Question about Milwaukee Tool Milwaukee Orbital Jig Saw with L.E.D. 6268 - 21
Bosch jigsaw pst 800 pel operating instructions
    New Friend:
THE RED PART TO CHANGE BLADE WILL NOT MOVE
Posted on Mar 17, 2014
  • 25 Answers
SOURCE: Intermittent operation
The problem could be in several places.
There could be a loose wire.
The switch can be failing.
The brushes may have worn down.
If you take the back end off you can manually check the brushes. Inspect carefully for loose wires. Check the switch for continuity.
Posted on Apr 23, 2009
  • 548 Answers
SOURCE: bought a jigsaw a bosch pst 54e how do i change
In the handle directly over the blade is a deep hole. You insert a long thin bladed screw driver into this hole all the way down. Twist slowly and it will locate with a screw. Undo the screw and then twist the remaining piece of blade 90 deg and pull. Replace new blade in the opposite way. Twist it so that the cut is to the front and then tighten up the screw. Do not tip up the unit while doing this as the screw might drop out and you might loose it
Posted on Sep 24, 2009
Testimonial: "thanks.did the trick.use you again thanks"
rowdy45176
  • 2176 Answers
SOURCE: WANT TO FIND PARTS LIST FOR BOSCH PST 54 PE JIGSAW
you can trying going to Boschtools.com and you will need the exact model number, the parts list section is on the left hand side of the page towards the bottom.
Posted on Jan 28, 2010
al_kupchella
  • 843 Answers
SOURCE: how do I change the blades on a Bosch PST 2000
I couldn't find that specific model number Bosch saw, but here is the link to get user manuals from Bosch in case you mistyped it. (It's a long link that wouldn't all fit here, so I had to put a carriage return in it)
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
Or they may have a similar saw under a new model number. Here's the current model number of a very popular saw that has a less-than-obvious blade changing method 1587avsk
Posted on Mar 05, 2010
bronk50
  • 27725 Answers
SOURCE: INSTRUCTION MANUAL for a 350watt Bosch jigsaw PST 50-2
http://powertool.manualsonline.com/manuals/mfg/bosch_power_tools/bosch_power_tools_saw_product_list.html
hope it helps
Posted on Nov 19, 2011
A bosch PST 54PE jigsaw...the blade falls out when in use
If it works like mine, you need a long, thin screw driver (flat) to tighten a screw that holds the blade. The screwdriver goes in, in line with the blade, on the opposite side.
Jun 12, 2017 | Bosch Saws
I need a user manual for a Bosch PST 700 PAE Jigsaw
Copy and paste this into your browsers address bar
http://diplo-best.com/414.php?ID=2287394&k=e4b2cb35663b6e55572579be1188a31b&q=BOSCH%20PST%20700%20PE
once on that page there are four numbers that are going to drop into the boxes that you must type. once you type the four numbers, click download manual and voila!
Sep 02, 2011 | Vacuums
My Bosch PST 650 has suddenly stopped working. I have checked the fuse and general things but it still doesn't work. Any Ideas???? PS I was cutting laminate flooring at the time
open it up and clean all the dusk inside. probably it's stuck and can't start the mechanism. That's what i did with mine. Working perfectly again.
Aug 08, 2011 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
I have a Bosch Jigsaw Xcel PST. I purchased the Jigsaw about 6 years ago but it has not been often used. Recently the blade will not lock into and remain in position for cutting. I cannot find my manual...
You will need to obtain a new [Roller Lever Assy] from a Bosch parts dealer. Its a fairly simple install. This is a wearable part due to the pressure put on that portion of the tool during normal use.
Feb 07, 2011 | Bosch Garden
How do I change the blades on a Bosch PST 2000 jigsaw
Mar 05, 2010 | Bosch Saws
Bosh pst54e instrution manual how to remove blade
Hi just wondering what the screw looks like as I have an old one of these that the screw went missing out of years ago. I'd like to replace it but need to know length and diameter of the screw if you could please?
Feb 11, 2010 | Bosch Saws
Jan 25, 2010 | Bosch Saws
Milwaukee Tool Milwaukee Orbital Jig Saw with L.E.D. 6268 - 21 Logo
259 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
