Question about E-Machines eMachines Desktop PC
Windows xp my t3516 emachine will not start windows keeps restarting but nothing. when i try to download system recovery discs(there are 3), completes disc 1 then ask for disc 2 , downloads most of it and will say that system restore is complete. then says put in disc1 and it repeats it to this point. the 3rd disc never gets installed. any solutions how to solve this problem? thanks
    Genius:
  • 1,673 Answers
The hard drive may be defective. It is very difficult to fix a computer problem over email unless it is a common type of fault. Get a computer tech to check this out for you.
Jerry G.
Posted on May 09, 2008
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
Mi notebook acer aspire 3000LCi the only do is a an upper and i dont have a recovery disk
When you restore your system back to the new factory settings, it will wipe your hard drive clean and do a fresh install of the operating system with the original factory setting.
To start this process, unplug all extra devices from your computer
(printers, external hard drives, etc.) as these can interfere with the system restore.
Starting with Windows XP, most systems with issued a system recovery disk in case of any problems with the factory installation.
Check the documentation and disks that came with your computer to determine if you have one of these system disks.
If you do have a copy of this disk, place it in your CD/DVD drive and restart your computer.
If you do NOT have a copy of this disc, skip to step 3 for further instructions.
Once you restart your computer, a screen will appear with the words.
Press Any Key to Boot From CD. Once you press a key, a screen will come up containing instructions to format your hard drive and restore the original factory settings.
Follow the on-screen prompts to finish the installation.
Once the restore is complete, remove your Recovery CD from the disk drive so that your computer does not try to boot from the CD again.
Restart your computer to complete the restore.
3. If you do not have a System Restore disk, then your computer should have a recovery partition on your hard drive, separate from the main partition of the disk.
Unplug all external devices and restart your computer.
When the loading screen comes on with the Windows logo, press Alt+F10 together five times.
This will bring up the system restore menu.
Follow the on-screen prompts to restore your computer back to the factory settings
hope this helps
Oct 17, 2012 | Acer Aspire 5610-4648 Notebook
EMachine EL1850-01e
It looks like you'll have to either return it or perform a default factory recovery. These instructions are from their site but proceed knowing that this will erase any data that is stored on the primary partition (meaning if you have anything on it, it's gone...). Esentially it resets it to a point as if you just picked it up in the store (which you did.. :( )
How can I restore my computer with the backup discs I created?
With user created backups you are able to restore your computer to the factory default settings. If backup discs were created instead of factory restore discs, these can be used instead and will restore the system to a user backup point.
    If you have a recovery disk:
    1. Ensure that the computer is completely shutdown, then turn on the computer.
    2. When the eMachines splash screen appears, tap the Alt and F10 keys simultaneously. A screen stating "Starting eMachines eRecovery" should appear.
    3. From the recovery options, choose Restore system from CD/DVD.
    4. Insert either the first Recovery or Backup disc that you created.
    5. From the on-screen options, choose a backup.
    6. Click OK and the installation will begin.
    7. Change the disc as necessary when prompted.
      If you do not have a recovery disk:
    8. Restart the computer.
    9. When the eMachines logo appears on the screen, press the Alt and F10 keys repeatedly.
    10. If you are prompted with a Microsoft Windows boot screen, press the Enter key.
    11. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Dec 13, 2011 | E-Machines eMachines Desktop PC
Restored Emachine T3516 computer to factory settings and now the computer says the ntldr is compressed
This should solve your problem:
1. Start the Recovery Console. If you do not have the Recovery Console installed, start it from the Windows XP compact disc (CD). To do this, follow these steps:
a. Insert the Windows XP CD and restart the computer. If prompted, select any options required to boot from the CD.
b. When the text-based part of Setup begins, follow the prompts; choose the repair or recover option by pressing R.
c. If you have a dual-boot or multiple-boot system, choose the installation that you need to access from the recovery console.
d. When prompted, type the Administrator password.
2. At the command prompt, type "cd \" (without the quotation marks), and then press ENTER.
3. Type "ren ntldr ntldr.old" (without the quotation marks), and then press ENTER.
4. Type "map" (without the quotation marks), and then press ENTER.
5. Note the drive letter assigned to the CD-ROM drive that contains the Windows XP CD. It is displayed in a format similar to the following: D: \Device\CdRom0
6. Type "expand <drive>\i386\ntldr._" (without the quotation marks) (where <drive> is the drive letter of the CD-ROM drive that contains the Windows XP CD), and then press ENTER. For example:
Expand d:\i386\ntldr._ <ENTER>
Note the underscore character after the "."
The following message appears: ntldr, 1 file(s) expanded.
7. Type "exit" (without the quotation marks). The computer restarts.
8. Remove the Windows XP CD and start the computer normally.
IF that fails put in your Windows installation CD and reinstall the operating system
Aug 27, 2011 | eMachines T3516 PC Desktop
Can't find my startup disc for my emachine, is
yes windows xp potable CD will solve it but select boot from CD ROM rather boot from floppy disk or you can use windows xp on bootable flash memory or you can restore your windows it might work
May 23, 2011 | E-Machines eMachines Desktop PC
I was trying to create the Recovery Management disk but everytime I try to burn the CD it keeps ejecting. I would really like it if you could provide some help. I recently bought this E-Machine computer...
Welcome to Fixya
Please see procedure below on how to create recovery disk. Let me know if smae thing will happen.
  • 1
    Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
  • 2
    Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
  • 3
    Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
  • 4
    Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
  • 5
    Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
  • 6
    Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
  • 7
    Set up Windows Vista with your own personal settings.
  • Thank you for using Fixya!
    Dec 04, 2010 | E-Machines emachines (emachinees) CD-ROM...
    My emachine M6805 will not boot up. It gets to
    Do you have a recovery disk set, or is there a recovery partition on the hard drive?
    Mar 14, 2009 | E-Machines M6805 Notebook
    Only getting EMachines/Windows XP Logo when boot up T3882
    you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
    Aug 18, 2008 | E-Machines eMachines Desktop PC
    E-Machines eMachines Desktop PC Logo
    94 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
