from unnecessary work, and lessen the load placed on the RAM when it's left idle. right mouse click in the bottom toolbar select task manager applications if you see something running that should not be running select end now you might even uninstall that specific program if its no longer needed also in the processes tab see whats ticking over in the background might be a virus or malware. Download and install at least one of these all free depending on your operating system http://download.cnet.com/avg-antivirus-free-2013/3000-2239_4-10320142.html avg free 2013 http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials
Feb 24, 2013 | Microsoft Windows XP Home Edition
Hp freezes after it sits for long time
which operating system ?
When your computer freezes after a long idle period, it could be due to a malfunctioning screen saver. Turn your screen saver off, by clicking "Start" and then "Control Panel." Under "Appearance and Personalization," click "Personalization" and select "Screen Saver." Select "None" under the screensaver drop-down list and hit OK. Pay attention next time your computer goes idle for reappearance of the problem. b> Power Saving Options b> Windows Vista provides users a way to select how their computers behave after sitting idle for a certain amount of time. In many cases, the hard drive and monitor are instructed to enter sleep mode or even shut down after they've been idle for a specified time frame. To check or alter your settings, click the "Start" button and then "Control Panel." Under the System and Maintenance icon, click "Power Options." Under this tab you can change the amount of time before your system goes to sleep, and the actions it takes after reaching the idle time. Malware b> When mysterious things begin happening to your computer for no apparent reason, there's a good chance a malware program is behind it. Malware are nasty, hidden programs that download themselves onto your computer to cause havoc and even steal your personal information. These invaders monopolize your CPU, clog your RAM, and generally make using your computer unpleasantly slow and frustrating. Their presence can affect everything from program operation to operating system functionality. Always update and run malware protection software regularly to keep these pests out of your computer. b> Update Windows and BIOS b> Your computer's operating system and BIOS files are responsible for proper operation and functionality. Over time, these files can become outdated, requiring patches, fixes and other updates to correct compatibility and security problems in your computer. Microsoft provides regular updates for its Vista operating system to correct reported problems. The BIOS in your computer is programmed into the motherboard, so the board's manufacturer may have an update available for your version. In many cases, the brand that sells the computer may offer a link to the BIOS update, so check with Microsoft for any updates available. b> Too Many Processes b> Your computer will register as "idle" if you haven't used it, even if you have programs open on the screen. After a certain amount of time, the system will send the data you were working on to the RAM as the system settles into sleep mode. When trying to wake the system after this idle period, it may have a hard time resuming the programs that are open, causing a freeze. Close down any program you are not actively working in to save the CPU from unnecessary work, and lessen the load placed on the RAM when it's left idle. right mouse click in the bottom toolbar select task manager applications if you see something running that should not be running select end now you might even uninstall that specific program if its no longer needed also in the processes tab see whats ticking over in the background might be a virus or malware. Download and install at least one of these all free depending on your operating system http://download.cnet.com/avg-antivirus-free-2013/3000-2239_4-10320142.html avg free 2013 http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials Hope this helps.
Dec 20, 2012 | HP Compaq d530 CMT PC Desktop
Vostro 200 PC freezes on Dell Start up page & won't turn on
If you have windows 7 installed, then see if you can boot to the DVD and run a repair on the OS. You also may want to run a diagnostics on the system if you can get to the F12 menu
Feb 27, 2010 | Dell Vostro 200 PC Desktop
It's freezing up and will not even load the screen to choose user
It's broken when that happens. If not, then try shutting it off then turning it back on :(
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Weird clicking noise and computer freezes.
Laptops have very few moving parts. Your problem is more than likely either a fan or your hard drive. Remove the hard drive, start the computer up and just let it run for awhile. If the clicking noise never comes up then thats your problem. If it does, its probably a fan.
Disregard anything on the screen itself, just let the PC run. It sounds like after the hard drive has been spinning for a minute a motor starts to die.
Jan 29, 2009 | Acer Aspire 5100-3357 Notebook
Xbox 360 Freezing Problems
Shutting off the Xbox corrupted the Hard Drive... Have you ever got a Live System Update? You can also reset your Xbox without shutting it off using the controller. You probably have the Three Red Rings of Death... Go to this...
http://www.fix3redlights.com/?p=bfy&m=1&gclid=CKTS1MGEmpcCFRlRagodpD9H-A
Nov 29, 2008 | Microsoft Xbox 360 Console
Boot up problem
  1. Start
  2. Settings
  3. Control Panel
  4. performance and maint.
  5. power options
  6. click on advanced tab
  7. under when lid is closed select what you want
  8. if you want to activate hibernate select that tab
  9. apply
  10. close evrything out
Apr 15, 2008 | Dell Inspiron B130 Notebook
Computer Freezes During Startup (Urgent!)
slamming the keyboard would jar the memory on the bottom or under the keyboard, and make this happen, inspect them both, and then restart it..
check your computers warranty here 4 FREE
Mar 15, 2008 | Acer TravelMate 2300 Notebook
Dell Inspiron 1545 Notebook Logo
111 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
