Question about Sony STR-DE497 Receiver
No audio in channell a out put - Sony STR-DE497 Receiver
  • 99 Answers
Check your connectons on the back of the receiver as well as thoes to the speaker. Make sure the wire has not been cut, or pulled apart. Both A and B come from the same part of the amp along with center. The rear channels come from a seperate board. Rotate the switch and see if you hear the sound of the relays falling in the back.
Posted on Aug 31, 2010
Dhc1204 car amplifer
it puts out 600 clean watts per channel, rms @ 4 ohm, and up to 2000 dirty watts bridged mono.. lt listed for over $800, but is realistiocally worth around $300, currently.
DIGITAL AUDIO Amplifiers
Jul 15, 2014 | Digital Audio 2000 WATTS SINGLE CHANNEL...
Public Access Without Audio
I assume you put it on the right channel and they want it on the left. The easiest is to make both channels the same ie set it in stereo mode.
Mar 17, 2014 | Arcsoft ShowBiz DVD 2 (3265)
I have a 42" Hannspree TV. What channel do I put
h;
your DVD player has an output of Audio and Video, and at the back of your TV has and input A/V
you have to connect a RCA cable to this inputs, your RCA must have 3 connectors yellow for video,red for left channel audio white for right channel audio,
then set your TV to AV1 if connect it to AV input 1,there are two AV input at the back,and also SVideo input,
you have to set it by pressing INPUT or TV on remote or button of your TV.
Sep 03, 2011 | Televison & Video
My remote broke and some of my channels are on sap. and when i go to the menu there is no audio setting how do i put the channel setting back to stereo or mono
Hello
While receiving an MTS broadcast, press [Audio] repeatedly to to cycle through the available channel.
Main: Outputs main audio.
SAP: output secondary audio programme.
Mono: Outputs mono audio.
You must ahve remote control to change these, because only remote control have Audio button on it to control these. OK.
May 05, 2011 | Sylvania LC-155SL8P 15 in. LCD Television
Can not see the Video when I input it, see only a blue screen.
ok hook up the audio video in the OUTPUT on vcr and INPUT on the tv then make sure tv is changed to the right input channel now go to vcr and change that channel to AV,.if AV isnt there you may have to go into menu of vcr and do a channel search,but when you change it to AV on vcr you should see the picture
May 27, 2009 | Televison & Video
Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
Nov 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Audiobahn A4601T, only 1 audio channel works
Is it the same channel in both amps that produces output?
Have you tried all combinations of setting for the switches and pots on both amps?
Oct 25, 2008 | AudioBahn A4601T Car Audio Amplifier
Channel problems
Do any of the channels produce sound?
Aug 15, 2008 | Visonik V418XT 125W x 4 Car Amp Car Audio...
Onkyo TX-28 Receiver Output Problem
You may be confusing +/- power supply rail fuses with left and right speaker fuses.
Sep 02, 2007 | Kenwood VR-305
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
Sony STR-DE497 Receiver Logo
85 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
