Question about Enermax Noisetaker EG425P-VE (EG425PVESFMA20) 420-Watt Power Supply
My computer will not power up at all been looking for another compatible power supply since this one is discontinued need help immediately.. enermax eg425p-ve
    President:
  • 1,768 Answers
I found a Ebay listing that may help your issue:
Here is the Enermax power supply page for the VE
http://computers.shop.ebay.com/Computers-Networking-/58058/i.html?_kw=eNERMAX&_kw=VE
Here also is a site where you can purchase the OEM ( Original Equipment Manufactuer) for you particular PC unit.
http://www.enermaxusa.com/wtb.php
Posted on Aug 31, 2010
    Problem Solver:
  • 10 Answers
I'd check into a DiabloTek PHD650 650-Watt Power Supply. It's a higher voltage module, but has similar features to your Enermax power supply. If you can't find it locally, check out TigerDirect.com (my fave) or NewEgg.com. These two sites are likely to have these, and are competitively priced.
What fuse is in a Enermax EG495P-VE Noisetaker 485W Power Supply
Just buy a new power supply. If you touch the wrong thing inside that psu you will die. Seriously.
Aug 15, 2012 | Enermax (by Coolergiant) EG495P-VE SFMA...
Power supply compatible for cooler master cac-t05-uw
Most brands like HEC, Gigabyte, FPS, Cooler Master, Enermax, Silver stone, Corsair, etc. Will fit in your casing but you must consider your hardware before buying a power supply.
Most power supplies that are priced below $30 generally do not meet the power requirements of the latest processors. To make matters worse, the components used in them are of inferior quality and more likely to fail over time. While they may power the computer system, inconsistencies in the power to the components will tend to cause instability and damage to the computer.
Consider the ff:
ATX12V Compliant
PC Power Supply Wattage
Silent PC Power Supplies
Power Efficiency
Having the right number of connectors
PSU Wattage Calculator Asus
PSU Wattage Calculator extreme
Hopefully this helps..
Thank you for posting..
Jul 08, 2011 | Cooler Master (CAC-T05-UW) (CAC-T05-UWA)...
How can I test voltages on the Enermax Galaxy EGA1000EWL 1000-Watt Power Supply unit out of the computer.
Most motherboards will give tell you all of the voltages being provided by the power supply in the bios under hardware or health monitoring section. Otherwise you will need a multimeter to test the different voltages. You would want to set the multimeter to the 20v or similar setting. Depending on what voltage you would want to test would determine the color of wire you would check. You would connect the black/negative/ground lead of the multimeter to one of the ground wires coming from the power supply normally a black wire. The 12v is normally a yellow wire, the 5v is normally a red wire and the 3.3v is normally an orange wire. The wires may be different colors so you may want to look up the ATX pinouts to find the exact voltages you want to measure.
Feb 23, 2011 | Enermax Galaxy EGA1000EWL 1000-Watt Power...
WHICH POWER IS COMPATIBLE WITH THE CACT05UW CASE
ANY good power supply will fit.
Go for a good make 80+ rated supply
Try
seasonic
silverstone
ocz
enermax
Or just google 80+ psu
Aug 19, 2010 | Computers & Internet
My enermax power pack sparked out of the fan in the back and now my computer wont turn on. Not sure if it's the power pack or the board is fried... Any help would be appreciated thanks =)
if it sparked then something inside the power supply malfunctioned and that is the reason it wont work. You will need to replace it. Unlikely that it fried your board in the process. You can test this by swapping the power supply with one that you know works.
May 20, 2010 | Enermax EG301P-VB (eg301vb) Power Supply
Hi, I have a problem with my Enermax Blue Viper CS-718-B, bought in 2006. When pressing the start button, the light and fan are working very short, or I get a peep, but the computer is not booting. Only if...
Your computer either has a fault with the power button in which you can request off the manufacturer a replacement (may cost money depends on warranty) or you do not have enough power for the computer components. Try removing all the peripherals except from screen, keyboard and mouse and then try booting. If it works then you dont have a large enough power supply for all the equipment you have. If it still does not work then it could still be a power supply (PSU) fault in which you can take the psu to your local computer store and they can test it for you.
hope this helps
Oct 08, 2009 | Enermax (CSXSEG718SNP) ATX Full Tower Case
Case tranfer
Yes your motherboard will be compatible in the new case.
Please vote if this helps!
nLinked
Computer Support Services
Jun 07, 2009 | ASUS P5PE-VM Motherboard
Power supply , small plug hook up?
That plug is for the fan RPM monitor, it is not needed for normal operation.
Mar 06, 2009 | Enermax (by Coolergiant) EG495P-VE SFMA...
How much watts of power do i have?
the 9600GSO uses arounf 250 watts under load. While I cannot fing exact spec for the HP PSU I would be surprised if it were more that 350W. Is there any indication on the case or can you open the case up and look at the PSU?
9600 GSO Power
You need somthing in the order of 450W or greater. Get an Enermax, Corsair or other good quality PSU.
Jul 25, 2008 | HP PAVILION A6230N DESKTOP PC
Power supply
I personally use an Enermax.
Enermax FMA 350W would be good. I've been running a 461 for 8 years now without any problems and I have yet to build something that it can't power.
Apr 25, 2008 | Computers & Internet
Enermax Noisetaker EG425P-VE (EG425PVESFMA20) 420-Watt Power Supply Logo
159 people viewed this question
Top Enermax Computers & Internet Experts
David Payne
David Payne
Are you an Enermax Computer and Internet Expert? Answer questions, earn points and help others
