Question about HP Compaq Motherboard
My hp compaq d530 mother board 5vsb light blinking what is the problem i do,t know. i try to solve this problem but not success yet. so any one have to solove my problem
SOURCE: 5 beeps HP Compaq d530
I'm having the same problem....... I don't think I've added any memory to it.
How do you fix if it's motherboard problem
Posted on Apr 26, 2008
SOURCE: HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS
I already fixed it by following your suggestion. Guess what. It worked. Thanks to you all. I really appreciate it. Have a Happy New Year.
Posted on Dec 27, 2008
SOURCE: HP COMPAQ D530 RED BLINKING LIGHT WITH BEEPING SOUNDS.
4 beeps & 4 flashes mean problem with the power supply. For my experience, most of the time the PSU is good, it is just overloaded.
For more LED and Beep messages, check this link:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00067072/c00067072.pdf
Posted on Dec 31, 2008
SOURCE: HP D530 Will not start:
I had the same problem with my HP D530. It would not start but the motherboard green led light stays on. At first, I thought its the power supply. I DISCONNECT the power plug and removed all my RAMS, AGP video card and I then took off the BATTERY (bios) and replace it with another one from my old computer that had the same battery PART NUMBER. Place the power cable back on and turn on the PC. If the CPU fan comes on, your motherboard is ok. Now UNPLUG the power cord again and place the RAMS. Plug the power cord again and check if the CPU fan comes on. If it did, the computer is properly working. I had mine working but for some reason, it stop working when I install two different AGP video card on it so I had to use and settle with the built in video.
Posted on Feb 02, 2009
buffalonyman
  • 1865 Answers
SOURCE: ethernet driver for hp compaq d530
Drivers are located here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
You must select the appropriate operating system for your application
Posted on Apr 25, 2009
My computer is hp compaq d530 SFF when I turn it on nothing starts only green light blinking on the logic board. Please help me solved it.
It sounds like the power supply is defective and will need to be replaced.
I hope this helped.
Good luck and have a great day.
Jun 21, 2011 | HP Compaq d530 SFF PC Desktop
I try turning on my hp compaq d530 sff this morning it did not boot and the switch light was blinking red every two or three seconds.
PLS REMOVE THE POWER CORD AND THE BATTERY FROM YOUR LAPTOP AND WAIT FOR 5 MINS THEN RE-INSERT THEM AND ON IT . SHOULD WORK
. PLS REPLY OR COMMENT. THANKS
Jun 15, 2011 | HP Compaq d530 SFF PC Desktop
I have an hp d530 cmt motherboard with tray & would know if it would fit in an hp xw4100 case. I have not been able to locate a d530 case.
Most mother boards are loosely speaking "one size fits all". The newer the board the smaller generally. You will have to offer it up and see. It may mean you have to move a couple of pillars.
So long as the PSU leads fit, it sholud be OK.
Dec 15, 2010 | HP Compaq d530 CMT PC Desktop
Need help with motherboard power connection wiring.
i have no mother board cd then system is formatting is not possible please help me i want drivers cd
Apr 11, 2009 | Compaq Computers & Internet
HP Compaq d530 SFF PC Desktop. Black Screen and Cursor blinking..
Try to enter in to BIOS by restearting the notebook (Pressing F2 function, if the notebook enters in to bios then no need to worry. after theat i suggest you to reinstall the notebook to original factory settings dy the recovery disks.
Mar 06, 2009 | HP Compaq d530 SFF PC Desktop
if it is a long beep then check ur ram, try cleaning ram. if not solved then there may be problem with ur ram try changing ur ram.
if it is short beep and if you have a display card installed check the display card
Dec 26, 2008 | HP Compaq d530 PC Desktop
Hy hp d530 won't turn on
I have a similar problem:
My Compaq d530 was running fine until one day during plugging in a USB device (MP3 player) the system completely stopped working. The only thing which is active is the green LED on the mainboard.
I have checked several things and have found the following:
- IDE cable had burn marks!! (nasty)
- USB connection cable which runs from the front to the motherboard has changed in color. (darker green while all other connector have e more light white color.)
These are the signs of a brun out, but I do not have any solution to repair this.
Economically the best thing to do is buy a second hand (or new) system. (d530 are about 60 euros these days (march 2009). Hardware parts can maybe salvaged.
Dec 09, 2008 | HP Compaq d530 PC Desktop
HP Compaq d530
it all depends on the number of flashes , pause, repeat.
Since the problem did not indicate any beeps her is the following info
Power LED blinks RED 2 times, one every second, followed by a
2-second pause. = Processor Thermal Protection Activated
3 blinks 1 second apart = Processor not installed (not an indicator for a bad processor).
4 blinks 1 second apart .= Power Failure (power supply is overloaded)
Other possibilities are:
5 blinks 1 second apart No memory
6 blinks 1 second apart No graphics
7 blinks 1 second apart System board failure (detected prior to video)
8 blinks 1 second apart Invalid ROM
Nov 07, 2007 | HP Compaq Business d530 Ultra-Slim PC...
HP Compaq Motherboard Logo
99 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
