Question about RCA Televison & Video
I have a 52" RCA TV Model 52w1913yx1, when I turn it on the green LED will flash and then go out. There is no High Voltage and no picture.
    Top Expert:
  • RCA Master
  • 14,553 Answers
I suspect High voltage splitter is bad, can you confirm chassis number?
It is on label on back with model number, something like CTC or PTK 169 OR 171.
IF ONE of these chassis or similar I can tell you how to prove block is bad and where to find and replace--most of these sets also have year they were made on the back.
I am here to help you for free.
SD TECH
Posted on Aug 31, 2010
  • bbartlett Sep 03, 2010
    the chassis number is ITC222, also the picture will come on then the LED will flash 3 to 5 times then goes out.( this happens within seconds of turning TV on ) when this happens there is no High Voltage or no picture.
  • SD Tech
    SD Tech Sep 03, 2010
    This set also uses a high voltage splitter. You will have to remove entire front grill below the screen and remove inspection plate behind it. Splitter is tan colored and has 4 rather large wires going into it on the top. If you are lucky you will hear or see a spark near it when you try to turn the set on.
    The only way to be sure if the splitter is bad or not is locate the single red wire that goes from it to the rear of the set (it goes to HV transformer). Wire is pressed and and will pull out (not easy).
    If out, place the wire (end) in a glass bottle well away from any metal to isolate it (I use a soda container)
    If set comes on and power light does not go out (you will hear the HV sizzle in the bottle) the splitter is your problem. If not the problem is back at the deflection board which produces this voltage.
    Most techs (myself included) do not like working on these sets as they are not easy to take apart and there are some parts not readily available.
    Trouble is either the splitter or in front of it.
    SD TECH
The blinking of death.
set is trying to come on but not making it.
Most common issues with this model are bad connections around the high voltage transformer or on that same board.
A few will also have the High Voltage splitter at the very front of the set behind the front grill fail---a faint arc when you try to turn on.
8_30_2012_2_57_40_pm.jpgHigh voltage transformer
Aug 29, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA D52W20 52" HDTV Ready TV which I
Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52" D52W20 ATC221 TV Problem
The FBT is dead.The buzzing sound mean there no high voltage is come to the CRT(tv tube).No burning,marks on the FBT doesn't mean it not dead.I change parts all the time with out burn marks on them.Trust me i replaced dozen of the FBT before.It make buzzing noise it dead.
Mar 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Model 52" hd RCA tv Will not go on.hit power button green light keeps flashing.will not stop
These units are famous for bad capacitors in the power supply. When the capacitors go it causes voltages to fluctuate out of range. You have to remove the deflection PCB to repair this. Also look for loose connections at the high voltage transformer. This can be a dangerous circuit to work on. Have a repair shop check it out for you. Thanks
Oct 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Jun 05, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 50 inch rca tv model m50wh185 no picture but has sound
do u hear any high voltage static when you first turn on. possible high voltage problem with the high voltage splitter or focus pack. ussally when there a problem with these high voltage is being generated but not delevered to the tubes
Mar 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52754AT 52 in. No Picture No Sound
Sounds like the flyback failed,or a loose connt. on the high voltage area of the main board.
Jan 26, 2008 | RCA P52830BL 52" Rear Projection...
Rca m50wh74s HELP
Sounds like a bad high voltage transformer (FBT). Call a service center.
Jan 11, 2008 | RCA HD52W56 52" Rear Projection HDTV
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
52 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
