Question about Hoover Washing Machines
I have front loading Ligic 1200 washer and from last week it has stopeed spinning at 1200 rpm.I checked by just using spin 1200 programme it does not spin and leaves clothes wet.I tried "J" + Economy and once it shows crease Guard and when pressed it does not spin. Rest of the functions are OK. What could be the problem and its solution pl.
  • Hoover Master
  • 2,605 Answers
Hi, It can be caused by a obstructed or partially blocked darin pump, have you checked the removable filter/pin trap for the pump at the bottom of the washer ? If it is clogged and not allowing a proper drain, the unit cannot spin correctly...at any rpm. The other possibility is the motor brushes. The unit may in fact rotate one way and you can check this in the wash cycle. After it fills observe the basket turn. Does it go clockwise and counter clockwise ? Let me know what you find. If it is not turning both ways, that is typically motor brushes...see my profile ( macmarkus ) and look for my "how to TIP" on changing the motor brushes. I'll watch for your reply, but it's lights out for tonight where I reside ( Western Canada ) so I will check in the AM. Good luck. Macmarkus :)
Posted on Aug 31, 2010
Is it normal for the washing machine to start and stop the spinning while the machine is in each cycle? Should it take over an hour to run one wash cycle?
Yes...they use less water...so they start, tumble, then cycle again adding more water. I use the fastest setting on all my clothes which is 1/2 hour. It also does start and stop during spinning to tumble the clothes. It speeds up as it goes thru each stop till it spins real fast. All my clothes wash perfectly on fastest cycle.
Aug 13, 2014 | Bosch Nexxt 100 Series WFMC1001UC Front...
NEPTUNE WASHER WILL NOT SPIN UP TO SPEED ON LAST CYCLE
sounds to me to be the programmer (mine went down last week) i bought a new machine as the part was a joke cost wise. if its old your probably find that other things will go wrong soon. now i have a fresh 3 yr warranty. would advise the same for you
Mar 08, 2014 | Maytag Neptune MAH5500B Front Load Washer
What is the meaning of RPM
In general RPM is rotations per minute. This is usually a rating of the washer spin cycle; usually less water is left in the clothing after a faster spin cycle. The washer tub will rotate during the other cycles but that will often be much slower than the spin cycle.
I hope this helps.
(some front-loading High efficiency washers go up to 1200 RPM; top loaders only spin at half that rate usually.)
Dec 03, 2012 | Bosch Washing Machines
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
MACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
May 31, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Washer stoped spinning
It is a 4 out of 10 on the repair scale.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 29, 2009 | Kenmore HE2 Plus Front Load Washer
How to diagnose
Sounds like your motor is blown. That's going to require a repairman.
Mar 31, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Danby front load washer Will not spin motor runs
If the "Spinning Off" button is pushed in you will get this problem.
It happened to my wife last week.
If the drum is turning the belt is OK
Jan 25, 2009 | Danby DWM5500 Front Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
142 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
