Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Forget username and password GT704WG router , I need to connect my IPOD, my desktop and laptop works fine
    Problem Solver:
  • 5 Answers
The default username and password for configuring the router are admin and password respectively, however if you are wanting the password KEY to the wireless signal, look on the router itself, if you didn't change it to something else, it should be WEP KEY listed on the bottom. Good luck!
Posted on Oct 23, 2010
GT704WG wont pass internet connection
need to configure the router again with PPPOE settings on the router.
Oct 20, 2012 | Actiontec (GT704WG) Router
What if the default username and password do not work on a G704WG router
The default username and password for GT704WG router is
username: admin
password: password
If your not able to login, then please click on the link to reset the password
http://www22.verizon.com/residentialhelp/highspeed/networking/troubleshooting/questionsone/87897.htm
Thanks & Regards,
Prema.
Jan 06, 2011 | Actiontec GT704WG Wireless Router...
What is the password trying to set up my laptop for internet connection and it keeps asking for the password. I am using a actiontec GT704WG router
i believe you are referring to the network key,contact your internet service provider and have them personalized the password or try to access the router,type 192.168.1.1,username: admin password: password, once you are able to access the router,you will be able to personalized the password,but what i suggest is to contact ISP
Jun 28, 2010 | Actiontec GT704WG Wireless Router...
I'm trying to connect to my actiontecj GT704WG
hi!. reseting the router is your last option, but 1st try to connect your laptop directly to the router using an ethernet cable and access the setup page of your router and go the wireless settings of the router and you will see the wireless security and password.. to access the setup page u need to check the default gateway of your router, how? click on start, run and type in cmd, it will show the dos prompt and type ipconfig/all, it will list ur ip address, subnetmask and the default gateway.. ex. 192.168.1.1, then pull up the browser and type at the url-192.168.1.1 and it will ask the username and password for the router, u need to type in the username and password for the router so that u can access the setup page..I hope this will help ur problem
Aug 10, 2009 | Computers & Internet
Verizon AGT704WG modem/router conflicts w/ T-Mobile WRTU54G-TM
your Verizon AGT704WG is a gateway, meaning, it's a modem that has router functions (wireless, support for multiple pc's etc.). If you want to connect your T-Mobile wireless router, it would cause certain conflicts with your Verizon 704WG because it is also a wireless router. That's why you can't configure it.
So, if you want to connect your T-Mobile wireless router, you would have to set up your 704WG first to BRIDGE MODE. Which means you would have to disable its routing functions so that only the T-Mobile will function as your router and will not cause any conflict.
If you want to set your GT704WG to bridge mode, follow these steps.
1. Hardwire (connected using ethernet cable) your compuer to your 704WG.
2. On your Internet Explorer or Firefox, type in 192.168.1.1 (default address for your GT704WG). You will then see a verizon page which is the configuration page of your gateway (for newer modems, the background is usually red and black).
3. When prompted, enter username and password. default username is ADMIN, password is PASSWORD or if you've called Verizon tech support, password would be ADMIN (lower case).
4. Click on the MY NETWORK icon from the top bar.
5. Click NETWORK CONNECTIONS from the left navigation box.
6. Click BROADBAND CONNECTIONS (DSL)
7. Under the VC’s section, click the EDIT icon.
8. Select BRIDGE on the PROTOCOL drop down box.
9. Select ROUTED BRIDGE in the BRIDGE MODE field.
10. Click on APPLY and then click on YES to confirm reset.
You would notice that the wireless light on your gt704WG will be off. That's ok because that would indicate that your modem is in bridge mode.
Powercycle (turn off modem for 30 secs and turn it back on) your Actiontec.
That should do it. Good luck.
Apr 20, 2009 | Actiontec GT704WG Wireless Router...
Username and password
if this is fresh from the box, the factory default will be (username - admin) and the (password - admin). but if this already configured by the user before, all you have to do is restart it so that it will back into factory default.
simply press the "reset button" for 10 sec...
then try to login as a factory default then configure it again
Mar 22, 2009 | Actiontec GT704WG Wireless Router...
Need wireless code
if you mean username and password to setup the connection with security etc you will need to go to your routers page and login with a username and password.
A few of these can be found here.
ActionTec isnt a very popular make unfortunatly.
http://artofhacking.com/etc/passwd-actiontec.htm
Mar 12, 2009 | Actiontec GT704WG Wireless Router...
Can't connect iTouch to Verizon GT704WG wireless router
Actiontech routers should use the username/password combination of admin // password. If those aren't working, you or someone else, may have changed the default username/password of the router. In that case, you either need to figure out what was set or use the little red button on the back of the router to reset the router to factory defaults. Once that's accomplished, you should be able to use the password combo above.
Mar 05, 2009 | Westell Wirespeed VersaLink...
Neighbors logging onto my network wirelessly
I have the same router. Mine is from verizon, and i assume yours is also from verizion. Please follow these steps: 1.Type "192.168.1.1" in your browser window. 2.Username is "admin" and the password is "password" 3.Click on wireless setup. 4.Make sure that WEP is on and copy down all of your wireless settings at the bottom.
Thats it.
Jan 02, 2009 | Actiontec GT704WG Wireless Router...
User name and password
Username: "admin" and Password:"password", unless you changed it. If you did, just reset the modem to the factory settings by keeping the reset button pressed, and admin and password should work again.
Dec 01, 2008 | Actiontec GT704WG Wireless Router...
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
186 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
