Question about Miele K8952SDED Refrigerator
The fridge is freezing. This happend after a hot summer and the internal fan was on almost a month. It started to freeze before the fan was put off. Thermostat is my suspect, but I can't understand that it can be faulty after 2 years. Only. How it can get broken this fast??
  • Miele Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 01, 2010
Whats with norpole 12000 btu window air conditioners w/FO CODE,now all i have is a expensive fan!
they eventually do need serviced by a good repairman .freon leaks out .control boards fail etc .
Jul 18, 2016 | Filter Heating & Cooling
MY SAMSUNG SRS584DP IS FRIDGE FAN IS ICING UP AND MAKING A WHIRRING SOUND
does it have a summer setting. turn temp down just a little is frezzer overpacked check for build ups of ice in corner some have holes to alow proper cool air circulation.
Sep 27, 2012 | Cell Phones
Fridge keeps freezing.
its not going into auto defrost the cause is either the freezer fan jammed or burned out the defrost timer but in 99% cases its a burnt out defrost element id start there replace it
Apr 20, 2010 | Hoover HCA390FFK Bottom Freezer...
Samsung fridge freezing the contents
is ther much frost in the fridge?if so, defrost (no hot water)
if not just turn down the thermostat to no 2. on scale of 1-5 poss cause... ambient air temp change from summer to winter i.e. turn it up in summer down in winter....
Feb 08, 2010 | Refrigerators
Refrigerator not freezing
It appears that your thermostat setting is not correct. Please put it on HI cool and then check if the fridge is working OK . The problem could be due to leakage of gas. Please check this If both these fail then get your fridge checked up by a technician as there could be a internal problem. Most likely it is the above 2 problems.
Jan 30, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
GE PFS22MISBWW is a piece of junk
One doesnt like to hear it but possibly cut your losses and look for a less complicated fridge with minimum electronics.
Jul 21, 2009 | GE PDS22LBN Bottom Freezer French Door...
Water dispenser line keeps freezing
no idea.probably need to contact the technician of the manufacturer's firm.
Apr 10, 2009 | Kenmore Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Miele K8952SDED Refrigerator Logo
416 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
